Old 08-31-09, 10:47 AM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Rookie
Vacuum Leak - 3VZ-E, Air Suction Reed Valve?
I have a '92 pickup with the 6 cylinder 3VZ-E engine. For some time now, there has been a pretty loud noise from the passenger side of the engine compartment. It sounds like an unmuffled engine. I have also noticed that I have very little power when accelerating and it acts like the engine is "missing" in the lower RPM ranges. I friend of mine listened to it and said it sounded like a vacuum leak. He messed around a little and traced it to a box near the back of the engine on the passenger side. It has 2 metal plates with a gasket between them. The plates have separated and when closed the engine noise improves significantly. Looking in the Haynes manual, I think this is the "air suction reed valve." Does this sound right? If so, can I just replace it? What does it do? Could it be responsible for the power loss? The manual doesn't say anything about it. It just shows it in a diagram. Any input would be greatly appreciated.
Thanks.
drcaduceus is offline   Reply With Quote
Old 08-31-09, 12:17 PM   #2 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
Welcome to Mud!!!!
Wait a minute..... 2 years a member and this is your first post?
I don't know much about the ASRV, but if you look in the FAQ thread here, there is a 93 FSM link that you can learn all about it from.
Old 08-31-09, 02:28 PM   #3 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
Originally Posted by drcaduceus View Post
I have a '92 pickup with the 6 cylinder 3RZ-E engine.
Thanks.
Just a little nit-pick. The 3RZ-FE is a 4 cylinder engine used in 1995+ trucks. You should have the 3VZ-E which would be the 3.0 vee6.
aka Bushrat
1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB ... assembled!
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
"EFI Jon, EFI." - Juane
pappy is offline   Reply With Quote
Old 08-31-09, 06:55 PM   #4 (permalink)
Rookie
Yep, you're right. I put the wrong letter in. Sorry for the confusion.
LinkBack to this Thread: http://forum.ih8mud.com/79-95-toyota-truck-tech/308206-vacuum-leak-3vz-e-air-suction-reed-valve.html
Posted By For Type Date
T-thread Vacuum Leak on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 09-28-09 08:06 PM
WASALive ! Air - IH8MUD.com This thread Refback 09-08-09 05:34 AM
