changing Gearbox fluid in a 1995 toyota
So i have never change my changing Gearbox fluid in a 1995 toyota my self and was wondering if any one has done a wright up on doing it on a 95 runner.
i am thinking it cant be much diffrent then an oil change. in one side and out a drain plug in the bottom. any basic help would ROCK!! |
You may need to check you FSM. It would depend on whether or not you have an automatic tranmsson or 5speed. I believe the Auto's in the 95 4Runners were th A340H model, which shares ATF with the Transmission. The 5 SPD model uses Standard 75-90wt gear oil.
__________________ 1989 Toyota Pickup - 255,xxx miles, SAS, Bed Bobbed 14", 95 4Runner front clip, Hanemman Fiberglass front fenders, All Pro 5.5" lift, Hi Steer, 5.29 gear rear Detroit locker, front ARB locker. 1988 4Runner - Blown up 3.0 V6 1999 4Runner SR5 Sport Edition 1992 Lexus SC400 |
I'm freakin Irie damnit
Get the filler plug off of it before draining the old fluid. It really bites to drain things and then discover issues with the filler (seized, stripped, ext.).
__________________ 1994 Pickup 3.0, Total Chaos Caddy kit, Bilstein 9100's front/7100's rear, Centerforce Dual Friction, Red Optima, Flex-a-Lite Fan, TC Idler Arm, TC Diff Crossmember, Marlin rear bumper, fresh Toyota HG's with DOA Head Studs, Amsoil Synthetic Fluids everywhere and 33 BFG Muds. If grandma had wheels she would have been a streetcar. |
ya i got a 5 speed
now i just have to find the fill and drain holes. |
#5 | ||
22mm on the rear of the transfer case, and the trans its on the drivers side. use 90W __________________ Wristy check the FAQ! 1980 RN37 ![]() ![]() 1989 RN101 1986 RN64 Quote:
Yup, pull the filler on the top, pull the drain plug on the bottom, go have a beer, make a sandwich and come back, put the drain plug back in and fill it back up until it starts to seep out the fill plug. replug, torque em down and you are good to go. i prefer valvoline 80w90 for my tranny, tcase and axles.
Thaxs for the tips guys!!
If there is ANY huge amount of resistance on that plug, heat it up so you don't risk ruining the bolt. I have experienced issues with drain plugs/filler plugs being seized when they have not been removed in a long time.
A six point socket is ideal as well. The filler/drain plugs, like the oil plug, is pretty soft and will strip easily. Just a forethought for you. __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
Myspace Backgrounds | Credit Cards | Mortgage Calculator | IDN domain | Credit Card |
