Old 09-16-09, 08:44 PM   #1 (permalink)
cruiser88's Avatar
TLCA# 17319
dual t-case install
What do I need to do to get this in?
http://forum.ih8mud.com/sale-parts/3...-complete.html
other than the transfer to tranny gasket,cut hole in floor?
Driveshafts ok the way they are?
I already have the front driveshaft kit...I just never have put it in.
my rig is an 84 runner with a newer topshift
Originally Posted by calstyl2 Randy has lots of junk.........
NEW! Club sticker for sale. See my avy...pm me for details!
MountaineerCruisers.net
Need a mini truck head for cheap?
http://forum.ih8mud.com/sale-parts/3...ini-truck.html
Old 09-16-09, 08:54 PM   #2 (permalink)
cruiser88's Avatar
TLCA# 17319
how about the crossmemeber........need re-located?
Old 09-16-09, 09:07 PM   #3 (permalink)
cruiser88's Avatar
TLCA# 17319
Marlin Crawler was the first to bring dual transfer cases to the USA and the first in the world to bring low range gear kits to the Toyota market. As the leader in Toyota transfer cases we build the best units period. We can give you the low range, slow crawling gears your looking for.
Installing a dual transfer case into a 4-cyl equipped truck requires moving your existing t/case back approximately 6.5 inches. The additional crawl box is installed between the transmission and t/case. All 4-cyl gear driven t/cases are 21-spline except for the 1986-87 turbo, which is 23-spline. 2.28:1 or 4.70:1 gears can be used in any combination in the two t/cases. The most common choice is one set of 2.28:1 gears and one set of 4.70:1 gears, known as a Dual Ultimate Crawler. When building a transfer case for 4-cyl applications, the stock 21-spline input gear can be used. When building turbo, V6 & V8 applications, we highly recommend using a 23-spline input in the rear t/case. Otherwise, failure of a factory 21-spline input gear is certain. Floorboard and drive shaft modifications are required. The factory crossmember remains in its original position.
  • 20 forward and 4 reverse gear combinations.
  • Fits 1979-1995 gear driven transfer case applications.
  • Includes (1) EcoSeal transmission output seal and (1) EcoSeal transfer case rear output seal.
  • 4 & 5-speed application only.
  • One t/case shifter included, reuse your original shifter in second position.
  • 4.00 or 4.97 gears available upon request.
Old 09-16-09, 09:21 PM   #4 (permalink)
beauty school dropout?
RockDoc's Avatar
TLCA# 18148
What the f&%k is a t-casr, and why would you want two of 'em?
[ ][ ]=TOYOTA=[ ][ ] - 3FE and rust - Wobble Wagon
[ ][ ]=TOYOTA=[ ][ ] - 2FE and no rust, in the works
Edmonton area Cruiser Corner
Peace Canyon Toyota Swamp Donkeys
Today's lesson: You can't teach others, you can only facilitate their learning.
RockDoc is online now   Reply With Quote
Old 09-17-09, 06:52 AM   #5 (permalink)
cruiser88's Avatar
TLCA# 17319
lol.....I noticed that. The beer was good last night
Old 09-17-09, 11:42 AM   #6 (permalink)
KLF
KLF's Avatar
Besides new driveshafts, you'll need one of these:
BudBuilt - Dual Case Crossmembers
and you gotta hack a big hole in the floor of the cab. You'll also need an extension for the speedo cable.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Old 09-17-09, 11:49 AM   #7 (permalink)
cruiser88's Avatar
TLCA# 17319
What do I need to do with the rear driveshaft? Keep in mind I have a good size lift. I know from looking I need to get my driveshaft kit in the front
Old 09-17-09, 11:52 AM   #8 (permalink)
cruiser88's Avatar
TLCA# 17319
I see what you mean about the rear. How do I go about getting it shortened? Local drive shaft shop?
Old 09-17-09, 12:11 PM   #9 (permalink)
cruiser88's Avatar
TLCA# 17319
looks like 200 clams to get both shafts cut and balenced
Old 09-17-09, 12:30 PM   #10 (permalink)
cruiser88's Avatar
TLCA# 17319
The marlin case is about 6 inches thick.........so I need to shorten about 6 inches?
Old 09-17-09, 05:06 PM   #11 (permalink)
Tartu hetkeen
liljlandon's Avatar
Garage
I would assume, but could be wrong.
Crusified:
You don't "lock" a Toyota's hubs, you "Call down the Demons".
liljlandon is offline   Reply With Quote
Old 09-17-09, 05:12 PM   #12 (permalink)
RockDoc's Avatar
TLCA# 18148
Did you ask Gary about the shafts from the truck it was pulled out of?
Old 09-17-09, 05:30 PM   #13 (permalink)
cruiser88's Avatar
TLCA# 17319
ohhhhhhhhhhhhh good question
Old 09-17-09, 05:40 PM   #14 (permalink)
North Florida Cruiserhead
mel lowe's Avatar
TLCA# 19409
I took measurements for the shafts, once the cases were in the rig.
82 Fj60 - 2F, 37"s, Toybox, Daily Driver, 62 Frame, Lights, Grill and Roof
http://nfcruiserheads.org/forum
mel lowe is offline   Reply With Quote
