Old 09-13-09, 08:08 AM   #1 (permalink)
Rookie
IFS Upper Control Arm
I have a 89' Toy, 3.0 v6 with the Toytec spacer. I have run into an issue where the IFS upper control arm was changed by the manufacturer mid 88'. The upper rear control arm bushing changed sizes and the pre 88' is a little difficult to get. I was able to get the bushing with some work, had them pressed in. The arm was, lets say, not in the same condition when I dropped it off when i got it back.. but it seems to work for the time being. Yet I would like to see if there is a company that makes an aftermarket replacement control arm. I believe Rancho used to replace the upper control arm in their lift kits but that it is no longer avail. I intend on staying as stock as possible and maybe making it easier to find the bushings for this part in the future. Perhaps a later model stock arm will fit and then I would be able to use the Energy Suspension kit (Which the bushing is too long upon test fitting for the pre 88') ??? Any suggestions are appreciated.
skyehunter is offline   Reply With Quote
Old 09-13-09, 10:22 AM   #2 (permalink)
corax's Avatar
Garage
if the post-'88 arm bolts in the same way, junkyard a pair of upper control arms and just use the later style
-Keith- kb3scj
'88 4runner SR5 - 3L 7MGE swap - Marlin HD W56 - 4.56 V6 Thirds, LSD up front - 33x10.5 BFG KM2's- home fab front and rear bumpers - NWMP 14 gal aux fuel tank
"Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
corax is offline   Reply With Quote
Old 09-13-09, 11:48 AM   #3 (permalink)
Rookie
Yeah, just not positive it bolts up the same way....time for junkyard run i guess.
Old 09-14-09, 10:08 PM   #4 (permalink)
DanS HJ-45's Avatar
TLCA# 17527
I should have some A-arms from a '91 LN-130 Hilu Surf sitting around the shop that I could measure (or sell) for you.
Dan
KE5YYE
1976 HJ-45 (needs restoration) http://forum.ih8mud.com/fj45-owners-...self-into.html
1991 "Faux-Lux"Pickup 4x4 2LT-E/R-150f http://forum.ih8mud.com/79-95-toyota...onversion.html
1979 FJ-40 to BJ conversion http://forum.ih8mud.com/diesel-tech-...ml#post3811936
"Dandelions. You see flowers in these weeds."
--Five Iron Frenzy
DanS HJ-45 is offline   Reply With Quote
Old 09-17-09, 07:26 AM   #5 (permalink)
Rookie
If they are the same and fit what would you be looking to sell them for?
