10-01-09, 06:56 PM
Coolant Leak
I have a 93 4Runner. It is leaking coolant out from behind the timing cover. I have been told that it could possibly be the head gaskets. I haven't noticed any white smoke indicating that the coolant is getting into the cylinders. The part that I don't understand is that it only leaks after it has been parked for a while. I don't want to put a lot of money into it because I want to sell it. Any help would be appreciated. Thanks.
10-01-09, 07:06 PM
it could be the water pump
10-01-09, 08:14 PM
Incredibly random
water pump, upper coolant inlet, or head gasket(s)
could be any of the above.
10-01-09, 08:21 PM
You're gonna have to take it apart anyway. My bet is on the water pump.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
10-02-09, 05:20 AM
Rookie
I had a water pump go out recently on my 1995, and the leak was coming from almost the exact spot you described. Not sure about the milage but mine finally went at about 140K. A good indicator of whether or not it's the water pump is how fast the leak developed. If it came on suddenly then it's a good chance it is your water pump. If it took time to develop, like one drop here, one drop there, it's probably something else. Mine leaked for a day or two, then it just poured like my truck was raining. I had it replaced by Toyota and it cost me $525. If you plan on replacing it, you may as well do the timing belt at the same time.
10-02-09, 11:42 AM
Thanks guys. I figured it was the water pump. Luckily I can do it myself. Looks like I'm making a trip to Carquest.
10-02-09, 12:25 PM
I hope your trip to Carquest is to get rags and brake cleaner for the job. There is NO WAY IN HELL I would trust anything but Toyota OEM quality for something as important as a water pump. It's not a quick easy job to get to that thing behind all those belts and covers, you don't wanna be doing this again in a year.
Call CDan, get the parts from him.
KB1OSF
'98 Lexus ES300
10-02-09, 01:04 PM
x a billion.
Originally Posted by decavo
he got a new blue ray of a Johnny Depp movie and is in a 646 coma
90' Pickup reg cab 22RE-W56-LCE dual chain conversion-tr*il gear slides-31' BFG MT-15x8 Allied rockcrawlers-SAW torsion bars-Rancho & Bilstein shocks-97' taco front bumper-custom 6 leaf rear
01' 4Skinner SR5 5VZFE 4x4 all stock
Web Wheeler Wizard-Level 21
10-03-09, 10:23 AM
Incredibly random
And X a billion more
10-05-09, 12:30 AM
#10 (permalink)
It's the water pump.
Water pump is driven by the timing belt, (another not-so-great aspect of the 3.0) so you might as well replace it too, and while you are there, replace the thermostat.
I would normally be the one to tell you to just get the water pump from the local parts house, but it something happens on that engine and the water pump locks up or the bearing comes apart, your timing belt goes too........very bad for the engine.
Black 95 4runner--the family playtoy
silver 01 cherokee--the family hauler
red 88 toyota truck--the red rust sled/abuse testing vehicle
wanna go wheelin? luke 306-3519
10-08-09, 06:50 PM
#11 (permalink)
Getting ready to get started anyone have pics or a write up on how to do this?
10-08-09, 10:13 PM
#12 (permalink)
times 11venty billion more.
10-08-09, 10:44 PM
#13 (permalink)
What are you planning?
10-08-09, 10:54 PM
#14 (permalink)
Oh nevermind......
It's a good solid day worth of work... Remove things in this order:
Drain coolant
Intake hoses and air filter box
fan shroud and radiator
the thing that sticks through the timing belt cover and goes to the upper rad hose (double nut the studs to remove them)
Fan
upper timing cover
middle timing cover (has idler bearing thing on it) You will have to loosen a couple bolts on the power steering pump to get it off.
Use starter and a breaker bar with 1/2 drive 19mm socket to remove crank pulley
Lower timing cover
timing belt
water pump
then put it all back together.... you'll want a FSM handy to check on torque specs etc.
The timing belt tensionor is a hydraulic thing that you need a press to push in. You might be able to do it with a jack under the truck...
Pile everything up in a row with it's bolts so you don't loose anything... this list may not be 100% complete on in the right order, but it'll get you close.
And remember, have fun!
10-09-09, 12:56 AM
#15 (permalink)
Going to replace the timing belt along with the tensioners and pulleys and water pump.
10-09-09, 06:15 PM
#16 (permalink)
get you a repair manual. it shouln't take you maybe 3 to 4 hours from start to finish.
10-09-09, 10:49 PM
#17 (permalink)
Oh nevermind......
I think that's really optimistic... Things will take longer than you think they will. i just got done changing the brushes in a 22RE alt, and it took way longer than it should have, cause i could not get the alt plug back in... Had to pull the alt back out to figure it out....
Plan for a whole day, and don't do it on a Sunday.... nothing is open when you need it.....
10-09-09, 10:54 PM
#18 (permalink)
I've done a few, and I don't think I could do it in 3-4 hours. At least not do a good job.
KB1OSF
'98 Lexus ES300
10-11-09, 07:57 AM
#19 (permalink)
i have done several timing belts on v6 truck, cars, and vans. replacing all the seals and pulleys and the water pumps in less than two hours.
10-11-09, 08:23 PM
#20 (permalink)
Incredibly random
If they were toyota v6s..... you were doing it wrong.
10-11-09, 08:52 PM
#21 (permalink)
That is pushing it even on a 22r including you do the timing
10-11-09, 09:59 PM
#22 (permalink)
No offense intended, but I wouldn't trust the work of someone that told me they did a water pump and timing belt job on a 3VZ in 2 hours.
This reminds me of the time a guy posted in Pirate that he did a clutch job in an hour. He then tried to tell me he never removes the crossmember. Ya OK...
KB1OSF
'98 Lexus ES300
10-11-09, 10:11 PM
#23 (permalink)
Toyota master tech that did my 3.4L timing belt, water pump, thermostat, and crank seal in a hour fifteen.....while talking the whole time. Course he's only been doing it for 30 years.
10-13-09, 07:17 PM
#24 (permalink)
Incredibly random
I believe that.
Not including cam seals.
