Old 06-20-08, 04:36 PM   #1
HJ-45CrewCab's Avatar
TLCA# 17572
I need transfer case wisdom!
Gentleman, I started out with an auto to manual transmission swap, but I have since decided to do more with the transfer case setup. The truck is a V6 95 4runner and I have looked at the websites for Marlin, Inchworm, Allpro etc for all the info on transfer cases. My goal is to not mess with drive shaft modifications, and put in a single 4.70 gear case. (90:1)
I have finished the following modifications:
Removed automatic
Installed new pedal assy and hydraulics
Installed resurfaced flywheel, new clutch
Installed the R150 5 spd,
Removed and opened the VF1 transfer case
I have the following parts:
Marlin's 4.70 gear set 23 spline
85 4runner parting out (fwd shift transfer case?)
$150 gift certificate to Advanced Adapters
I know I need the V6 adapter plate, which I will get through AA with the gift certificate. But can I use the transfer case out my 85? Pretty sure its forward shifting, or does that matter? Can it be converted? Finally, with the width of the V6 adapter, will the stock drive shafts still be ok?
Thanks for your time.
1980 HJ-45 Crew Cab
1990 FJ-62
1995 4Runner
2007 FJC
2005 BMW F650GS Dakar
1968 M105 trailer
HJ-45CrewCab is offline   Reply With Quote
Old 06-20-08, 05:22 PM   #2
foxfab's Avatar
TLCA# 9838
In order to use the V6 adapter, you need a top shift 4 cylinder t case. If your 85 case is forward shift (non EFI truck) , it can be converted to a top shift. Marlin sells a kit to do it. A forward shift has two forks sticking out of the front of it. A top shift doesnt. I cant help you on whether your driveshafts will work though.. Since you're going to have to disassemble the 4 cylinder case to install the 23 spline 4.7 gears, making it a top shift will be easy.
YANKEETOYS.ORG
Member of the elite FJ25 club
Low range? We Don't Need No Stinkin' Low Range
Why would you want to put a round tire in a square wheel well?
foxfab is online now   Reply With Quote
Old 06-21-08, 11:35 AM   #3
toyminator's Avatar
TLCA# 17965
Have you tried looking on Marlin's forum?
Marlin Crawler - Online Forum - Index
1989 Toyota Pickup - 255,xxx miles, SAS, Bed Bobbed 14", 95 4Runner front clip, Hanemman Fiberglass front fenders, All Pro 5.5" lift, Hi Steer, 5.29 gear rear Detroit locker, front ARB locker.
1988 4Runner - Blown up 3.0 V6
1999 4Runner SR5 Sport Edition
1992 Lexus SC400
toyminator is offline   Reply With Quote
Credit Counseling | TV Guide | Electricity | Loan | Mortgage Calculator
