Old 05-07-08, 07:11 PM   #1
liljlandon is on a distinguished road
4.88's vs. 5.29s
I want a lower axle gear to tote around my camping/work supplies, but judging by the cost of them it would be cheaper to go with a 5.29 ratio. My problem is I am only running a 31x10.5R15 Trxus and dont know what each would bring me. I found a really good deal on a marlin crawler 4.88 3rd w/ a detroit but It would cost less for me to go 5.29 with lockrights f/r after i regeard to 4.88 in the front. I feel pretty good with my dad setting them up, but the main question I am trying to ask is, Is a 5.29 to low for a stock vehicle? or would fifth finally be usable, and honestly I could live with fifth being about the same as forth.
4th= 1:1
5th= 0.85:1
So would a 15% increase in gear ratio be enough
4.11x1.15=4.73
So in theory of that a 4.88 would actually make 5th gear feel a little lower than 4th.
So what do you guys think?
Im the lil landon (ironic name...)
hogansoffroad.com
^^^^^^^^^^Our Stomping ground^^^^^^^^^^
liljlandon is offline   Reply With Quote
Old 05-07-08, 07:52 PM   #2
Jetboy is on a distinguished road
I'd say 5.29 is just right for 35's. Way too low for 31's. Plus why not spend the $ on 4:1 t-case gears for the stock case, and drive in 4th on the highway? That way you'll have the low gears you want offroad and about the same highway performance. My opinion is that the transfercase is a better place to get your low gearing for offroad. For the highway I just don't see any benefit of puting it in 5th over 4th.
jetboy,
75-40
Jetboy is offline   Reply With Quote
Old 05-07-08, 08:21 PM   #3
Hilux's Avatar
TLCA# 9h9-69
Hilux is an unknown quantity at this point
put some 33's on it if you insist on the 5:29's
Personally I would not lug a truck I drive at all, for the sake of when I do go off roading.
If the 5:29 is more economical to you then its just an,...and a good one at that, excuse to get bigger tires. Then your clearance will be better off road....
still not sure if I understand you post though. See if this helps. Sit down with a pen and paper and you can SEE the RPM's the gears will be giving you at the speed you want.
Lifted v, and your OD ratio is different
Originally Posted by Hilux View Post
mph x final drive x O.D / (divided by) Tire dia x 336
Alright, now some things you need to remember here is 1: you cant put a gear in the calculator you think you running, it'll be inaccurate or wrong. Like I said. I use, .10 per 1" so because you are running a theoretical gear (not the true 4:11) adjust this to work in the equation. And 2: It's an equation for an SAE, its not for a metric tire so heres the formula for that:
tread width/ 25 x aspect : x 2 + wheel dia.
265/70x16
265/ 25 = 10.6 (which incidentally is the tread width in ")
10.6 x 70% = 7.42
7.42 x 2 =14.84
14.84 + 16 = 31.84 (which incidentally is the tires height in ")
see?
Now, "what would be my top speed with 4:88's??????????? 35mph?????"
Is that a trick question?
I'm assuming you mean rpm at 35mph with 4:88's and 33's, If I am correct here goes.
33 x 4:88 x .71 = 114.33 / 33 = 3.46 x 336 = 1,164rpm at 35 mph
And since the OD is most likely not on:
33 x 4:88 = 161.04 / 33 = 4.88 x 336 = 1,639rpm at 35 mph
And since it wont be in either one of those gears (OD or 1:1< 3rd) and I don't have the proper gear ratio's I cannot tell you the answer to that
Well snap,....ask and yee shall,......but I aint doing it!, uh uhh
A440F
Produced January, 1990 through July, 1992 on U.S. spec FJ80s
1st gear: 2.950 to 1
2nd gear: 1.530 to 1
3rd gear: 1.00 to 1
overdrive: .717 to 1
I'm too old school, I still hold a phone to my ear...
We're just one krappy Diesel away from another 30 years of gas ...the "6.2 Redo"
As soon as I figure out how to make a still, I'm
going to start making "Bio Gasoline"
lets see, corn, sugar...copper pipe...
Hilux is online now   Reply With Quote
Old 05-07-08, 08:38 PM   #4
Hilux's Avatar
TLCA# 9h9-69
55 x 5.29 x .85 / 31 x 336 = 2,680rpm's at 55mph
70 x 5.29 x .85 / 31 x 336 = 3,411rpm's at 70mph
55 x 4.88 x .85 / 31 x 336 = 2,472rpm's at 55mph
70 x 4.88 x .85 / 31 x 336 = 3,147rpm's at 70mph
55 x 4.11 x .85 / 28 x 336 = 2,305rpm's at 55mph
70 x 4.11 x .85 / 28 x 336 = 2,934rpm's at 70mph
You might not want to take my word for it. learn to do this yourself and you'll always know its right
Old 05-07-08, 09:29 PM   #5
well, id rather go dual cases than a 4.7, for many reasons, i would actually have hi, med, and low vs. hi and low.
I am a hardcore weekend wheeler, the truck gets me atleast 30 miles to school and then a 45 mile trek to work and back home a day, along the way I constantly am transfering from interstate to hills, and then riverbottom to stay out of traffic, and about once or twice a week i try to brinbg home loads of metal(reason i want more power). i can get around 23-25 mpgs if i leave it in 4th at 70-75mph. I figure if i can get the better take off and better gear widths then i should be set to go on these treachorus hils and keep the gas mileage by using my pretty much obsolete 5th gear. I have heard tghat the lower the axle gear the less stressful the shock is on the xcase.
And Hilux, i really got confused, wats the 336 for?
hogansoffroad.com
Old 05-07-08, 09:49 PM   #6
Hilux's Avatar
TLCA# 9h9-69
spedo corrrrected?
Heck I don't know, and dont care, all I know is it works
Old 05-07-08, 11:40 PM   #7
No longer pre-approved...
2ndGenToyotaFan's Avatar
2ndGenToyotaFan is on a distinguished road
I use 5th all the time and I'm pushing 33's with 4.10's.... Not up much of a grade, but it's still usable.
also, here's a helpful link:
Calculators from www.4Lo.com
Old 05-07-08, 11:52 PM   #8
Hilux's Avatar
TLCA# 9h9-69
Thats all well and fine but FYI you cant have 4:11's with 31's AND... 28's
Old 05-07-08, 11:58 PM   #9
What's the rest of that thought? Do you mean don't mix tire sizes? That's a rule regardless of sizes and ratios.....
Old 05-08-08, 12:09 AM   #10
Hilux's Avatar
TLCA# 9h9-69
I knew this was coming.
Heres my thought, say someone punches in they have factory gears and 31's. Is the answer that calculator is going to give be the same RPM's as with 4.56's?
IDK, but I don't think its right,
see what I'm saying? For example UserX punches in 31's w/ 4.11's b/c he didnt take the overall difference the added tire DECREASED his real gear ratio, didn't factor in "correction". Will the equation be accurate?
I think not
Old 05-08-08, 12:24 AM   #11
No, 31's with 4.10's and a 0.85 5th is 2077 rpm.... 4.56 is 2310
Yes, the rpm calculator works......
Old 05-08-08, 04:58 AM   #12
WarDamnEagle's Avatar
WarDamnEagle is on a distinguished road
No, 31's with 4.10's and a 0.85 5th is 2077 rpm.... 4.56 is 2310..
Which is why I'm buying TRD elockers with 4.56 gears to go with my 31" BFG MT tires.
Note: Jerod's figures above are for 55 mph. At 70 mph it's 2644 rpm with 4.10's and 2941 rpm with 4.56's.
1985 4Runner - first round of upgrades finished!
1997 FZJ80 - locked and stock
2007 HDJ100 - DD
WarDamnEagle is offline   Reply With Quote
Old 05-08-08, 06:42 AM   #13
spedo corrected?
Thats factored in, the odo is off by 33%, so if i drive 20 on the odo im actually driving around 30. So i multiply my trip meter by 1.33 to get my actual mileage and divide by my gallons
usually i get 270-300ish off of 12-13gallons.
Also, once i factor in the difference of my original tire size it says my current axle ratio is 3.70
original 28
new 31
gears 4.10
new axle ratio 3.7032258064516123
Same as above using 4.88 gears
new axle ratio 4.4077419354838705
I actually come out a bit lower, which is what i want.
I dont think that the my tach is right, because according to that i should push 2800 rpm at 75 in 5th (.85) while i actually push more to the 3300 side.
4th (1:1) at 75 is 3332 while my tach says around 3800.
Can my tach be that far off?
Or have my gears been changed by the PO?
Ill check when ever my new seals get here from man-a-fre.
Thanks for all your help
hogansoffroad.com
Old 05-08-08, 07:06 AM   #14
I don't think your odometer is off by 33%. By my calculations it's off by 10.7% so you should multiply your odometer mileage by 1.107 to get your actual mileage.
The above assumes exactly 31" OD tires vs. exactly factory 28" OD tires with no other changes to the vehicle.
Or have you checked your odometer with a GPS and know for a fact that it's 33% off? (Which means that something else has been changed, like gears, or your speedometer doesn't work properly.)
2007 HDJ100 - DD
Old 05-08-08, 07:22 AM   #15
original 28
new 31
gears 4.10
Doh, WDE beat me to it while i was looking for the color codes.
I'm confused by your math. With 31's, assuming you have a 4x4, you're not off by 1/3 on the spedo. Stock 235/75/15's are 28.9" so figure 29" to make the math easier. So one rotation of a 29" tire is 91". One rotation of a 31" tire is 97.34". So we're talking about a 9.3% difference. When you're spedo says 20, you're going 22mph, not 30. To get that far off you'd need 38.5" tall tires. I think that's why you think you're getting that good of mileage. Borrow a GPS and test it. I'm guessing you'll find your a lot closer to the spedo than you think.
If your engine is healthy, you should not have a problem with 31's.
I don't really care what you do, but I can tell you from experience that 5.29's work great for 35's and will be too low for 31's. That's what I had on my 84 pickup. And that's in Montana at 6,000 feet with mountain passes. I've also had 31's on my 84 stock with 4.10 gears and thought it was about right. I currently have 38's on my Landcruiser and 5.29's and they are actually a little low for highway cruising. It also had 4.11 stock gears.
Also, FYI, if you have stock gears you can check the ration by the color of the marking paint on pinion without pulling the 3rd members.
Table: Ring and Pinion ratios
Color
3.42 Purple
4.10 Pink
4.11 Orange
4.30 . . Blue . . .
4.37 Green
4.56 Yellow
4.88 White
jetboy,
75-40
Old 05-08-08, 08:10 AM   #16
Yeah, 31's are 10% bigger, not 33%. Which means your mileage isn't as good as you think.....
Old 05-08-08, 08:55 AM   #17
cokidva is on a distinguished road
just read this post... my head hurts
85 turbo mini locked and loaded with a tightened arse! SOLD
95 FJZ80 Lockers OME
cokidva is offline   Reply With Quote
Old 05-08-08, 09:59 AM   #18
Hilux's Avatar
TLCA# 9h9-69
x3.14
original 28
new 31
gears 4.10
4.10 x 75 x .85 / 31 x 336 = 2,832rpm's at 75 mph 31's 4.10's
Dang! now I remember.....I used to have the tire size (or was it rpm's??) to miles formula!...It made it real easy to see the difference they made up in ONE mile shocking.
it had pie (3.14) in it and the # feet in a mile IIRC, but its burried in about 100 magazines
Old 05-08-08, 12:18 PM   #19
That was all good informatiion Jetboy so I don't want to split hairs with you but stock (I think this is on an 84 Hilux) was P225/75R15 which is more like 28.3". OK, maybe I am splitting hairs....
2007 HDJ100 - DD
Old 05-08-08, 12:20 PM   #20
douglashuft's Avatar
TLCA# 13623
douglashuft is on a distinguished road
You can buy used factory 3rd members in 4.88 ratio (for cheap) and it will buzz along the highway with 31's or work well with 33"s. I would not bother with 5.29's unless i had a 35" or larger tire.
Doug
-Bone stock 94 22re mini (except for bumpers, sliders, skidplates, rear locker, 1" body lift w/trimmed fenders and 33" tires. IFS still works
-Locked 93 fzj80, OME medium, deflared/linered, metaltech sliders, 285's, family tent trailer tow vehicle
-She got the 89 fj62, I got the house
douglashuft is offline   Reply With Quote
Old 05-09-08, 05:55 PM   #21
No, i have not used a gps unit, what i have done is matched the distance traveled to the nearest mall with my grandpas 07' chevy, his odo had 48, mine had 36 and google maps had 47.4
48/36=1.33
so i multiply by 1.33, i know my speedos off but know one around here really cares to give me a ticket if i am speeding..
I think im going to go with 4.88s and zing everywhere!
hogansoffroad.com
Old 05-10-08, 12:41 PM   #22
fortysixandtwo's Avatar
fortysixandtwo is on a distinguished road
I would NOT run 529s with 31s unless you plan to get at least a 35" tire in the near future. Before I bought my 35s i ran 529s for about a month with 31s. It SUCKED. felt like i was driving a drag yota. I maxed out at about 45-50 mph in 5th gear and that was damn near red lining it.
If you really want to get 529s get 35s. I think 35s are the minimum for 529s and even then they are more optimal on a 37+ tire.
1985 4Runner SR5 with the usual goodies.
fortysixandtwo is offline   Reply With Quote
Old 05-10-08, 01:53 PM   #23
There is a thread about this stuff in the FAQ, spells it out pretty good.....
Jerod
