09-22-09, 01:00 PM
Clutch advice...
Getting geared up to swap in my rebuilt R151F with crawler t-case (finally!), may start this weekend. The clutch in my truck now has about 80K on it, I know of 2 times when I abused it enough to get it stinky and smoky, so I know it's close to shot. Trying to decide what to do, but I think I've made my mind up already. Looking for holes in my thinking...
I have the clutch and flywheel from the turbo parts truck. The clutch is in remarkable shape, not new but still quite a bit of material on the disk. It is an AISIN clutch. I think I'll just have the turbo flywheel resurfaced, then put it in, with the used clutch. Might as well use it, right? I think the turbo flywheel is a little bigger in diameter at the clutch contact point, but I don't know about the weight.
Am I missing something?
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
09-22-09, 01:19 PM
you can do that but toyota's week link is there clutch. i have a centerforce and it does not slip.
QUIT SUCKING MY OXYGEN
09-22-09, 01:29 PM
Well, I've never used anything but AISIN clutches (OEM from Toyota), have been happy with them so far. I know the turbo clutch on the 22RTE is a little bigger, so I'm sure it will be up to the massive torque of my tired ol' 22RE.
Actually, now that I think of it, I made the mistake of installing a no-name aftermarket clutch from AutoZone once. Huge mistake, that POS lasted about 1500 miles and fell apart.
KB1OSF
'98 Lexus ES300
09-22-09, 01:41 PM
every time i did a steep hill climb my stock toyota clutch would slip and burn and stink, so i talked with a service adviser at the local dealership, he was an offroader, he told me that toyota designed it that way so the clutch would slip before something more expensive broke. so when i had the engine out i put in a centerforce and it has not slipped so it is now in my 84 4runner and when it is time i will buy another one. also i but it in my 87 in 96 and drove the truck about 140 miles a day into dc and offroaded on weekends i finally killed it when the trans went out after driving it through the Shenandoah river and got water in the trans that was in 2000.
09-22-09, 01:45 PM
as for the autozone experience i had that with a life time alternator.
09-22-09, 01:54 PM
New Centerforce DF clutch from Summit = $310 + shipping
Clutch sitting in my garage right now = FREE
Time to swap a clutch = 4 hours
What would you do?
KB1OSF
'98 Lexus ES300
09-22-09, 02:53 PM
i would buy the centerforce, but to put another spin on it i am out of work. so at this moment i would use the free in the garage one and get about 100 to 200 thousand miles out of it. i do not get to go offroading much any more.
09-22-09, 03:06 PM
if i had the money and i were doing the work you are doing i would definitely buy the centerforce. and check around i think four wheel wharehouse had it for $293 with free shipping not long ago when i thought mine was gone.
09-22-09, 03:22 PM
Well... considering I also just dropped ~$400 for a new header from LCE (arrived yesterday), I think a new clutch "just because" is not a good idea right now. I just want to make sure I'm not missing some glaring technical issue.
KB1OSF
'98 Lexus ES300
09-22-09, 03:30 PM
#10 (permalink)
i do not know if it is different or not. i do not think so if it were it would be in the trans input shaft, so you would have to use the turbo clutch any how. but you might have to use your fly wheel. the turbo engines could have used a different crank. like i said i do not know for sure.
09-22-09, 03:41 PM
#11 (permalink)
try and use the turbo clutch its free
09-22-09, 03:47 PM
#12 (permalink)
Tartu hetkeen
With that salary those students are paying for, id buy a new one
Crusified:
You don't "lock" a Toyota's hubs, you "Call down the Demons".
09-22-09, 09:07 PM
#13 (permalink)
the center force dual friction is the way to go
09-22-09, 09:17 PM
#14 (permalink)
Oh nevermind......
OT, what are the 1st and 5th gear ratio's on the R151F? I thought I heard it had a lower 1st and a taller overdrive, can anyone confirm? Thanks!
Clutch: If you have a garage and don't mind swapping a clutch, go for the free one, and then donate the $310 you would have spent to my "Ran when Parked" project!
09-22-09, 09:57 PM
#15 (permalink)
Yes, this is true, this is one of the reasons why the R151F is so desirable. Check out the data on the expert's (Marlins) website:
Transmission Gear Ratio Chart | Marlin Crawler, Inc.
Really looking forward to finally getting mine installed.
Hmmm... maybe I'll donate it towards my "keep beer in my fridge" project...
KB1OSF
'98 Lexus ES300
09-22-09, 11:09 PM
#16 (permalink)
Oh nevermind......
KLF...... this is an intervention!  Send me your beer money!
Thanks for that link! I'm going to FAQ it right now.
I wonder if the R154 out of the turbo Supra is similar enough to the 151 to swap 5th gear....
09-23-09, 05:42 AM
#17 (permalink)
Hmmm... maybe I'll donate it towards my "keep beer in my fridge" project...  [/QUOTE]
why didn't you just say that in your first post. you have to keep the fridge stocked up, that is mandatory.
09-23-09, 06:48 AM
#18 (permalink)
I went with the LC Engineering Pro Street clutch after considering both the Centerforce and some of Marlin's offerings. Cost wasn't a major factor in my decision but I remember paying less than $300.
09-23-09, 11:56 AM
#19 (permalink)
Not to stir the pot but I have had a Autozone clutch in my truck for 50k miles without any issues whatsoever.
This is with hauling a trailer up and down Jellico Mountain many many times.
So, not sure expensive is always the way to go. And like many have said, why do you need a high friction clutch on a 22re? I have never, not once, burnt my clutch and I have pulled many a truck out in farm fields-amazing how the diesel Dodges just spin the tires in wet/mud considering all the torque and being unloaded.
"May you be in heaven a half an hour before the devil knows you're dead"
1992 4x4 PU
09-23-09, 12:28 PM
#20 (permalink)
he might have been looking at a centerforce 2 i just have the centerforce one i like it because it behaves the same as stock on take off but the more rpms the more grab. and with my stock with out a trailer it would slip on steep hill climbs. with the centerforce i have hauled 1 1/2 cords of wood on my trailer over a mountain on a logging trail just to get to the main road and no slippage what so ever.
09-24-09, 12:00 PM
#21 (permalink)
The cheapo AutoZone experience happened in 1992, actually this was before AutoZone, they were known as AutoPalace back then. It was a Saturday afternoon, I had the tranny down to replace the leaking RMS, and found the clutch to be marginal, so I set about finding a replacement. Dealer was closed, so they were the only place in town that had one. It was manufactured by a company called "Blue Chip" out of PA. There were no springs on the center disk, just rubber cushions. The rubber parts disintegrated, all the washers fell out of the disk, it went south from there. Really chewed up the flywheel. They were total dicks about it when I tried to get a refund, too.
KB1OSF
'98 Lexus ES300
09-24-09, 01:38 PM
#22 (permalink)
Trivia for the FAQ:
22RE flywheel: 24.2 lbs, 11" diameter
22RTE flywheel: 23.7 lbs, 11-1/2" diameter
Starter gear rings are the same diameter and teeth count.
KB1OSF
'98 Lexus ES300
09-24-09, 07:55 PM
#23 (permalink)
less weight equals more rpms
09-24-09, 07:55 PM
#24 (permalink)
more weight equal more torque
09-24-09, 11:57 PM
#25 (permalink)
Everyone has their opinion, but I've got over 200,000 miles on my Aisin clutch. I wouldn't replace it with anything else.
Originally Posted by decavo
he got a new blue ray of a Johnny Depp movie and is in a 646 coma
90' Pickup reg cab 22RE-W56-LCE dual chain conversion-tr*il gear slides-31' BFG MT-15x8 Allied rockcrawlers-SAW torsion bars-Rancho & Bilstein shocks-97' taco front bumper-custom 6 leaf rear
01' 4Skinner SR5 5VZFE 4x4 all stock
Web Wheeler Wizard-Level 21
09-25-09, 05:26 AM
#26 (permalink)
I'm with ya on this. When a co-worker finally had to retire his '86 4Runner a few years ago due to excessive rust, it had over 350,000 miles on it, but still the original factory clutch. I was with him when he bought it brand new in early '86, that was the truck that really got me hooked on these things.
KB1OSF
'98 Lexus ES300
09-25-09, 03:51 PM
#27 (permalink)
yes factory clutches are good but what does it hurt to make sure that your clutch isn't going to slip.
09-26-09, 06:19 AM
#28 (permalink)
Holy crap... I'm beginning to think keeping an old truck on the road is costing more than it may be worth. $50 to have a flywheel resurfaced. $50 for a throwout bearing. And a new OEM rear main seal is now $41!!
KB1OSF
'98 Lexus ES300
09-26-09, 10:22 PM
#29 (permalink)
everything keeps getting higher but the money flow keeps getting less
09-26-09, 10:26 PM
#30 (permalink)
yep sucks and klf i doubt buying new would decrease your cost.
