My mileage numbers are in...
I just went through my first tank of gas in the '93 pickup. The odometer said 208 miles on 14 gallons of gas. The truck has 31" tires, so I assume the true miles are a little more. I'm still not impressed - that's about 15 mpg. My V8 4Runner gets better mileage.
Does this sound like normal mileage? Stock 22RE, automatic transmission, 4WD regular cab short bed, no AC. CEL was not on. No highway driving - just short trips to the gym and home depot. |
In a 93 i would not know, i do know, however, that my 84 with 31's and the 22r 5spd gets around 23-25 on the highway, and 18 in the city. I have a .33% correction rate. My odo says 36 miles when google maps and other vehicles says 48.6 miles to the nearest big city
TLCA# Don't have one yet, but Rising Sun CO will be my domain
The auto definitely eats a little more gas and that's only a small part of why I'll be happy when I get my manual in.
__________________ 86 4Runner, stock, and clean......for now |
I don't think that is that far off at all-especially for short trips and for an auto.
__________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
#6 | |
not bad. you might see better with properly inflated tires, and a tune up.
but like they said, an auto kills MPG. my buddy gets 18 in his with a W56. __________________ Wristy check the FAQ! 1980 RN37 ![]() ![]() 1989 RN101 1986 RN64 Quote:
#7 | |
__________________ Mark Janzen Born to lose and destined to fail www.mntoyx4.com www.coloradolandcruisers.org www.myspace.com/manjerk |
No longer pre-approved...
Yup, 31's are 10% +/- over stock 28's..... 33% is way off....
15 sounds right, as the others said. __________________ Jerod Online Toyota Parts Catalog!!! 89 4Runner "The James Caird" 01 4Runner, for my Jefferson State Cruisers |
#9 | |
so i multiply my odo by 1.33 I have around 194 right now. 194x1.33=258 258 off of 12 gallons = 21mpg or 194 off of 12 gallons = 16.1mpg I like the 21mpg better. I know for a fact that its right. And its old, give me a break! My chevy blazer was off the other way! it said i had 300 miles off of 30 gallon. 10mpg (sucked) Then i replaced my speedo cable to get rid of the needle shake, and i had 230 miles before i ran out of gas on 30 gallons! I averaged 7-8 mpgs, and it sucked so bad! The moral of the story is Toy>Chevy! |
#10 |
never rely on google maps or another vehicles odometer. Use a GPS or mileage markers.. The only way you'd be 33% off is if you were running 35's....
EDIT: the only other way that I know of would be incorrect speedo gears in the tcase output... The rest is just basic math, nothing more. __________________ Brian K. Gallus |
#11 | |
"Socks"
__________________ 1984 Toyota 4runner SR5 2004 Ford F150 2002 Suzuki DL1000 |
#12 | |
BIKER= Auto or manual? |
#13 | |
"Socks"
5-speed __________________ 1984 Toyota 4runner SR5 2004 Ford F150 2002 Suzuki DL1000 |
#14 |
Ive had 4 toyota pickups 2 20r's 1 22r both stock and bored .30 over with higher performance internals and a 3.slow. None of the 4cyl ever achieve higher than 18-19mpg. Ever. All were 4x4 and 4 or 5 speeds. I have a very hard time believing a 22r can return more than 20mpg at highway speeds in a 4wd pickup. I've never experienced it, even with all syn fluids and a fresh engine.
Now, with both the 3.0 pickup and the 3.4 in my 4runner Ive consistently achieved over 20mpg. My last trip from Missoula Montana to Bozeman (195 miles) at 70mph (slow) I used 7.8 gals there and 8.0 back. Right under 25mpg. Anyway, I think that's as good as you'll probably get with a 22r. I've never had a 22r leave me walking either though. Even when I put the hood under water without a snorkle, I winched out, let the water out of the intake and she fired right back up. __________________ jetboy, 75-40 |
#15 |
I get a little over 20 with my 83 with 33's and 5:29's
__________________ www.tlca.org President-Central Valley Crawlers www.centralvalleycrawlers.org www.marlincrawler.com |
#16 |
1989 Gen1 4Runner
22RE motor LC headers, Borla exhaust (2") good rune tired motor (360K - one HG) 5Spped W56 Tranny If I drive like a granny - Get 19-20mpg mostly highway With 360K of gas logs I averaged 21mpg highway prior to major mods (lift, bumper etc) Last 100K has seen 18/20mpg... ALOT has to do with the right foot BTW |
#17 |
My stock 1985 Xtra Cab SR5 4x4 22RE (212k miles) w/5spd tranny gets 18-19mpg around town and 20-24mpg on the highway. Stock tire size. It has a steel camper shell on the back, same height as the cab. I'm looking to go bigger tires (31-33") and mild lift. I know I will sacrifice mpg to get there, tho.
__________________ Bob Bulleri Novato, Ca. 1974 FJ40 F Engine, DUI HEI, 2.5" OME lift, 33x12.50x15 BFG M/Ts, Front Disc Conversion, P/S, Header, locked, Detroit rear, ARB front, Mudrak Improved! 1985 Toyota 4x4 Pickup, Xtra Cab, EFI...bone stock TLCA# 13586 Pacific Mountain Cruisers |
#18 |
I picked up some info on the "340H" once by accident. It said the "H" TC acted much like another torque converter and it was said this was the major source of the loss of both power and mpgs.
Also, if anyone cares(I do, I have an AT rig that's going to be kept AT) I believe Marlin has an adapter to put a gear driven TC and do away with the "H". I believe...no pretty sure many others have reported mileage gains by doing this and doing away with the traditional "H"ydraulic TC __________________ Originally Posted by Hilux I want to be the Ben Braddock of the apocalypse ![]() And Resident headache getter ridder of-er for the ladiezzz... ![]() |
#19 | |
#20 |
just threw Aisin hubs on my T100 - mileage up almost a full 1mpg in mixed city/traffic/highway driving (leadfoot) to almost 19.5... Still doesn't touch my Civic, though.
#21 | |
I never run synthetics but I keep on top of the valve specs and oil changes/lubes/gear oil changes. I just logged 24.1 mpg this weekend going back and forth from Lexington to Louisville. Driving style has a LOT to do with mpg. I never get over 3500 rpms to shift. Usually I am shifting right before 3000. __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
#22 |
In debt to the Shaman
You stock boys make me sick. I used to get 24mpg in the 4Runner. That was, oh, 20 years ago. Now, with 33" MT/KMs, 4.56 gears, and 4" of lift I'm lucky to see 18mpg on the highway, and 16 around town.
__________________ aka Bushrat 1969 FJ40 Project TEROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC ... assembly in process 1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage. McCain/Obama - Four more years of hell. |
#23 |
Hmmm.. My old 85 w/ lift, 35's, 5.29's did 18+ combined, and could hit up to 22 on the highway... Never understood the variances.
