Well I needed a 2nd t-case tp put my doubler in so I went and bought a slightly rolled 86 4runner for for $500. I swapped in the 22re/ w56 and t-case along with my old one. Sold my old motor, tranny, and other parts off the 4runner to make a pretty good profit. The took it out a few more times before the big transformation.
motor
flat belly with doubler
I sold a set of 1 ton axles to purchase a 92 FJ80 off the board, the traded a set of 44s for a set of 39s. Now we get to the meat and potatoes of the build....the suspension and axle swap.
My goal was cheap. I used every part off the FJ80 that I thought I could possible use and parted out the rest....which financed 80% of my build.
I started with the rear suspension. I used the factory FJ80 5 link, but used Factory lower links as both my Upper and lower links....lowers got a 2inch rib welded to the top. I then raised the factory panhard about 6 inchedand used the factory springs all the way around.
testing rear for bind.
I was really hoping to keep the taillights I worked so hard to keep....more on that later.
The rear went together quickly and I started on the front. I used the Rear Slee CV shaft that I got with the FJ80 as my front drive shaft. Instead of paying to have the shaft cut down I just pushed the axle that far forward. which gave me a pretty good approach angle.
Again I used the factory FJ80 Radius arms and springs up front.
It was about his point in the build that I got Bell's Palsy. I pretty much stopped working on the truck for 4 months because I didn't want to risk something damaging my eye.
