Old 11-08-04, 03:17 PM   #1
Lor
Front main seal replacement on 22RE
I didn't find anything on the tech link and search.
Do I need to take the chain off (I believe this engine is chain driven) to replace the front seal? I got oil flying everywhere in the front. I have done work on belt driven, but not chain. It looks like all I need to do is taking off the pully. Could someone confirm or give me some directions, tips etc. Thank you.
Lor is offline   Reply With Quote
Old 11-08-04, 05:23 PM   #2
bkg
Remove pulley and oil pump - that should be it. No need to remove t-chain.
Brian K. Gallus
bkg is offline   Reply With Quote
Old 11-09-04, 10:08 AM   #3
Lor
Thanks.
Old 11-09-04, 11:44 PM   #4
hammerhead's Avatar
It can be done by just removing the pulley if you have a hook type seal puller like used for a motorcycle fork seal and a driver big enough to install the new seal. Otherwise do like bkg said and pull the pump off.
utah4x4club.com
U4WDA
hammerhead is offline   Reply With Quote
Old 11-23-04, 07:53 AM   #5
toyrunner's Avatar
TLCA# 7031
Thanks.
To break the bolt loose, prop the breaker bar against the framerail. Pull the coil wire and give it a bump.
I always use a screwdriver very carefully to pry the seal away. A socket will drive the new one home.
Easy twenty minute job.
Danny
toyrunner is offline   Reply With Quote
0 Credit Cards | Credit | Credit Cards UK | Fast Loans | Personal Loans
