Old 05-22-08, 06:59 PM   #1
Jukelemon's Avatar
Anybody got a pic of the cold start injector. 22re
Thanks.
JL
"May you be in heaven a half an hour before the devil knows you're dead"
1992 4x4 PU
Jukelemon is offline   Reply With Quote
Old 05-22-08, 07:08 PM   #2
WristPin's Avatar
in or out of the manifold?
ill go take one after supper
why??
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Originally Posted by Rezkid View Post
ridin quads and blastin' mofers...life don't get much better than that
Originally Posted by chesshircat View Post
Found my Haynes manual, shoved it under the leg of my bench to level it out.
Old 05-22-08, 07:13 PM   #3
Jukelemon's Avatar
Hey pin.
In the manifold. I was reading that fellows post about hard starts and I still have that strange issue of hard starts when the truck sits for an hour or so AFTER being run. Never an issue when warm and never an issue when cold i.e. first starts in the mornings in any temp.
I replaced the coolant sensor and that did nothing. Checked the fuel pump and even bridged the connection so it ALWAYS ran. Still nothing.
Thought maybe the cold start injector could be dirty/faulty.
1992 4x4 PU
Old 05-22-08, 08:43 PM   #4
In debt to the Shaman
pappy's Avatar
TLCA# 10004
Originally Posted by Jukelemon View Post
... and never an issue when cold i.e. first starts in the mornings in any temp.
If it starts easy first thing in the morning it's not the cold start injector.
aka Bushrat
1969 FJ40 Project TEROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC ... assembly in process
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
McCain/Obama - Four more years of hell.
pappy is offline   Reply With Quote
Old 05-22-08, 08:51 PM   #5
pappy's Avatar
TLCA# 10004
Cold Start Injector
aka Bushrat
Old 05-22-08, 09:43 PM   #6
Jukelemon's Avatar
Thanks.
What are your thoughts then?
1992 4x4 PU
Old 05-24-08, 05:55 AM   #7
LeftCoast's Avatar
Maybe you've seen this, but it describes your problem. If not, it's worth a look.
Toyota 4Runner and Pickup: Cheap Tricks
LeftCoast is offline   Reply With Quote
Old 05-24-08, 08:44 AM   #8
Jukelemon's Avatar
Thank you.
Saw that/did that a couple years ago. Was VERY excited to see that write up but no luck. Did not fix anything. I could hear the pump going when the ignition was on run-point of the cheap trick BUT it never helped. Same problem existed.
I just looked at my AFM and it is clean as a whistle. Of course, that doesn't mean anything ohter than it is not sticking due to debris.
Quite a riddle.
1992 4x4 PU
Bad Credit Mortgages | Mortgages | Cell Phones | Xecuter 3 Mod Chip | Credit Card Consolidation
