Old 05-14-09, 07:43 AM   #1 (permalink)
meatloaf's Avatar
Idle Question
noticed this morning (in stop and go traffic) that my 92 22re truck idles back and forth between 900-1000 rpms. When I got to work I aslo noticed it that it would do it when I would step on the brake. When I release the brake, idle goes up and then stabilizes.
What could it be? the TPS?
Thanks for the help,
Luis
83 FJ60
92 4X4 x-tra cab 22RE
Meatloaf®
meatloaf is online now   Reply With Quote
Old 05-14-09, 07:47 AM   #2 (permalink)
toy4xfun's Avatar
Not sure could be vacume booster behind your master cylinder
toy4xfun is offline   Reply With Quote
Old 05-14-09, 09:15 AM   #3 (permalink)
Jukelemon's Avatar
Before you do anything, pull the intake hose off the Throttle Body, get a can of carb cleaner and a toothbrush and clean the hell out of the intake/butterfly valve/and idle circuit port.
If you have not done this yet to this truck, it is likely to be VERY corroded.
You will need a lot of paper towels and a set of rubber gloves. You will be surprised how dirty it will be.
Should take about 30 total minutes. See what happens. You may have to decrease your idle speed after IF someone has just increased idle speed to compesate what is actually a idle flow issue due to a clogged port in the throttle body.
"May you be in heaven a half an hour before the devil knows you're dead"
1992 4x4 PU
Jukelemon is offline   Reply With Quote
Old 05-14-09, 10:45 AM   #4 (permalink)
meatloaf's Avatar
Thanks J-lemon,
I actually pulled off the whole throttle body about 3 weeks ago and cleaned it to "like new" condition... I did mess with an idle screw on top of the TB yesterday because it was idling low...hmmm, maybe I messed it up. I do not drive this truck too much so I had not noticed this problem.
Luis
83 FJ60
Meatloaf®
Old 05-14-09, 11:46 AM   #5 (permalink)
Jukelemon's Avatar
OK. Then it is more than likely not it.
Does it fluctuate without the brake being depressed i.e. just in Neutral/flat surface?
1992 4x4 PU
Old 05-14-09, 04:14 PM   #6 (permalink)
GRM
Profesional at Something
GRM's Avatar
TLCA# 16721
Heres what your problem is:
The 22re has a system, where it cuts out the fuel injectors when you hit the brakes. This helps you save fuel. When the idle is too high, they system keeps cycling between the low rmp, and what you set your idle speed at.
Solution: Turn down your idle.
GRM is offline   Reply With Quote
Old 05-15-09, 08:13 PM   #7 (permalink)
raydouble's Avatar
Yep, make sure Idle speed and timing are right on, should disappear in a flash.
Originally Posted by decavo View Post
he got a new blue ray of a Johnny Depp movie and is in a 646 coma
90' Pickup reg cab 22RE-W56-LCE dual chain conversion-tr*il gear slides-31' BFG MT-15x8 Allied rockcrawlers-SAW torsion bars-Rancho & Bilstein shocks-97' taco front bumper-custom 6 leaf rear
01' 4Skinner SR5 5VZFE 4x4 all stock
Web Wheeler Wizard-Level 21
raydouble is offline   Reply With Quote
Old 05-15-09, 10:04 PM   #8 (permalink)
meatloaf's Avatar
Problem fixed! Turned idle down and problem disappeared...
Thank you all!
Meatloaf
83 FJ60
Meatloaf®
Old 05-20-09, 10:53 AM   #9 (permalink)
Freeman's Avatar
thats good info to know. thanks. now to my piece. glad you got your fixed.
65' FST....without the FST
“Lincoln: The Man, The President, The Town Car”
Freeman is offline   Reply With Quote
