Old 09-02-09, 11:57 AM   #1 (permalink)
4.88 or 5.38??
I'm making an engine swap, my old engine was an 22RE and i was running 4.88 R&P set with it. Now i have in a my hands 2 sets of R&P 5.38 for my front diff (DANA 44) and 5.29 for my rear diff (Toyota 8")
Running a 5VZ-FE is better to keep my 4.88's or change for the new sets??
mferguson28 is offline   Reply With Quote
Old 09-02-09, 12:00 PM   #2 (permalink)
cruiser88's Avatar
TLCA# 17319
Not sure if the transfer case would bind with two diffrent gear ratio's?
Originally Posted by calstyl2 Randy has lots of junk.........
NEW! Club sticker for sale. See my avy...pm me for details!
MountaineerCruisers.net
Need a mini truck head for cheap?
http://forum.ih8mud.com/sale-parts/3...ini-truck.html
Old 09-02-09, 12:08 PM   #3 (permalink)
te difference bettwen one and the other is 1.6% the maximun acceptable is 2.0%
Old 09-02-09, 12:46 PM   #4 (permalink)
inkpot's Avatar
TLCA# 10338
Howdy! I always thought that the lower gear set (bigger number) should go in the front, since the front travels a longer distance while making turns. Tire size, rig setup, and driving styles might all influence whether you should stay with the 4.88's. John
85 Toyota mini truck for chase/support!
CSC #41
inkpot is offline   Reply With Quote
Old 09-02-09, 12:51 PM   #5 (permalink)
Thanks, now i'm running 35's SS LTB, but i'm planning to go to SS TSL 38's
Old 09-02-09, 01:20 PM   #6 (permalink)
WarDamnEagle's Avatar
Not if you keep it in 2H (or Neutral)!
It might work but I wouldn't do it. Not that I'm an expert on the subject...I'm just anal retentive that way.
1985 4Runner - ROTM WarDamnEagle's 85 4Runner
1997 FZJ80 - locked and stock
2007 HDJ100 - DD
Plus a few others
WarDamnEagle is offline   Reply With Quote
Old 09-02-09, 01:51 PM   #7 (permalink)
toy4xfun's Avatar
i do not think i would either. but i think some ford broncos came from the factory like that they had a warning not to engage 4wheel drive on hard surface roads.
QUIT SUCKING MY OXYGEN
toy4xfun is offline   Reply With Quote
Old 09-02-09, 02:00 PM   #8 (permalink)
inkpot's Avatar
TLCA# 10338
Howdy! I'm running 5.29's over 35's on my mini truck now, withe a 22re. My speedo is about 10% lower than actual speed. Cruising on the freeway means running between 3000-3500 rpm to keep up in the left lane. If your going to drive a lot of mud at WOT, I would probably stay with the 488's. The bigger engine should be able to keep them spinning. But if you are going to crawl a log of bedrock, then go with the lower gears. John
CSC #41
