09-15-08, 08:45 PM
#1 | | 250+ Club
| 22re check engine light.? I have a 1992 toyota pickup with a 22re. I have a check engine light on. I was told to jump the T1 and TE1 jumpers to read the code. There is no T1.
Can anyone tell me what the correct jumpers are?
Thanks.
__________________ 1997 Landcruiser Collectors Edition 242k miles & counting (mine)
2008 Highlander 134K miles & counting (wifes)
Sold. 1992 FJ80 212k miles (used to be mine)
Sold. 1987 4Runner 240k miles (used to be mine)
Sold. 1994 Corolla Wagon 320k miles (used to be mine) |
09-15-08, 08:51 PM
#2 | | Lifer
Join Date: Sep 2005 Location: The NW, Cascade Mountian Range
| its e1 and te1.
__________________ Wristy Quote:
Originally Posted by cruiser88 Jebus... | I AM THE 22RE GOD
22RE Tech hotline- check the FAQ  |
09-15-08, 08:53 PM
#3 | | Lifer
09-15-08, 08:53 PM
#4 | | 250+ Club
| Quote:
Originally Posted by WristPin its e1 and te1. | Thanks....
I will recheck tomorrow.
09-15-08, 08:57 PM
#5 | | Frame waxer
| Maybe this will help, sorry all my manuals are packed up: Off-Road.Com - Toyota Tech - Diagnostic Trouble Codes
__________________ KB1OSF
'87 Toyota xcab SR5 - SAS'd, e-lockers, stuff (22RE/R151F/4.7's) - currently undergoing frame-off restore
'05 Lexus ES330 - Nav/ML/17's
'04 Toyota Highlander |
09-15-08, 09:22 PM
#6 | | 250+ Club
| Quote:
Originally Posted by WristPin | Quote:
Originally Posted by KLF | This will definitely be helpful.
Thanks a million and one!
09-16-08, 07:52 PM
#7 | | 250+ Club
| Code: 21 So I get a code 21. 21 OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER SIGNAL OPEN OR SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR SIGNAL
What does that mean?
Bad O2 sensor?
09-16-08, 08:38 PM
#8 | | Addict
| Quote:
Bad O2 sensor? |
....if I was a betting man....
IIRC a lot of codes have a, "short circuit in terminal "T" when ac switch ON or IDL point off."
and if that's the case the throttle body needs to be checked.
you don't have have so I'd bet it's isolated to the O2 sensor.
09-16-08, 10:34 PM
#9 | | Lifer
| replace it with a NTK or bosch brand O2 sensor only.
09-17-08, 05:09 AM
#10 | | 250+ Club
| Cool. Atleast we're getting somewhere......hopefully.
I'll try the O2 sensor and see how that goes.
09-17-08, 06:12 AM
#11 | | photosynthesizing
Join Date: Oct 2003 Location: Palm trees and cool streams
| Quote:
Originally Posted by WristPin replace it with a NTK or bosch brand O2 sensor only. | I will toss in Denso (OEM) too. You might be able to pick up a Denso at oxygensensors.com. They have them for many applications.
NTK is good. My luck with Bosch has not been good.
aka Bushrat 1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB. 1985 4Runner: lifted, locked, Tim@DOA 22RE, 33" training wheels, R151F with dual 23-spline TCs.
"EFI Jon, EFI." - Juane |
09-17-08, 05:25 PM
#12 | | Lifer
| i have used bosch in almost all the cars and trucks i work on. only time they dont werk is if i use the universal one and mix up the heater and sensor wires....
but you are right pappy NTK is better anyway. same with denso. gotta go with the high quality jap stuff anyway
09-17-08, 08:16 PM
#13 | | 250+ Club
| I went to the local auto store today, and they couldn't find an O2 sensor in stock. They said they'd have to special order it. It was a bosch. I was shocked! Olreily's auto didn't carry it. These things are not cheap...LOL.
I'm curious, this might be a dumb question,,,,but would this potentially take care of my bogging and slow acceleration issue?
09-18-08, 05:06 AM
#14 | | photosynthesizing
| Quote:
Originally Posted by lispeej I'm curious, this might be a dumb question,,,,but would this potentially take care of my bogging and slow acceleration issue? | It could. I've also had failed OX sensors cause a rough, erratic idle. It should also improve your gas mileage.
09-18-08, 05:09 AM
#15 | | 250+ Club
| hmmmm.
