Old 06-04-08, 01:54 AM   #1
VA.CRUISER's Avatar
TLCA# 13552
Timing Chain Question
I've got a timing chain quetion for you 22R/E guys. I have a '88 2wd with a 22R while changing the timing chain,when I installed the new sprockets with the #1 cylinder at TDC the woodruff keys are pointing at each other. So with this the dots on the sprockets do not line up with the bright links at the same time. The old setup was the exact same way, so is this right or is something out ? I've turned the engine over with a rachet with nothing hitting just wanted to know if I need to check anything before finishing it up.
Hope this makes sense TAT,
Burl
'77 FJ-40 2F 4SPD.TRANS W/3SPD.CASE HOLLEY CARB. OFFENHAUSER INTAKE UNDER CONSTRUCTION SOON TO HAVE GOZZARD TUB, SOA ONE DAY
'88 FJ-62 4" Alcan Springs w/Daystar Super Shackles 33"x9.5" tires front & rear Aussie lockers with Sliders NOW
'99 GMC SUBURBAN -YOTA TOTER
VA.CRUISER is offline   Reply With Quote
Old 06-04-08, 05:02 AM   #2
tlcruiser66's Avatar
I wouldn't worry about the links lining up, as long as your crank key and cam dowel are lined up at #1 TDC at 12 O'clock you should be alright, just make sure they still line up after 2 full rotations of the cam and you'll be fine.
1966 FJ-40 Under Construction.
1985 4Runner. Something to play with while the 40s out for mods.
2003 GMC Sierra Quad-cab. Duramax diesel w/ all the toys. Diablosport Predator tuner and 33" tires.
tlcruiser66 is offline   Reply With Quote
Old 06-04-08, 05:28 AM   #3
Jukelemon's Avatar
I don't agree at all with that.
The chain markers are there for a reason-why ignore them? I don't know the exact mechanical reason BUT I believe it has to do with making sure the tension on the chain/timing of the crank/cam remain in spec.
I am not sure about a 22r but on a 22re, the cam sprocket dot/marker for the chain link is pointing at 12 o clock and the Crank sprocket dot/marker for the chain link is at 6 o clock when the engine is at TDC. As well, at TDC, both the crank and cam keys are pointed at 12 o clock and Piston 1 intake valve is open.
Hope that helps.
"May you be in heaven a half an hour before the devil knows you're dead"
1992 4x4 PU
Jukelemon is offline   Reply With Quote
Old 06-04-08, 07:00 AM   #4
KLF
KLF's Avatar
It sounds to me like you have the cam 180d out of phase. I'm agree -- those marks are there for a reason, I wouldn't ignore them.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Old 06-04-08, 08:49 AM   #5
Hilux's Avatar
TLCA# 9h9-69
The TDC mark is the same as the BDC only the cam is on the (correct me if I'm wrong) #4 cylinder firing position.
since #1 and #4 (and #2 and #3 share the same stroke only different time) are on the same stroke but different time.
I agree w/ KLF.
I believe you put the crank at TDC and if you would have looked the distributor would be pointing at #4 cylinder
Originally Posted by Hilux
I want to be the Ben Braddock of the apocalypse
And Resident headache getter ridder of-er for the ladiezzz...
Hilux is offline   Reply With Quote
Old 06-04-08, 10:56 AM   #6
Jukelemon's Avatar
No, at TDC the dist is pointing to #1 not #4.
Confident about this since I just did the timing chain 6 weeks ago.
1992 4x4 PU
Old 06-04-08, 11:07 AM   #7
Hilux's Avatar
TLCA# 9h9-69
it's a 50/50 shot
yes the ***CAM*** is at TDC, NOT in his case though. One full rotation and the TDC mark will come up again, only it's for the compression stroke for #4 and at the intake stroke for #1...Intake: *not compression*
Old 06-04-08, 01:26 PM   #8
Jukelemon's Avatar
I see your point Hilux but you are missing the big point.
That is when you do a timing chain r and r, the engine should be at TDC as indicated by the intake #1 being open. At this point, the point of reference for the entire process of r and r, the dist is pointing to #1 piston.
That is where you should remove the dist and where it goes back.
There is no 50/50 chance that the dist is pointing to #1 at TDC when the #1 intake is open. It is 100% or you have intalled the components incorrectly.
1992 4x4 PU
Old 06-04-08, 02:06 PM   #9
EVILSPOTTER's Avatar
If the intake valve on# 1 is open wouldn't that be intake stroke? I get to TDC of compression stroke by rolling around to dist@ #1 with both valves closed.
EVILSPOTTER is offline   Reply With Quote
Old 06-04-08, 02:30 PM   #10
Hilux's Avatar
TLCA# 9h9-69
all of this is better explained in the setting valve lash procedure
You can have the "mark" at TDC and the cam 180 from TDC.
Which I believe is the case for the OP.
Old 06-04-08, 02:40 PM   #11
Hilux's Avatar
TLCA# 9h9-69
Burl
DUH! (self duh )
Mr. Ives, to answer a question about safe rotation. Move the TDC mark to what would be BDC that is to say move the mark to its most southern point, straight down. This will draw all the pistons halfway down the cyliders and have NO CYLINDERS at any point sitting flush with the top if the block. Then you are free to move the cam any way you want w/o fear of hitting a piston at the top of its stroke.
On a positive interference motor ALWAYS move the pistons down off the top to be able to turn the cam. Or else the compression in the vale springs could cause a sudden loss of control and slam a valve into a piston.
Old 06-04-08, 06:35 PM   #12
beatdown83fj60's Avatar
TLCA# Don't have one yet, but Rising Sun CO will be my domain
Wow long day at work so that math is killing me right now but I will share my experience. I had an 84 4Runner. It had a 22r but a newer (86-95 I believe) head. I bought a timing chain kit at NAPA. Part of the kit was alright. I ended up having to -I Think- use the lower sprocket made for my 84 22r, use the chain/guides from the 84 kit, and the upper sprocket from the 86+ kit. I think...It's been a while. If you search my username and "timing chain" you will find it. Sometimes before you own a vehicle things get changed and in turn you need to piece stuff together. With the 84 22r kit the chain links would not line up like they should until I put the cam sprocket on that belonged with the head. I also had to degree the cam a little differently which I have no idea how I did right but I did.
86 4Runner, stock, and clean......for now
beatdown83fj60 is offline   Reply With Quote
Old 06-04-08, 06:50 PM   #13
PurpleFJ62's Avatar
I remember having a similar thing on my 3vz. it has a belt, but the key argument is the same. on an oem belt there are painted marks that you are supposted to line up with the painted dots on the engine crank and cam sprokets. After several attempts of doing this i failed and said screw it. I am not sure why they are on there, but as long as you have the Cam and crank timed correctly the engine will operate as it should. It dosent matter how the chain or belt is orientated. Shoot for the timing marks to be correct, thats what is really important.
Kettering University Incoming Freshman
1988 FJ 62, 1994 4Runner, 2001 4Runner, 2006 VW TDI, 1992 Plymouth Laser, 1999 Heep of Junk Wrangler
Live in the thumb of michigan? Need body repair or restorations?
http://www.cococollision.com
PurpleFJ62 is offline   Reply With Quote
Old 06-04-08, 09:54 PM   #14
Jukelemon's Avatar
Guys I understand what you are getting at BUT that is NOT how to do a proper r and r of the timing chain.
As described by the FSM, TDC, or the reference point in FSM for beginning and end of the process, is described as the #1 intake valve being open.
It is really moot as to what happens at 180 degrees of that because if that is where you are, then you need to turn the crank 180 degrees and get it to where I stated. If not, then you cannot align the chain marks with the sprockets and it does matter or else it would not be mentioned to do so.
Maybe the engine will run OK, I don't know. But it is described as such for a reason in my opinion.
1992 4x4 PU
Old 06-04-08, 10:46 PM   #15
No longer pre-approved...
2ndGenToyotaFan's Avatar
At TDC both #1 valves are closed. I guarantee it. You must be misreading the FSM. If a valve was open at TDC it would be being crushed by the piston.
I'm not sure what the problem is at this point, but if you got the cam and crank out of sync, here's how to get it back. Install the cam gear, and turn the cam shaft till the timing mark is at 11:30 and both #1 valves are closed (you will be able to wiggle the rockers), if you can't turn the cam it's because the pistons are up stopping the valves from opening, so you will need to turn the crank to give the cam room to turn.
Pull plugs, and stick a feeler in the #1 spark plug hole, turn the crank either way as long as the #1 piston comes up. Turn the crank back and forth till you have it centered at the top of it's travel. Having a helper is good for this.
Now remove cam sprocket and install timing chain and sprockets so that the bright marks on the chain match the timing marks on the cam and crank. Check that the rotor on the distributor points to the #1 spark plug wire on the cap and button it up.
Old 06-04-08, 11:53 PM   #16
VA.CRUISER's Avatar
TLCA# 13552
Thanks for all the help everyone I'll check things out tomorrow and report back LOL
Thanks again
Burl and yes I'm named after Burl Ives
Old 06-05-08, 07:18 AM   #17
KLF
KLF's Avatar
All I can say is I'm glad some of you guys aren't working on MY engine... wow.
KB1OSF
'98 Lexus ES300
Old 06-05-08, 08:08 AM   #18
Jukelemon's Avatar
OK, shit. I am wrong. I misthought open versus closed. The rocker can be moved for intake 1 when you are at TDC. That would mean intake 1 is closed. DUH!!!
Sorry guys. My bad. I was thinking backwards ) :
1992 4x4 PU
Old 06-05-08, 09:37 PM   #19
No worries Juke
Old 06-11-08, 11:18 PM   #20
VA.CRUISER's Avatar
TLCA# 13552
Sorry for just now getting back to everyone (have been working 12hr nights for past 2 weeks ) Just wanted to thank everyone for their help ended up being I was at TDC on #4 instead of #1 guess I have a few things to learn about these 22R's . I did find out what was causing all the noise at start up the connecting rods are a little loose on the crank but what can I expect with 326,000 +
Thanks again to everyone,
Burl
Old 06-12-08, 11:30 AM   #21
Sweet! Someone besides me with his foot in his mouth! Geez, It was getting lonely holding down the fort all by myself . . .
The garage is no place to park an automobile. (TLCA-14131)
theo is offline   Reply With Quote
Old 06-20-08, 05:39 PM   #22
foxfab's Avatar
TLCA# 9838
It has to be #1 TDC of the COMPRESSION stroke....
YANKEETOYS.ORG
Member of the elite FJ25 club
Low range? We Don't Need No Stinkin' Low Range
Why would you want to put a round tire in a square wheel well?
foxfab is offline   Reply With Quote
Search Engine Friendly URLs by
