More timing chain questions...where to seal
Hi all.
Did you guys use FIPK on the bottom and top of the TC cover? I am assuming so since there is no gasket for that area. __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
#2 | |
you are supposed to put where any two metals join. such as the corners of the timing cover, on the top, where it meets the head.
since the oil pan is sealed with the FIPK, you use it all around the lower portion of the timing cover. I have put it all around the top side of the cover, so the head gasket stays put when assembling. no leaks! __________________ Wristy check the FAQ! 1980 RN37 ![]() ![]() 1989 RN101 1986 RN64 Quote:
Right. So, anywhere that a gasket is not used.
That is what I assumed. __________________ "May you be in heaven a half an hour before the devil knows you're dead" 1992 4x4 PU |
TLCA# Don't have one yet, but Rising Sun CO will be my domain
Anywhere a gasket isn't used would be correct. I actually did my last one entirely with FIPK (not reccomended) and it worked just fine. I put it on and let it set up for about 15 minutes before install, not sure if it helps or if it's a bad idea but it becomes a lot less liquid-ish.
__________________ 86 4Runner, stock, and clean......for now |
#5 | |
#6 | |
check out the embarrasing question thread. i took a high res pic of my engine for you and theside00
Thx man
Fodbold | Loans | Remortgages | Credit Cards | Loans |
