Old 05-28-08, 04:15 PM   #1
COMITX's Avatar
Brake Upgrade
One of the calipers on my '86 4Runner decided to give up the ghost and needs a re-build. I'm considering upgrading to the '88-'92 V6 Calipers. I've read this post, V6 Calipers on a '90 4Runner , which discusses the upgrade on a '90. Since my truck is an '86, I have a few questions:
1. Will these calipers work on my truck?
2. Do I need to upgrade to V6 rotors?
3. Will I have clearance issues with my stock DLX steel wheels?
Thanks, Ken
FJ60 "Moose", FJ62 "Mule, UZJ100, '86 4Runner "Junior"
COMITX is offline   Reply With Quote
Old 05-29-08, 12:55 AM   #2
WristPin's Avatar
the calipers will bolt up
call a parts house and check if the v6 and 4cyl rotor have the same part number. if the are different, you need to swap rotors too.
wheel clearance? well at least you are asking all the right questions. I dont know. i assume they would be fine. but you know what they say about assumptions...
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Originally Posted by Rezkid View Post
ridin quads and blastin' mofers...life don't get much better than that
Originally Posted by chesshircat View Post
Found my Haynes manual, shoved it under the leg of my bench to level it out.
WristPin is online now   Reply With Quote
Old 05-29-08, 07:43 AM   #3
COMITX's Avatar
Thanks Twisty.
The Part Numbers do match so I'm going to order the parts. I'll update on the wheels, and if they don't work, I'll have an excuse to upgrade there too.
Old 05-29-08, 07:52 AM   #4
In debt to the Shaman
pappy's Avatar
TLCA# 10004
I'll bet the wheels fit. It's the solid axle steel wheels that don't clear the V6 calipers.
aka Bushrat
1969 FJ40 Project TEROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC ... assembly in process
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
McCain/Obama - Four more years of hell.
pappy is offline   Reply With Quote
Old 05-29-08, 10:49 AM   #5
Hilux's Avatar
TLCA# 9h9-69
or a small, over the stud spacer. I can't imagine them being that much off...
Originally Posted by Hilux
I want to be the Ben Braddock of the apocalypse
And Resident headache getter ridder of-er for the ladiezzz...
Hilux is offline   Reply With Quote
Old 05-29-08, 01:18 PM   #6
It all works fine...pads and the calipers are the only diff from 89-95 and 86-88.
TOYOTAPARTS is offline   Reply With Quote
Old 05-29-08, 03:31 PM   #7
KLF
KLF's Avatar
Yup, the only issue you will have is you'll probably have to trim the dust shields a little to get the calipers to fit.
I've done this upgrade and it did help some. But what really helped was also upgrading to a 1" MC and brake booster from a V6 truck.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Old 05-29-08, 03:39 PM   #8
COMITX's Avatar
Thanks for the info. I'm planning on that upgrade later. But since my existing calipers need work now, I figure that I might as well upgrade.
What did you use to trim the shields?
Old 05-29-08, 05:05 PM   #9
pappy's Avatar
TLCA# 10004
First time = file
Second time = file
Third time = grinder
aka Bushrat
Old 05-29-08, 07:38 PM   #10
4 cyl is same stuff just as long as its 89 up. The brake master does help a lot.
www.davezoffroadperformance.com for all your new and used Toyota parts. 530-622-2148
Old 05-30-08, 07:39 AM   #11
KLF
KLF's Avatar
I used my cut-off tool, I actually trimmed mine way back to expose the rotors. I kept getting rocks stuck inside them. Before and after:
KB1OSF
'98 Lexus ES300
Old 05-30-08, 06:50 PM   #12
PurpleFJ62's Avatar
intresting mod, i am in the process of doing a solid axle swap in my 4runner. I am installing my old V6 calipers onto the solid axle in place of what ever was there. My calipers are off of a 94 model, they are pretty big, 4 pistons. My jeep only has single piston calipers.
Anyways....I trimmed my dust shields with a cut off wheel, not too much has to come off to make a good fit. One thing i am pretty shure of is that you cannot just get rid of the dust shield, it needs to be in there to have proper spacing of the spindle assembly. You could just get rid of all the material around the flange portion. I am not sure what you want to do there. I have some pictures that might be of help to you.
Sorry the picture orientation dosent match...
Here is the before
Here is the after
Hope this helps..
Kettering University Incoming Freshman
1988 FJ 62, 1994 4Runner, 2001 4Runner, 2006 VW TDI, 1992 Plymouth Laser, 1999 Heep of Junk Wrangler
Live in the thumb of michigan? Need body repair or restorations?
http://www.cococollision.com
PurpleFJ62 is offline   Reply With Quote
Loans | Mortgage Calculator | Bad Credit Mortgages | Finance News | Pay Day Loans
