Old 06-12-08, 09:12 PM   #1
coolant leak
Have an 84 4runner with a 22r. As I was driving the car began to run hot an smelled coolant burning, I discovered coolant leaking from passenger side area under the air filter/carburetor and above the starter. I thought it might be the hose that is in between this area, but after replacing, discovered that I still had a leak right above the hose. I am not able to locate what is under the carb and leaking. When the engine is idling, it begins to drip, and drips faster as the car warms up. Does anybody have any ideas of where this leak is coming from? Any help would be appreciated. Thanks
texapino is offline   Reply With Quote
Old 06-12-08, 09:23 PM   #2
If its getting a heavier, quicker drip as its warmer than it is metal of some sort, as metal expands when its hot. I dont know, nor at the current moment have the will power to grab a flash light ad examine mine. So ill look and get some ideas 2morrow. till then, cheers
http://www.hogansoffroad.com
Locked and loaded 84' lux' on 31's
liljlandon is offline   Reply With Quote
Old 06-12-08, 11:08 PM   #3
Bogo's Avatar
This is where the dental mirror comes in handy.
When change isn't enough. Vote CHAOS party. You know you can't resist.
Bogo is offline   Reply With Quote
MPAA | Loan | Credit Counseling | Send Money Online | Apply for Credit Card
