lear spring rear to coil spring rear conversion for 95 4runner
my 95 4runner (3L engine,full cab) and runs coil spring front and leaf spring rear suspension... the other day i sat in a friends hilux surf (coil spring rear) and the ride was phenomenal. i want to do this conversion to my 4runner... from what i understood after looking under both the 4runner and hilux surf was the diff tube, coil spring, spring seat support bars(diff to the front of the chassis) need to be there for this swap to happen. any body done this swap? help would be really apreiciated.
ideally if somebody from the asia pacific region can also point me towards a reliable junk yard where i can source the nessary parts. |
BUMP anybody..
it seems to me that you want to go to a 3 or 4 link suspension. The easiest way is to buy a donor vehicle and swap everything over, or you can get into custom suspensions. If you have the tube, tools, bender, and know how to do simple geometry than you good. if not i believe there are some aftermarket bolt/minimal fab kits availble.
No longer pre-approved...
You're 95 4RUnner has leafs in the rear? I thought they were all coil rear 90 +? Swapping the stock coil set up can be done, but it's a lot of work and you get a decent ride, but not much flex.... A custom 4 link would be better, and possibly less work than the stock coil swap....
__________________ Jerod The 79-95 Truck/4Runner FAQ 89 4Runner "The James Caird" 01 4Runner, for my Jefferson State Cruisers |
#5 | |
I'd go with a custom 3-link + panhard to allow the tank to stay in the stock position. __________________ Brian K. Gallus |
hey guys thanks for the reply. the LN135 4runner came with a 3L engine and leaf springs at the back.
the car is mainly a city runner so a comfortable ride is what am looking for. excuse my ignornace but what is a 3-4 way suspension? and where can i get more details regarding the same. i live in india and 4runners and hiluxs are a rarity here so any part which needs to be sourced needs to be from abroad . so if you guys can point me in the right direction to where i can get toyota part numbers on the internet.( i know bmw has realoem for part numbers and part discription) or breaker who can help me. any further help will be of great help as i want to do the coil spring rear mod first and then the 3L turbo later so i have a cool ride... which takes me everyhwere thanks, phil |
#7 | |
Oh, OK. now this makes sense. you have a 4Runner/Surf! no wonder it has rear leafs!
![]() here is a link with all kinds of builds. a 3, 4, or 5 link is a type of suspension that uses either 3, 4, or 5 bars that hook to the axle and frame. It uses coil over shocks. these setups are tricky. and should not be attempted by a rookie. they allow for insane articulation. __________________ Wristy check the FAQ! 1980 RN37 ![]() ![]() 1989 RN101 1986 RN64 Quote:
#8 | |
Are you familiar with Tatas? Im talking about the car/pickup truck company, not boobies.
How well do those things hold up? __________________ Wristy check the FAQ! 1980 RN37 ![]() ![]() 1989 RN101 1986 RN64 Quote:
yea they are pretty common here. the great value for money if you ask me but fit and finish is a black spot . why do you ask ?
#10 | |
cause i read a report indicating they will be importing them in 09. I just want to form a completely biased opinion.
#11 | |
I drove a 1998 Tata Telcoline back in the day before I bought my Hilux. - The dealer had it advertised as a 4x4, but it was a 4x2.
__________________ 1986 Nuclear Reactor 1985 Toyota LN65R LIFE AIN'T WORTH LIVING WHEN YOU DIE BEFORE YOU'RE MEANT TO! |
#12 |
Welcome India!!!
It's so cool that Toys have brought is all together. Glad to have you. The stock 90-95 4Runner has a 5 link coil suspension, 2 going forward on each side, and one going sideways. Here's a shot of the right end of the "panhard" (sideways) bar.
#13 |
Maybe a mod like this would do what you're looking for?
coil lift Also, any pics of your 4Runner/Surf?
#14 |
and here's a shot of the 2 right side links... (upper right, and lower left)
![]() http://rds.yahoo.com/_ylt=A0WTb_sRcG...el.com/054.jpg Took a bit to find that pic.... Hehe __________________ Jerod The 79-95 Truck/4Runner FAQ 89 4Runner "The James Caird" 01 4Runner, for my Jefferson State Cruisers |
#15 |
Maybe the new 4-link from trail-gear is the easiest way to go?
__________________ knixens runner on 39,5 iroks
Loans | Debt Consolidation | Debt | Loans | Loans |
