Old 06-17-08, 07:14 PM   #1
forestdan7's Avatar
TLCA# 17532
Clicking noise: bad piston?
87 4Runner 22RE 5 speed
I've got a clicking noise that's been on and off for a while. Right now, if I hold it at 2000 RPM, it's loud and constant, but only very intermittent at idle, with no rhythm to it at idle. Above 2000 RPM, it's also intermittent.
Sounds like one of those old noise makers at football games. Very metallic sound. I used a hose tonight and could not locate it very specifically, but seems like it's coming from inside the block.
It's not from the timing chain I don't think, and the valves are kind of loud, but not like this.
It really sounds like it's one cylinder doing something bad. Any ideas? With the rust issues I've got, I'm not sure I'd be into rebuilding this engine.
1985 FJ60
1987 4Runner
2007 Honda XR650L
forestdan7 is offline   Reply With Quote
Old 06-17-08, 07:32 PM   #2
Hilux's Avatar
TLCA# 9h9-69
If its from the top, and a light clicking, I'd say piston slap.
Bottom, and more pronounced I'd say rods...
Originally Posted by Hilux
I want to be the Ben Braddock of the apocalypse
And Resident headache getter ridder of-er for the ladiezzz...
Hilux is offline   Reply With Quote
Old 06-17-08, 07:44 PM   #3
forestdan7's Avatar
TLCA# 17532
Thanks, Hilux.
It does sound like it's more from the top. But it is pretty pronounced.
It is strange that it's only around 2000 RPM, and not constant at any old speed.
I was about to drive a few hundred miles in her this weekend. Would either piston slap or rods leave me stranded, or is it just going to get worse and worse and start running bad?
1985 FJ60
1987 4Runner
2007 Honda XR650L
Old 06-17-08, 08:27 PM   #4
PressOn's Avatar
I picked up an 81 landcruiser (BJ42) in Tennesse and drove it to northern Michigan with a respectable piston slap. I put on another 4k miles until I got the rebuild parts together. In my case it was a cracked and missing piston skirt on half the piston. It also had a sweet spot where it was pronounced similar to what you describe.
I'd suggest pulling the oil pan and take a look. You might see where the slapping is coming from.
Good luck.
Jeff
1981 BJ42/Factory smurf blue/PTO Ramsey
03 Volkswagon wagon TDI
Only gassers left in my household are my Stihl chainsaws...
PressOn is offline   Reply With Quote
Old 06-17-08, 08:29 PM   #5
WristPin's Avatar
neither one of those possible problems are going to be nice to you.
if you are genuinely concerned about it, tear it down and fix it.
it also could be broken chain guides, and the noise is chain hitting timing cover.
use a stick as a stethoscope, not a hose. and check the timing cover for the noise
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Originally Posted by Rezkid View Post
ridin quads and blastin' mofers...life don't get much better than that
Originally Posted by chesshircat View Post
Found my Haynes manual, shoved it under the leg of my bench to level it out.
Old 06-18-08, 08:07 AM   #6
forestdan7's Avatar
TLCA# 17532
Good ideas. Thanks for the feedback. I'll post up what I find out. Might even let my mechanic take a listen this weekend if he's got the time.
1985 FJ60
1987 4Runner
2007 Honda XR650L
Final Fantasy MP3 | Car Insurance | Remortgages | Slot Car Racing | Personal Loans
