Strange Tachometer Issue
Hi all.
On the way home today, I noticed that at IDLE my tach showed 0 rpms BUT if I revved it up it registered as normal-or at least it moved like it was normal. Idle is perfectly fine i.e. smooth/right around 750-800 rpm Thought? Is the tach electronic or mechanical? Thanks __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
OK just searched and found that the tach is electronic.
So, why 0 at idle all of a sudden??? __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
No longer pre-approved...
That's bizarre... Does it operate normally, but 750-800 under what it should be all the time? Or when you hit the gas it jumps up to normal?
Either way..... weird. It gets its signal from the coil...... My guess is something's up in the tach its self, cause the coil's sending a signal if your truck is running..... __________________ Jerod The 79-95 Truck/4Runner FAQ 89 4Runner "The James Caird" 01 4Runner, for my Jefferson State Cruisers |
#4 | |
I would have to agree it is the tachometer. The connection are solid at the igniter and the tach works when I hit the gas-regardless if I am in gear or not. Oh well. I can live with it. __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
Update..
After a day or so, tach went back to normal. Really odd. Operates perfectly now. __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
#6 | |
yeah. its odd.
i just took apart my dash. the tach came out too. it is quite a marvel. one strand wires, opposing coils... __________________ Wristy check the FAQ! 1980 RN37 ![]() ![]() 1989 RN101 1986 RN64 Quote:
PVT. RICE CF
My Hilux did that the other day...
Went back to normal as well. I have a 3L diesel...
__________________ 1978 Toyota BJ40 B Diesel 1989 Toyota Hilux Crew Cab 3L 1989 Mazda B2200 SR20DET .zoom zoom. 1969 Mercury Marauder X-100 429 4bbl 1928 Ford Model T Huxter 4 cyl, really stock ![]() 1961 Austin Mini 1100 1974 Yamaha Enduro All the colors of the garage ![]() BR ![]() Crazy for dems oil burners!!!!1 Resto of the Klunk Munkey http://forum.ih8mud.com/40-55-series-tech/168364-1978-bj40-restoration-klunk-munkey.html |
#8 | |
mine did this today too, turned out one of my gerbils in the tires was out of water, so i fed him and gave him fresh water. now were back up to full operating temperature pulling two gerbil power
#9 | |
Hehehe
#10 |
or do you just hide your gerbils there and tell everyone you drove through some mud...
#11 |
or are you friends with Richard Gere LOL!!!!!!
Mortgage | Hotel Las Vegas | Credit Cards | Problem Mortgage | Internet Advertising |
