Old 05-25-08, 05:38 PM   #1
Spare holder
OK I drive an FJ40 but my Daughter's 89 Runner needs a new spare tire holder. The old lifter thing fell apart. I was thinking of welding a big bolt were the lifter goes and using a huge wing nut and washer or coming off the roll bar and mounting it inside. Any ideas? The Runner is stock but pretty beat up.
nailbender is offline   Reply With Quote
Old 05-25-08, 11:00 PM   #2
No longer pre-approved...
2ndGenToyotaFan's Avatar
How did it fall apart? They are very serviceable units as long as you didn't loose any of the important parts...
Old 05-26-08, 01:12 AM   #3
WarDamnEagle's Avatar
There's one or two complete OEM, undercarriage spare tire holders (chain, hoist, etc.) on ebay right now. They usually go pretty cheap.
1985 4Runner - second round of upgrades done!
1997 FZJ80 - locked and stock
2007 HDJ100 - DD
.....and these are just the Toyotas
WarDamnEagle is offline   Reply With Quote
Old 05-26-08, 05:02 AM   #4
Bogo's Avatar
A friend mounted a cable pulley down where the lifter goes. He then ran the cable to a winch he buried into the fender area. It has a set of holes on the winch drum and base so it can be locked with a pin or padlock.
Sanity is for wimps.
Bogo is offline   Reply With Quote
Old 05-26-08, 12:39 PM   #5
Thanks all, I looked and did find them cheap on Ebay. I will get under there agian and see if it unbolts or is rusted in place.
Old 05-26-08, 01:23 PM   #6
WristPin's Avatar
on my 80 it unbolted with the bolts going in from above it. i had the bed off, so it was a cinch.
if your truck is the same it will probably be best to use a gear wrench to remove the bolts.
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Originally Posted by Rezkid View Post
ridin quads and blastin' mofers...life don't get much better than that
Originally Posted by chesshircat View Post
Found my Haynes manual, shoved it under the leg of my bench to level it out.
Old 05-26-08, 06:10 PM   #7
If the housing part is ok, it's a piece of cake to change out the guts. Just a C clip holds it all in... What exactly is wrong with it?
Old 05-26-08, 08:15 PM   #8
I won't be able to get under it now until next week, daughter is out of town. Looked like a plate came off the housing and a horseshoe shaped spring fell out. The plate looked badly bent but the whole thing was so rusty I probably will see about getting one off E-gay or at the pick&pull.
Charms | Reptile Supplies | Mortgages | Web Advertising | Personal Loans
