Hard start when warm..
OK. I am going to do this by the book and see what happens.
According to FSM, here is the step by step when this happens Check (in order): 1- Coolant Temp Sensor 2- Gas quality 3- Idle speed control Valve 4- Fuel Pressure Control System 5- Intake Air Temp Sensor Circuit 6- Cold Start System I figured I would start with the top 6 Replaced 1 with OEM Toyota. No change. Gas is from Shell/Chevron. No change Have no idea what 3 is AND the FSM does not provide a reference page?? 4...Which one is the VSV?? There are about three on top of the Valve cover that match the pic in the FSM. Fuel pump is fine AND I have tried the cheap trick of keeping it on i.e. bypassing the AFM which makes me rule out, in my opinion, 5. 5...AFM. FSM states to test this at the ECU. Any easier way? 6...Will wait. Thx __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
#2 | |
3 its the big screw on the throttle body
4 trace the hose from the fuel pressure regulator, then check volts at connector while running. 5 in the FSM there is a section on just the AFM, and how to check values. but by opening the door on the AFM, it does kind of rule out the testing of it, and also cause it runs fine otherwise, right? I have been brain storming this problem too. seems like when i cycle the key it does it less often. maybe the EGR valve is getting opened right at startup? i'll try testing for that, do the same, see what happens. course i havent had a warm day here in a while. but my top is off! __________________ Wristy check the FAQ! 1980 RN37 ![]() ![]() 1989 RN101 1986 RN64 Quote:
Hey pin.
What are the specs, for lack of better words, for the idle speed valve? Thanks __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
#4 | |
we just a a thread on it
the big fat idle adjust thread 850 RPM I think __________________ Wristy check the FAQ! 1980 RN37 ![]() ![]() 1989 RN101 1986 RN64 Quote:
Oh, I get it. I thought it was a valve??
Idle is at spec so that rules that out. __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
Handytest | Adverse Credit Remortgage | Fast Loans | New York Hotels | Loan |
