Old 04-30-08, 06:38 PM   #1
theside00's Avatar
Embarassing to ask this but got to
This is a rookie question but I am in it this far and want to make sure I get it right.
The side of the head gasket that has the most metal points up toward the head, and the side with no metal goes onto the block correct?
Had to buy a new head but everything is going back tomorrow and hopefully running by tomorrow night.
theside00 is offline   Reply With Quote
Old 04-30-08, 07:29 PM   #2
WristPin's Avatar
I iassume you mean the d shaped oil retun port with the copper insert? yeah. that goes up. and if you would have waited to ask this after you tried installing it, you would have realized that it only goes on one way.
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Originally Posted by Rezkid View Post
ridin quads and blastin' mofers...life don't get much better than that
Originally Posted by chesshircat View Post
Found my Haynes manual, shoved it under the leg of my bench to level it out.
Old 04-30-08, 08:20 PM   #3
No longer pre-approved...
2ndGenToyotaFan's Avatar
Oh man!!! Ahh good stuff. Seriously, there's no stupid questions, only stupid people (who don't ask questions when they don't know something...) Glad you had the juevos to ask. And as Wristy pointed out, Toyota in all their wisdom made it so you can't install it wrong.... unless you're blind, in which case you shouldn't be working on an engine alone anyhow.
Old 04-30-08, 08:50 PM   #4
Have a Coke and a smile:D
bigndn's Avatar
TLCA# 18682
Yes it is a rookie question.
Chad
1976 FJ40: TBI350/SM465/SOA/SR/37's/ARBs/30-Longs/Metal Tech/SROR/Oeyes
1985 Toy Hilux: 6" lift/4.3L/R150F/Marlin's DUC/ARBs/30-Longs/5.29s/37's/Oeyes
2005 Dodge Ram 2500 CTD bullydogged, airlift
There's plenty of room for all of God's creatures, right next to my mashed potatoes!
Originally Posted by Mrs bigndn View Post
If it's got knockers or lockers, he'll be checking it out."
bigndn is offline   Reply With Quote
Old 04-30-08, 09:02 PM   #5
theside00's Avatar
Thanks for the answer probably could have test drove it.
Also another question how do I change the bearings in my muffler
Old 04-30-08, 09:04 PM   #6
theside00's Avatar
I got one from toyota and there is quite a bit of metal on the top of it. It is on the sides covering the water holes.
Old 05-01-08, 11:34 AM   #7
theside00's Avatar
I was reading some more stuff and somebody says that it says in the FSM that you should put some gasket maker around the timing chain cover? Anybody heard of this.
Old 05-01-08, 11:46 AM   #8
WristPin's Avatar
yes. Jukelemon asked a Q about this the other day.
anywhere two ends of metal meet, you use FIPK there. such as on the corners of the upper side of the timimg cover to the head.
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Old 05-01-08, 11:54 AM   #9
theside00's Avatar
Thanks I will just lay the head gasket down and fill in any bare metal spots with the good stuff
Old 05-01-08, 01:07 PM   #10
WristPin's Avatar
where i just described would mean you apply the fipk on the underside of the gasket.
i wish i had an engine apart, to take some pics.
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Old 05-01-08, 02:32 PM   #11
theside00's Avatar
All right I think I am catching your drift on this one. There was some silicone in a horseshoe shape around the TC cover but not going in between the cylinder and the TC. Should I just redo this? didnt leak or hurt anything before.
Old 05-01-08, 06:14 PM   #12
WristPin's Avatar
here is an actual picture of my uhhh 23RE
see the arrows? it puts the lotion on its skin, or else it gets the hose again.
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Old 05-01-08, 06:16 PM   #13
WristPin's Avatar
if you want to redo where you found silicone, that will be fine. the idea is to not put too much on anywhere, so it dosent clog an oil passage
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Old 05-01-08, 08:16 PM   #14
Where's the laughing a$$ off fist-pounding smiley? Did you do that drawing in CAD? oh man..... good stuff!
Old 05-01-08, 08:36 PM   #15
WristPin's Avatar
hehehe
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Mobile Phones | PrePaid Credit Cards | NJ CoLocation | Mortgages | Compare
