Old 10-07-04, 12:28 PM   #1
Independent Suspension Help
Does anyone know of any shortcuts to a suspension lift with independent suspension?
"He's half an idiot,....and that is the good half!"
Steve_925 is offline   Reply With Quote
Old 10-07-04, 03:52 PM   #2
Ride On...
lowtideride's Avatar
TLCA# 14891
drive it into tommys 45 then insure it, say it was TJDIV's fault and get a cruiser.
www.NFCruiserheads.org 1983 SR5 Hilux...
has had no peers for 50 years...
lowtideride is offline   Reply With Quote
Old 10-07-04, 04:11 PM   #3
cruiserrg's Avatar
Cut it out and replace it with a solid axle. Lifting IFS is not worth the time or money.
Reuben Gosewisch AKA: cruiserrg
http://webpages.charter.net/cruiserrg
Pics of my Tree Stand or otherwise known as my Tube Chassis rockcrawler project: http://webpages.charter.net/cruiserr.../toypuproject/
cruiserrg is offline   Reply With Quote
Old 10-07-04, 04:38 PM   #4
the shed guy's Avatar
What type of IFS, on what truck, and to do what?
This set up looks like it works ok.
Darren M.
"There's a gigantic grey area between good moral behaviour and outright felonious activities. I call that the Weasel Zone and it's where most of life happens." -Scott Adams
02 KZJ95TDI 285 MTRs ARB Secondairs Engel Shower GPS
the shed guy is offline   Reply With Quote
Old 10-08-04, 05:06 AM   #5
Admin
woody's Avatar
TLCA# 1548
question is, what are you trying to do?
IFS articulates terribly, but rides well and does nicely on highspeed stuff.
Brian 'woody' Swearingen
Old 10-11-04, 05:30 PM   #6
I want more clearance/ bigger tires on my '93 Pathfinder.
Old 10-11-04, 06:44 PM   #7
Ramblin Wreck
CruisinGA's Avatar
Cranking torsion bars is the only way. Make sure you know how to correct camber, otherwise you'll be wearing out half of your front tires very quickly.
On chevy 1/2 ton (maybe 3/4 too) you can swap the chevy torsion keys/cams out with Ford ones, the ford ones naturally have more "twist" in them, it is basically a method of tweaking the torsion bars even further.
Unless you just want to run something like 33's it will get very cost-prohibitive to "improve" your IFS.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'97 FZJ80
'98 UZJ100-OEM RR locker
ΣΧ
CruisinGA is offline   Reply With Quote
Old 10-11-04, 08:02 PM   #8
Admin
woody's Avatar
TLCA# 1548
93 PF outta fit 31's stock, 32's barely, and 33's with some hammering...try 33x10.5 tires and let us know what happens..
Old 10-12-04, 12:25 AM   #9
LT
Metal Tech
LT's Avatar
TLCA# 12989
IFS = It Fuking Sucks
Propane Powered 2f.
LT is offline   Reply With Quote
Old 10-12-04, 06:41 AM   #10
DUM8HIT
T Y L E R's Avatar
My '93 4Runner was IFS ... I installed a Trailmater 4" lift . I eventually ran 35's with that setup .. minimum rubbing . I remember seeing a pathfinder in the catalogue at the time with 33's and one of their lifts . Looked pretty good too .
TY
PS : Sell it though and get into an 80 dude
Hybrid suspension - Slee 4" Front/OME863 Rear, Slee Front control arms, Slee DIY adjustable panhards, Slee sliders, 36X13.5R16 IROK radials on AR Black Trenches, 1.5" Trail-Gear spacers, Toughbook CF74 with GPS etc, sans roofrack, jumpseats, lockers. Clear lenses abound
T Y L E R is offline   Reply With Quote
Old 10-12-04, 12:39 PM   #11
Isotel's Avatar
TLCA# 16898
if you want the look of a lifted truck do a body lift.. 100 bucks and you will clear 33's on the pathgrinder.. I just put a 3" Body lift on an 89 pathfinder for a freind..
I know the newer Pathfinders were unibody, so you cant body lift it at all.. and unibodys tend to break apart after a couple years of wheeling them hard..
If you want to go play with the big boys, Solid axel is needed..
1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINE
Colorado Land Cruisers - Club
Redline Land Cruisers - Safety First
CrAwLoRadO.com - Just Check it out
Isotel is online now   Reply With Quote
Old 10-12-04, 01:24 PM   #12
VZLAFZJ80's Avatar
My friend has a frontier, not the same truck but similar. He was running 33” tires with a 3” suspension lift and 3” body lift with no rubbing at all. He got tired of having problems and braking stuff because of the IFS and tomorrow we are going to start a solid axel swap. He is going to run a Dana 44 and wrangler leaf springs with a shackle reversal. Apparently this setup has work well for others and he would be able to run 36” tires no problem!
You can also check out
http://www.calmini.com/
93 FZJ80, Part time 4wd, 5 spd. - M15000 ,front and rear ARBs, 37" MTRs,Safari Snorkel, custom bullbar, sidebars, roofrack,exo-cage....etc..etc..etc.. and soon Stazworks beadlocks!
VZLAFZJ80 is offline   Reply With Quote
Old 10-14-04, 10:21 PM   #13
[quote=isotel]if you want the look of a lifted truck do a body lift.. 100 bucks and you will clear 33's on the pathgrinder.. I just put a 3" Body lift on an 89 pathfinder for a freind..
I know the newer Pathfinders were unibody, so you cant body lift it at all.. and unibodys tend to break apart after a couple years of wheeling them hard..QUOTE]
I would rather have the clearance than the "look", but right now I just want it to stop rubbing!
The '89 is the same body style as my '93. How hard or easy was the body lift?
Old 10-14-04, 11:43 PM   #14
Tools R Us's Avatar
http://nissan4wheelers.com/eve
Copper State Cruisers #007
Old 10-16-04, 09:14 AM   #15
fj40charles's Avatar
EXACTLY!
I'm sure the shed guy will chime in here and say we all don't "know" about IFS.....
69 FJ40 with some minor mods...
2000 Cummins powered Dodge with some power enhancements.
DO NOT SUPPORT TRAIL GEAR!!!!! bad ethics = bad business!
http://www.paypalsucks.com
fj40charles is offline   Reply With Quote
Old 10-16-04, 06:42 PM   #16
Originally Posted by fj40charles
EXACTLY!
Wwell, not everyone, but your the only one who has proved you dont, so far
Darren M.
Old 10-16-04, 07:58 PM   #17
You've proven to me that you don't know sh!t about suspension based on youur comments about IFS.
If you're convinced the IFS is the way to go, why stop at this web site? I would sugggest you go an preach the IFS gospel on www.pirate4x4.com. There will be many others besides myself who think IFS is just POS.
Old 10-16-04, 08:08 PM   #18
Hey Sheddy,
I did a search on POR and saw that you've posted 5 times. None of these posts were
about IFS or any type of suspension.
Why limit your expertise here on ih8mud???? You should show the world just how much you know about IFS by posting in the General 4x4 section. I'm sure you'll get plenty of
opinions there.
http://www.pirate4x4.com/forum/searc...earchid=441802
Old 10-17-04, 04:30 AM   #19
Didnt I just read this somewhere else,....
I would of thought you would of been open minded enough to try and understand something currently out of your grasp, but it would appear you simply want to express the same views as elsewhere, and you simply want the conversation to go there, because you dont feel confident enough to hold your own here
Anyway, enough of this discussion, my sig line says enough for me
Darren M.
Old 10-17-04, 08:04 AM   #20
Since you seem to think the next big thing in suspension is IFS, I think the rest of world should know. How come you don't want to share your vast knowledge with other like me who don't know as much about IFS as you? Why limit yourself sheddy?
What makes you think this is, "something out of your grasp" sheddy? I don't even know you and you think you know who I am? I used to have an IFS truck. I bet you didn't know that sheddy?
Quit hiding behind this web site and share you vast knowledge of IFS on www.pirate4x4.com. I know you have an user account and have posted 5 times, but none of the posts are about IFS.
Are you afraid of getting different opinions and not being able to hold your ground?????
Old 10-17-04, 10:16 AM   #21
cruiserrg's Avatar
Thought I would add my thoughts to the IFS debate you folks seem to be having. First the pic above of the desert racer is application specific and works well in that enviroment, but not as well in rockcrawling.
IFS in stock form (or even in that desert racing form) doesn't lend itself well in highly articluated situations. Its because of the design the traction is less in high articluation as the arms try to keep the tire in its camber. IFS would do well in straight or v climbs tho, but not substantially better than solid axle.
Do I think that IFS could do well in rockcrawling...Maybe in some situations, but not in others as noted in my comments. I have had thoughts of trying to address the concern with being able to change camber live and may someday play with that.
You may see more IFS in the future as rockcawlers try to lower CG and the axles start preventing that, but it will take a highly modifies arm system to be effective.
Old 10-17-04, 05:02 PM   #22
Good points on the IFS, and though i agree the relevance of the type of use, I havent seen anywhere where the "specific" use has been stated here
Simply something was wanted 'outside the square" so to speak, hence I attached a pic of Walker Evans vehicle, which was a little outside the square, and lacked development time [Walkers own words] and he was keen to go IFS on the next truck as well, and develop it over a longer period.
Anyone can copy a design that works, not many can create something that does.
Darren M.
Old 10-18-04, 07:08 AM   #23
cruiserrg's Avatar
One note, Walkers new rig is a moon buggy (rear engine) with solid axles front and rear. So did not pursue IFS/IRS any further.
Old 10-18-04, 10:47 AM   #24
cruiserrg's Avatar
Please bring the IFS debate here: http://forum.ih8mud.com/showthread.p...531#post246531
Old 10-18-04, 07:31 PM   #25
And I guess, in what he designed, its a little difficult to measure how worse, if any the IFS was, and how that translates to what the average person uses, whilst developing on the fly.
But just the fact they were looking at it, says it cant be all bad, just not developed enough to be in the top 10 in one small part of a motor sport catagory.
Darren M.
Old 10-18-04, 10:59 PM   #26
Wow, I was only looking for a shortcut!
Sorry, didn't mean to stir the fire up that much.
Old 10-19-04, 05:29 AM   #27
Relax Steve, some go looking for a topic that will do that, some go looking for a topic that has that, and some just post what they think
Darren M.
