Old 06-29-08, 04:32 PM   #1
CookieJR's Avatar
HELP front differential problems from cookie
So i was driving a while back and my 4by started to clank and every were i drove in 4wheel was like a roller coaster clanking up hills etc, and when i made sharp turns it would make violent clanking noises and you could feel the truck lunge forward stop then go again in a pattern. SO i was camping and i went to rip out a stump driving up a hill and the 4by stopped working and is making ugly noises from the front differential is it a crown gear? what should i do? buy new gears? Sas it? were can i get a good deal on a solid axle,/ swap kit ? thanks!
ROLLED AND TOTALED 1995 SR5 PU, EC, v6, 5 spd, 4' Pro Comp susp lift, 33x12.50 Interco MT's, 15' alloys, K&N cold air intake, PC skid plate, sirious sat, VHF radio, (2) kicker ds400 4'', (2) mtx 4/6's, panasonic deck, fosgate10' sub, 500w fosgate amp.
CookieJR is offline   Reply With Quote
Old 06-29-08, 04:35 PM   #2
WristPin's Avatar
what year?
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Originally Posted by Rezkid View Post
ridin quads and blastin' mofers...life don't get much better than that
Originally Posted by chesshircat View Post
Found my Haynes manual, shoved it under the leg of my bench to level it out.
Old 06-29-08, 04:45 PM   #3
CookieJR's Avatar
1995 toyota sr5 pickup in my description ty
Old 06-29-08, 05:04 PM   #4
WristPin's Avatar
OK, just checkin
first isolate the trouble area. check out your CV axles. when the hub is unlocked, do they turn easy? does the hub engauge well?
if the axles are jacked they may not spin smooth. but it could also be the ring and pinion. rive with one and then the other hub locked. see if this points to the problem. finally, drain the fluid from the diff, and look for critters.
you can take off the front cover of the diff to see if its jacked.
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Old 06-29-08, 06:25 PM   #5
No longer pre-approved...
2ndGenToyotaFan's Avatar
Sounds like the diff.... but do what Wrist pin said... You can probably find a new front diff for not too much money.... People throw them away after SAS's....
Old 06-29-08, 06:27 PM   #6
KLF
KLF's Avatar
Ya, it's either a blown CV shaft, or you munched the gears in the diff.
You can probably get either parts for cheap from someone locally doing a SAS, but IMO the IFS setup is not worth spending a nickel on. Do yourself a favor and start looking for a front axle now. Search, here and the web, there are tons of SAS kits out there to choose from.
edit: oh crap, read your sig, looks like you paid to have 4.88's installed in that diff. That's not gonna be cheap to replace, if that's the problem. Do the SAS now!
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Anime Episodes | Loans | Loans | Loans | Debt Loans
