Old 05-21-08, 09:31 PM   #1
CookieJR's Avatar
heeelpp mee my truckks flooded
well i tried to cross a rushing river in the trepanier valley and it took my truck side ways and submerged the front and i turned it off and had it tied to the nearest tree in less than a minute, after i relized i was stuck. It wouldnt start but marlin375 managed to get it to work im not sure how but he did it on the spot. any ways it starts and runs but after a short period of driving my check engine light turns on and the engine starts to cut in and out and wont let me rev over 2 or 3 grand and its not right! heeelllp!
1995 SR5 PU, EC, v6, 5 spd, 4' Pro Comp susp lift, 33x12.50 Interco MT's, 15' alloys, K&N cold air intake (soon to go), PC skid plate, sirious sat, VHF radio, (2) kicker ds400 4'', (2) mtx 4/6's, panasonic deck, fosgate10' sub, 500w fosgate amp.
''YOU DRIVE LIKE A MAN, YOUR GONNA PAY LIKE A MAN''
CookieJR is offline   Reply With Quote
Old 05-21-08, 09:49 PM   #2
I'm freakin Irie damnit
ms018kmf's Avatar
Damn dude, that sucks. There's a lot of small things to look over, but hey at least you're running .
I found water had traveled throughout many vacuum lines when I ate it. If water got to the emissions stuff there could be enough to make the engine sputter. Say there's a cup in that evaporation canister, it stays put until the motor revs enough to get a sip. If you're running and idling fine the major stuff should be intact.
Got any pictures, or video?
*Until I get a new camera all pictures will suck*
1994 Pickup 3.0, Total Chaos Caddy kit, Bilstein 9100's front/7100's rear, Centerforce Dual Friction, Red Optima, Flex-a-Lite Fan, TC Idler Arm, TC Diff Crossmember, Marlin rear bumper, fresh Toyota HG's with DOA Head Studs, Amsoil Synthetic Fluids everywhere and 33 BFG Muds.
If grandma had wheels she would have been a streetcar.
ms018kmf is offline   Reply With Quote
Old 05-21-08, 09:51 PM   #3
ms018kmf's Avatar
Oh yeah, I had great luck with that K&N too .
http://forum.ih8mud.com/79-95-toyota...one-wrong.html
Old 05-21-08, 11:46 PM   #4
CookieJR's Avatar
it doesnt idle it some times bounces off 0 rpm and keeps going for a secand then dies right away and i cant drive it when its warmed up because it just cuts in and out and runs horribley : (. and noo i was to angry and never thought of taking pictures lol
Old 05-22-08, 07:04 AM   #5
LeftCoast's Avatar
Don't forget about trouble code 99...a trout in the air box!
LeftCoast is offline   Reply With Quote
Old 05-22-08, 09:11 AM   #6
check the tps, afm, sounds like one of them is shorting out.
missouriman is offline   Reply With Quote
Old 05-22-08, 01:39 PM   #7
ms018kmf's Avatar
It's time consuming but I'd label and pull every hose for an inspection. Kind of painting with a wide brush but it's difficult to tell what to check over the intranets. If you didn't have standing water in your cab you got off easy .
Old 05-22-08, 07:09 PM   #8
Jukelemon's Avatar
What was pulled and cleaned so far??
You are aware that your diffs need to be drained unless you routed your vent lines somewhere VERY high. As well, better make sure there is no water in you engine oil i.e. through the dipstick if loose or through a very old PCV gasket.
Are all of your emission lines connected? Did the water cover the entire hood? If so, you could have water anywhere. Could have sucked water back into your gas tank via the emissions caninster ( I think v6's have them).
"May you be in heaven a half an hour before the devil knows you're dead"
1992 4x4 PU
Jukelemon is offline   Reply With Quote
Old 05-22-08, 10:50 PM   #9
No longer pre-approved...
2ndGenToyotaFan's Avatar
Start pulling hoses and electrical connections and find where the water is staying... A hair dryer may help.... Good luck!
Myspace Codes | Loans | Compare Credit Cards | News | Mortgages
