Old 09-06-08, 06:33 PM   #1 (permalink)
Conewashers on manual hubs
I just bought my first truck! A 1990 4wd pickup with the V6. I'm working on replacing the front CV shafts. My question is how do I get the conewashers out. I've just been taking it slow, I didn't want to start hammering on anything, I have an older BMW that i've done lots of work on but 4wd is brand new to me. Thanks.
Mpowered1 is offline   Reply With Quote
Old 09-06-08, 07:36 PM   #2 (permalink)
I like taking a small regular skrew driver and inserting it in the slot at an extreme angle. Then tapping on it to spin the washer. A couple of taps gets them out for me. And damage free.
NOTE: Don't hit it "in" it. Hit it to "spin" it.
A visitor from the past
Hilux is offline   Reply With Quote
Old 09-06-08, 07:42 PM   #3 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
Second method.
Get small brass hammer. Back off nut, but leave it on the stud (assuming open nuts, acorns need to be removed). Place brass hammer on stud, holding onto the handle. Give the brass hammer a whack with a 2lb hammer. Might take a few blows. Nut should be on the stud to keep the cone washer from flying across the garage floor. Brass hammer will keep the stud from getting boogered.
You can also tap on the hub body like the cheapy brake shops do, but I guarantee you will dent the body. Cosmetically bad? Yes. But it can also deform the body enough to where the gasket will not seal.
aka Bushrat
1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB ... assembled!
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
"EFI Jon, EFI." - Juane
pappy is offline   Reply With Quote
Old 09-06-08, 08:57 PM   #4 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
Welcome to Mud!!! Glad to have you..... we're gonna need to see some pics!
Old 09-06-08, 08:57 PM   #5 (permalink)
Tartu hetkeen
liljlandon's Avatar
Garage
Third method:
If you are skilled in the ways of cheapo depo pliers, you take thoes and apply just enough pressure to get the lip of the washer and pull. Simple and easy. Pappy's way is easy to. Hilux's way Ive never tried but then again, check the chit chat thread to fully understand hilux.
Crusified:
You don't "lock" a Toyota's hubs, you "Call down the Demons".
liljlandon is offline   Reply With Quote
Old 09-06-08, 10:50 PM   #6 (permalink)
raydouble's Avatar
The brass hammer or punch method is most effective IMO.
Welcome x2 on the pics.
Originally Posted by decavo View Post
he got a new blue ray of a Johnny Depp movie and is in a 646 coma
90' Pickup reg cab 22RE-W56-LCE dual chain conversion-tr*il gear slides-31' BFG MT-15x8 Allied rockcrawlers-SAW torsion bars-Rancho & Bilstein shocks-97' taco front bumper-custom 6 leaf rear
01' 4Skinner SR5 5VZFE 4x4 all stock
Web Wheeler Wizard-Level 21
raydouble is offline   Reply With Quote
Old 09-08-08, 02:43 PM   #7 (permalink)
Supporting Vendor
Isotel's Avatar
TLCA# 16898
i like the Brass drift method, but if you dont have one, just hit the metal hub body, and not the Aluminum lockout hub and you will be fine!
use anti seize to ensure they are easier to come off the next time
1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINE
Colorado Land Cruisers -=- CrAwLoRadO.com
Redline Land Cruisers - PM me for info on our products or to order!
Old 09-08-08, 04:52 PM   #8 (permalink)
toyminator's Avatar
TLCA# 17965
Brass drift and a hammer. put it right on the end of the threaded stud and tap it a few times. The cone washer should pop out. Heck in a pinch you can use a chunk of aluminum to do it. As long as the alloy is softer than the stud it won't damage the threads.
1989 Toyota Pickup - 255,xxx miles, SAS, Bed Bobbed 14", 95 4Runner front clip, Hanemman Fiberglass front fenders, All Pro 5.5" lift, Hi Steer, 5.29 gear rear Detroit locker, front ARB locker.
1988 4Runner - Blown up 3.0 V6
1999 4Runner SR5 Sport Edition
1992 Lexus SC400
toyminator is offline   Reply With Quote
Old 09-08-08, 10:18 PM   #9 (permalink)
ok, you have gotten alot of good advice.. spray them also, like wd40 ect..
but really this shows why there are cone washers. they are awsome for holding power. if you have a rubber hammer or one those yellow, red hammers.. the plastic ones beat the sh1t out of it. some times you can use a small straight screwdriver and get them to turn..
missouriman is offline   Reply With Quote
Old 09-08-08, 10:33 PM   #10 (permalink)
X2.
Just buy a brass drift if you don't have one. You need it to remove the wheel bearing races anyway when you replace the wheel bearings. And you will want to use it every time you remove cone washers.
Back the nut out to the end of the stud, and place the brass drift on the end of the stud and give it several good hits with a big ballpeen hammer. The impact causes the cone washer to back out. Keep the drift and hammer with your trail tools.
JonB ke6gfb
87 bj70, turboed, 35'ed, arb'ed, slidered, winched, 4x4llabs rear bumper & arb front, HF'ed & VHF'ed.
97 40th fzj80 w/difflocks, cdl switch & pin 7 mod, Hanna sliders, 2.5" ome lift, 1" body lift, rear drawer system on 285/75-16's.
87 sas 4runner- air lockers, dual cases, beadlocked 35" mtr's, waggy & cheby springs, sliders, 8274 winch, etc...sold to build a heep.
jonb96150 is offline   Reply With Quote
