Old 08-23-09, 11:27 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Exclamation 89 toyota pickup 4x4 wont stay running
the other day i was playing in the mud, i hit a really wet hole pretty hard. the truck started spitting and spudering while trying to drive. this went on for about 20 min then it started running great. about a week passes and i park my truck on a hill while at work, it starts raining really hard. then when i start to head home, it starts spitting and spudering again. but only with a load on it. i could push in the clutch and it would rev up fine. well i drove it like that for about 15 miles to an auto parts store to ask if they had any idea what was going on. they said my mass air flow sensor may have gotten wet, so we took it off and cleaned/inspected it. when i put it back on, the truck wouldnt run, at all. it was low on gas so we put some in it, just in case. that wasnt the problem either. i then removed the fuel line from the fuel filter on the tank side and turned my key on. it wasnt appearing to be pumping any fuel so i replaced the fuel pump. well now it will start and idle great for about 3 seconds then it starts running rough then dies. i have checked the ditributer, its not wet. i have checked to make sure it was firing, it is. i have taken my battery terminals off to reset the computer, it didnt help. i have a feeling it is something very simple but i cant figure it out and i dont have the money to take it to a mechanic. any ideas? it has a 3.0 ltr v6
yotakiller is offline   Reply With Quote
Old 08-24-09, 12:48 AM   #2 (permalink)
raydouble's Avatar
Did your airfilter get soaked?
Have you pulled sparkplugs?
Originally Posted by decavo View Post
he got a new blue ray of a Johnny Depp movie and is in a 646 coma
90' Pickup reg cab 22RE-W56-LCE dual chain conversion-tr*il gear slides-31' BFG MT-15x8 Allied rockcrawlers-SAW torsion bars-Rancho & Bilstein shocks-97' taco front bumper-custom 6 leaf rear
01' 4Skinner SR5 5VZFE 4x4 all stock
Web Wheeler Wizard-Level 21
raydouble is online now   Reply With Quote
Old 08-24-09, 01:22 AM   #3 (permalink)
i just bought the truck about a month before, it didnt even have an air filter in it when i checked and we pulled one plug to make sure it was firing. it was.. oh and when we pulled off the top of the aif filter housing, water poured out but when we opend the air flow sensor it didnt apear to have gotten wet
Old 08-24-09, 01:32 AM   #4 (permalink)
raydouble's Avatar
It's for a 93' but it will work...
1993 Toyota Pickup Service Manual
My first instinct would be check electrical in distributor and at coil, igniter and the VAF air meter.
Edit: coolant temp sensor also...
Old 08-24-09, 01:44 AM   #5 (permalink)
ok. thanks.
Old 08-24-09, 02:09 AM   #6 (permalink)
raydouble's Avatar
Maybe check the resistance of the spark wires also.
Old 08-24-09, 06:39 AM   #7 (permalink)
KLF
KLF's Avatar
Just an FYI... turning the key to ON won't make the fuel pump run. You can force it to run but taking a paperclip and jumpering the B+ and Fp contacts in the Diagnostic connector under the hood, then turn the key ON. It's likely you replaced the fuel pump for nothing.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
KLF is online now   Reply With Quote
Old 08-24-09, 09:07 AM   #8 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
Runs for a few seconds and dies sounds like a bad connection at the air flow meter.
Old 08-24-09, 12:47 PM   #9 (permalink)
yea i thought about that myself. i felt like an idiot when i realized i had just thrown away $150 and waisted so much time...
Old 08-24-09, 12:50 PM   #10 (permalink)
i kinda have a feeling that it has something to do with air flow now like maybe it has too much air flow or when we took the air flow sensor off and cleaned it we may have messed something up
Old 08-24-09, 07:09 PM   #11 (permalink)
KLF
KLF's Avatar
How exactly did you "clean" it?
Try the paperclip thing I mentioned earlier, see if it starts and stays running.
KB1OSF
'98 Lexus ES300
Old 08-24-09, 10:18 PM   #12 (permalink)
yea i done the paper clip thing today, it gave me a code 51. then before i done anything else i replaced my fuel filter. it helped alot. it will keep a good idle for about 30 seconds now but still dies. then i done the paper clip thing again, it gave me four codes, 21, 41, 51, and 52. they all point to the tps (throttle position sensor) except one that read the O2 sensor. so i bought a new tps and it didnt help so i took it back. now im lost again.. oh and to clean it we spayed throttle body cleaner in it from the bottom into the area with the metal valve/flap under the air flow sensor and wiped it down real good. then we took the two screws out of the front of the air flow sensor and slide the plug part out to make sure it hadnt gotten wet and it didnt look like it had so we put it back together.
Old 08-24-09, 10:25 PM   #13 (permalink)
Oh nevermind......
TLCA# 13872
You need to adjust the TPS, not replace it. Check the FAQ for instructions.
Old 08-24-09, 10:31 PM   #14 (permalink)
well when i checked it, the bottom screw on it was loose and it looked like it had gotten wet inside. im thinking i may have shorted out the mass air flow sensor though. any way to check this?
Old 08-24-09, 10:40 PM   #15 (permalink)
Oh nevermind......
TLCA# 13872
Check the FAQ for the FSM's I'm sure there's something in there about checking the MAF... Fingers crossed!
Old 08-24-09, 10:44 PM   #16 (permalink)
yea. same here. thanks.
Old 08-25-09, 08:59 AM   #17 (permalink)
http://personal.utulsa.edu/~nathan-b...93throttle.pdf
thats the throttle body pages. start at about pg6 and it talks all about adjusting the TPS. good luck.
ballinjefe22 is offline   Reply With Quote
Old 08-25-09, 10:10 AM   #18 (permalink)
KLF
KLF's Avatar
No, I meant the trick where you jumper pins B+ and Fp, to force the fuel pump to run.
... and slide the plug part out to make sure it hadnt gotten wet and it didnt look like it had so we put it back together.
Uh... I think this is your problem. Pulling that plug out breaks stuff inside the MAF sensor part, the section under that black square of plastic. Specifically, it messes up the contact that tells the ECU to turn on the fuel pump when the engine is running.
KB1OSF
'98 Lexus ES300
Old 08-25-09, 01:41 PM   #19 (permalink)
well we pulled it out gently then put it back together the same way..
Old 08-25-09, 01:51 PM   #20 (permalink)
KLF
KLF's Avatar
I don't think you understand. You can't move that connector AT ALL without potentially damaging the contacts inside.
KB1OSF
'98 Lexus ES300
Old 08-26-09, 05:12 PM   #21 (permalink)
so, you think i f***ed it up?
Old 08-28-09, 07:47 PM   #22 (permalink)
the truck doctor's Avatar
Hey chris Ill see if I can find a MAF senser you can use, maybe this will work.
Heart Of Dixie Offroad Club
The truck doctor
1989 excab 33" procomps, E-locker
SAS'D 1987 excab 5:29's welded f/r,flatbed,37"s 9.5xp wireless
the truck doctor is offline   Reply With Quote
Old 08-28-09, 08:47 PM   #23 (permalink)
KLF
KLF's Avatar
I would try to find another one and swap it on, see if that fixes it. You can take a sharp knife and cut thru that bead of sealant around that black plastic square, peel it open and see if you can find anything wrong.
KB1OSF
'98 Lexus ES300
Old 08-29-09, 07:29 PM   #24 (permalink)
ok. thanks man. just let me know..
Old 08-29-09, 07:30 PM   #25 (permalink)
yea we done that and everything apeared to be fine. but then again, i didnt really know what to look for
Old 08-30-09, 09:58 PM   #26 (permalink)
Bako88's Avatar
You need to be very careful about taking the top off the MAF. There are warnings that if you re-seal it, the fumes can damage the inside. Also, do not use fluid if cleaning inside the throttle body as fluid can get into the TPS and ruin it as well.
1988 Toyota Pickup - Stock - 22RE 5 Speed 4x4
http://www.thefoat.com/images/foat_follow_me.gifbako88
Bako88 is offline   Reply With Quote
Old 09-01-09, 11:07 PM   #27 (permalink)
ok, just an update. i looked closer under that plastic on my MAF sensor and aparently the guy that took the plug part out to "check it" broke a solder on one of the connections. so i relaced the MAF sensor and now it will idle for as long as i want it to. however, i cant really rev it up right now. it sounds fine to me at an idle but when trying to rev it up it starts missing then backfiring a little through the air filter and blows black smoke out of the tail pipe. my guess is, it isnt firing on one of my cylinders. guess thats where im gonna start tomorrow.. any ideas?
Old 09-02-09, 05:58 AM   #28 (permalink)
KLF
KLF's Avatar
That sounds like a timing problem to me. Try loosening the dist bolt and turning it a little bit, see if it gets better.
KB1OSF
'98 Lexus ES300
LinkBack to this Thread: http://forum.ih8mud.com/79-95-toyota-truck-tech/305765-89-toyota-pickup-4x4-wont-stay-running.html
Posted By For Type Date
79-95 Toyota Truck Tech on IH8MUD.com Forum - The Truth is in the Rocks | BoardReader This thread Refback 09-05-09 03:30 AM
89 toyota 4runner Blogs This thread Refback 08-24-09 02:11 PM
