11-21-08, 11:53 PM
LIFT
Whats the cheapest and easiest way to fit 33 on a 94. I just want to get the tires on for winter. this spring Im doing an solid axle swap..Cant  ing wait!!!!
11-21-08, 11:56 PM
Im trying to stay away from the torson bars iv already broke one.
11-22-08, 07:16 AM
Tartu hetkeen
for a soon-to-be SA swap id go Body lift- Cheap and removable when you do the SA swap
Crusified:
You don't "lock" a Toyota's hubs, you "Call down the Demons".
11-22-08, 07:57 AM
You could do something like Roger Brown's ball joint spacers:
Toyota 2WD/4WD IFS Front Ball Joint Spacers for Pickup, 4Runner and T100
Then also get one of his body lifts, pound the fendr seam flat in the front. Longer shackles in the back.
Spending money on lifting the IFS when you're just gonna hack it all back off is a huge waste.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
11-22-08, 08:47 AM
$150 for a 2" body lift I think is worth it. Don't know what kind of axle your swaping but I got 4" wrangler springs with the 2" BL on an 85' Axle, and I can fit 38's easy.
11-23-08, 04:16 PM
my truck has had a "temporary" (until i SAS it) lift for several years now. I pounded the seam and threw on a 1" body lift and 33" tires fit just fine. http://forum.ih8mud.com/attachment.p...3&d=1212047290
Doug
-94 22re mini (except for bumpers, sliders, skidplates, rear locker, 1" body lift w/trimmed fenders and 33" tires.
-93 fzj80 ROTW douglashuft
-fj62 replaced by the fzj80
11-24-08, 03:15 PM
I think ill go with the body lift. Ive got a 2inch bdy lift off a ford will that work if i get the steering bar??
11-25-08, 03:55 PM
You'll also have to re-locate the radiator, the fuel fill hose needs to be longer, and be careful not to overstretch the brake & clutch lines, as well as all the electrical stuff. The bumpers will look funny too.
KB1OSF
'98 Lexus ES300
11-25-08, 05:59 PM
unless you stick to a 1" lift. I adjusted the radiator with a homemade bracket but even that could have been avoided by removing the bottom of the shroud. A tacoma bumper piece will fill the gap between the body and front bumper.
Doug
11-25-08, 09:07 PM
#10 (permalink)
Yes, I have a home-brew 1" BL on mine, mostly to make mounting the sliders easier. I started by removing the bottom piece off the shroud, but then I lifted my engine an inch and had Bud bend me up a crossmember that also lifted the tranny an inch. The rest was really easy, no other issues.
KB1OSF
'98 Lexus ES300
11-25-08, 10:41 PM
#11 (permalink)
Rookie
do a three inch body lift cause then you can just bend in the front bumper brackets and mount them on two wholes instead of all four. The radiator also can be mounted then out of two wholes that already exist. I did that two my old 88 and it worked but the radiator only being held in buy two screws could cause some problems but it never did for me
12-01-08, 01:40 PM
#12 (permalink)
i vote for $5.00 worth of sawzall blades....
-Jason
'85 4Runner- Geared, locked, bobbed, tired, fun.
'97 LX 450- It's a little wet right now. Still big.
'94 Xtra Cab P/U - 5.29s & Detroits F/R, SAS, Marlin Hysteer, 30 spline Longfield birfs and axleshafts, chromo hub gears, dual cases (2.28/4.7) w/ 10* rotated adapter, FROR dual rotated case xmember/skid, 12 " Bob, 37" MT/Rs
"I got the J==p thing, and now it burns when I pee."
12-01-08, 05:51 PM
#13 (permalink)
12-01-08, 10:36 PM
#14 (permalink)
um 33's fit fine no body lift, nothin. all you gotta do is crank the t-bars down. and a cheap flexy rear set up would be a set of 63" chevy springs in the rear with custom mounts. then all you gotta get is some shocks for the rear and you can pretty much name your price on that stuff.
-Nate
88 PU long bed, pro comp 35s
All Pro rear suspension
Custom SAS
Toyota e-locker(R),aussie(F)
4/88's
And a whole lot of dents contributed by new england's natural flora and fauna (mostly responsible is one species of flora... pine) (and the elusive new england delivery truck)
12-02-08, 12:22 AM
#15 (permalink)
I have to say that 33" tires rubbed too much with a mildly cranked t bar and rear springs. It was definitely necessary to trim the rear of the front fenders and the front of the rear fenders along with a trimmed front rocker panel/pounded seam and 1" body lift and 1" rear bump stop extension. This was necessary for 33"/12.5 Goodyear mtr's on 8" rockcrawler rims with 3.75 backspacing. A narrower tire or closer to stock backspacing might tuck in better and require less trimming but might also interfere with the idler arm brace (which if you are running this size tire with ifs in the rocks you need the brace).
Doug
