Old 09-16-09, 08:05 PM   #1 (permalink)
Rookie
Horn switch/relay
Hey folks. Trying to get my 1985 4x4 mini past inspection. Horn hasn't worked since I got the truck a year ago, except at about 1/4 turn left and 1/2 turn right. This evening I pulled the steering wheel, and found that the spring-loaded horn post doesn't touch the brass contact plate on the back of the wheel except at those two places. Is there some way I can adjust the horn post, contact plate, or something else? Otherwise, replace contact plate, horn post, some other part in that vicinity?
thanks!
tghurst0 is offline   Reply With Quote
Old 09-16-09, 09:24 PM   #2 (permalink)
horn post.
it should not look like a nail or just a thin bar.
the (head of the nail) post is fairly long.
I can't find the picture I had of one.
missouriman is offline   Reply With Quote
Old 09-16-09, 10:11 PM   #3 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
Sometimes stretching out the spring a little will give you a bit more life. But it's time for a new contact really...
Old 09-17-09, 06:28 AM   #4 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
Replace the contact. About $6.50 from Toyota.
aka Bushrat
1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB ... assembled!
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
"EFI Jon, EFI." - Juane
pappy is offline   Reply With Quote
Old 09-17-09, 09:06 PM   #5 (permalink)
Rookie
Replace the contact even when it seems like the spring is what is short? Or is it that the contact has worn down enough so the spring isn't touching the contact throughout a full revolution of the wheel?
Old 09-19-09, 06:53 AM   #6 (permalink)
x factor's Avatar
TLCA# 18254
I just fixed mine with a thin piece of cardboard. Take the ring off the back of the steering wheel and use it for a template. The scews that hold the ring are long enough for thin box cardboard.
I'm a cheap bastard.
Bill
'84 Flamed flatbed
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preseved body,but rather to skid in broadside, totaly worn out & proclaming "WOW WHAT A RIDE!"
x factor is offline   Reply With Quote
Old 09-20-09, 07:18 PM   #7 (permalink)
Oh nevermind......
TLCA# 13872
Yes, the contact has worn down. The fat section on the end should be 1/4+/- long when they are new, but they wear down to 1/8-1/16 and they stop making contact...
Or you could do the cardboard thing...
