Old 05-19-08, 07:53 PM   #1
Jonathan_Ferguson's Avatar
TLCA# June 9th, 2002
Jonathan_Ferguson
Which Cars have the same Engine Fan as my Hilux?
I need to make the search very broad, because the Junk Yards, I mean Automotive Parts Recyclers operate in a weird manner in this Country. - They're not very interested in selling things, they're more like Automotive Parts Hoarders.
Can someone confirm if all 22R and 2L Fans are the same, and that the Fans remain the same regardless if it's fitted to a Hilux or a faux Landcruiser?
If there is no visible fluid leakage, is it likely that the Clutch is OK?
1986 Nuclear Reactor
1985 Toyota LN65R
LIFE AIN'T WORTH LIVING WHEN YOU DIE BEFORE YOU'RE MEANT TO!
Jonathan_Ferguson is offline   Reply With Quote
Old 05-19-08, 09:23 PM   #2
Hilux's Avatar
TLCA# 9h9-69
Hilux is an unknown quantity at this point
Don't they all turn backwards on the other side of the planet?
Everything else there is backwards....
I'm afraid NA cannot answer that one fer you....sorry.
but seriously, if Toyota put anything that can crossover from a Hilux, into a car, its news to me.
DUH I get it now. Myfriend, it sounds like you could use a E-Fan anyways. At idle the fan will be at full blast and it wont rob the engine of any power. And on the clutch fan fluid (silicone) matter, I believe you can rebuild them, I know its common in 80's tech.
I'm too old school, I still hold a phone to my ear...
We're just one krappy Diesel away from another 30 years of gas ...the "6.2 Redo"
As soon as I figure out how to make a still, I'm
going to start making "Bio Gasoline"
lets see, corn, sugar...copper pipe...
Hilux is offline   Reply With Quote
Old 05-20-08, 04:39 AM   #3
Jonathan_Ferguson
I can get a new Clutch 'ere in Australia. Davies Craig - Home
Is it easy to unbolt the blade portion from the Clutch?
1985 Toyota LN65R
Old 05-20-08, 08:05 AM   #4
No longer pre-approved...
2ndGenToyotaFan's Avatar
2ndGenToyotaFan is on a distinguished road
It's usually a tight fit, but not a big problem to get the fan off of the clutch....
Old 05-20-08, 03:40 PM   #5
DanS HJ-45's Avatar
TLCA# 17527
DanS HJ-45 is on a distinguished road
I'm not sure about what all the fans cross over to or not....
But the 22R-E and 2LT-E fans that I had were different. Now, two years later, I don't remember what exactly was different, but I specifically remember setting them side by side and noting that they were entirely different beasts. Perhaps the diameter of the hole centers was different....
Dan
1976 HJ-45 (needs restoration) http://forum.ih8mud.com/fj45-owners-...self-into.html
1991 "Faux-Lux"Pickup 4x4 2LT-E/R-150f http://forum.ih8mud.com/79-95-toyota...onversion.html
"Dandelions. You see flowers in these weeds."
--Five Iron Frenzy
Rebuilt Aisin Hub Faces http://forum.ih8mud.com/sale-parts/2...hub-faces.html
DanS HJ-45 is offline   Reply With Quote
Old 05-21-08, 06:30 AM   #6
liljlandon is on a distinguished road
You are correct, I ordered a replacement fan from man-a-fre for what they listed under the Hilux. When i got it the mounting holes on the new fan didnt match up, so i was very aggrevated and shot them an email. Turns out the fan is ment for a 2LT and will cross to "some" 22rs. Mainly the RE. That doesnt make sense as i work for oreillys and have been through all of the parts for the R and RE and the RET and they all use the same fan clutch, as do the deisels. Now I have a broken fan that will cost 78 dollars to replace along with one that doesnt fit in which i lost 31 dollars for. Itll cost more to ship it back to man-a-fre than ill get back.
On the electric fan, I ran 2 12inch e-fans and it would overheat going down the highway at 75+ or on the trail with high rpms. in the city or on a backroad it was fine. Swaped a broken fan and one 12incher and she runs at 190 no matter what. If you do go Electric I highly recomend you wire it to a switch, do not go with the thermal sensor. To much room for error, and if you cross water alot youll want to turn it off anyway.
EDIT: Some of the dodge trucks fan clutchs cross over, along with a Nissan and Mazda/Ford. I just cant remember which ones...
Im the lil landon (ironic name...)
hogansoffroad.com
^^^^^^^^^^Our Stomping ground^^^^^^^^^^
liljlandon is online now   Reply With Quote
Old 05-21-08, 06:34 PM   #7
In debt to the Shaman
pappy's Avatar
TLCA# 10004
pappy is an unknown quantity at this point
The EPC shows different part numbers for the L and R engines. Doesn't mean they won't swap, just different part numbers.
aka Bushrat
1969 FJ40 Project TEROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC ... assembly in process
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
pappy is offline   Reply With Quote
Old 05-29-08, 03:11 AM   #8
Jonathan_Ferguson
A new Dayco branded Fan Clutch AU$130.00
I used Thread goo on the Nuts that affix the fan onto the clutch.
1985 Toyota LN65R
Tattoo Forum | Car Finance | Mortgages | Mortgages | Credit Cards
