Crank pulley rubbing Oil Pump timing tab - help!
Hello,
I replaced the timing chain on my 85 Pickup 4x4 (22R), and after I put everything back together and started it, the crank pulley is now rubbing the timing mark tab on one side. It almost seems like the oil pump is on crooked....but I loosened the pump bolts and there is no play in it. I spoke to Tod at engnblder and he suggested that there might be something wrong with the harmonic balancer....has anyone ever replaced this? I think he may be right, as I can't find any other reason this might happen.
The truck was running, and this was not a problem before I took it apart. I reused the timing cover, oil pump, and water pump. Truck has about 270,000 miles, with about 30,000 on a rebuild (receipts from the PO).
I would appreciate any help or advice....thanks for reading this!
Chris
Chris
'75 FJ40
'85 Truck 4x4
