Old 04-29-08, 08:25 PM   #1
the truck doctor's Avatar
the truck doctor is on a distinguished road
DIY front drive shaft
Is it or would it be feasible to make a square tube front driveshaft using two cardan joints one on either end with 5" of lift?
the truck doctor
the truck doctor is offline   Reply With Quote
Old 04-29-08, 08:46 PM   #2
WristPin's Avatar
WristPin is on a distinguished road
search square driveshaft
http://forum.ih8mud.com/79-95-toyota...are+driveshaft
i am going to build one soon
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Originally Posted by Rezkid View Post
ridin quads and blastin' mofers...life don't get much better than that
WristPin is online now   Reply With Quote
Old 04-29-08, 08:48 PM   #3
toyminator's Avatar
TLCA# 17965
toyminator is on a distinguished road
As long as your not going to ever need 4wd over 30mph. They are a bit noisy too.
1989 Toyota Pickup - 255,xxx miles, SAS, Bed Bobbed 14", 95 4Runner front clip, Hanemman Fiberglass front fenders, All Pro 5.5" lift, Hi Steer, 5.29 gear rear Detroit locker, front ARB locker.
1988 4Runner - Blown up 3.0 V6
1999 4Runner SR5 Sport Edition
1992 Lexus SC400
toyminator is offline   Reply With Quote
Old 04-29-08, 11:43 PM   #4
WristPin's Avatar
who does that? 4WD is about control, not speed.
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Old 04-30-08, 10:12 AM   #5
Hilux's Avatar
TLCA# 9h9-69
Hilux is an unknown quantity at this point
This is not for AWD rigs and possibly snow and sand, anywhere your speed is erratic.
The reason I said snow is because I like to lock my hubs in the event, and I can choose to engage 4WD or in dry, higher speed areas 2WD. If your hubs are locked or AWD the shaft will spin. It don't take no Rocket scientist to know the square tube shaft is not balanced, and will shake your teeth out at speed.
Its a great, simple, get you home in a pinch, mod that IIRC the first article I saw it in, the guy had it where it could work in the front or the rear
He only needed one spare.
I'm too old school, I still hold a phone to my ear...
We're just one krappy Diesel away from another 30 years of gas ...the "6.2 Redo"
As soon as I figure out how to make a still, I'm
going to start making "Bio Gasoline"
lets see, corn, sugar...copper pipe...
Hilux is offline   Reply With Quote
Old 04-30-08, 08:39 PM   #6
missouriman is on a distinguished road
use just a u joint on each end. you will not be running in 4 wheel drive over 30 I hope. I wish that I had with my wifes and may redo it.
when I unbolt the drive shaft it binds up about 6 inchs below the diff. I would like more movement then that.
I also ran three lines of braze down each side.. not rattleing yet!
had to grind the brass a bit so it would slid in nice and tight.
line this part up square for phasing. This is a short piece of the inner to line up the larger outer. just weld the inside.
oh and the sliding end of the outer shaft. don't leave a sharp edge. grind it out to a pretty good ramp. so when you drop it onto a rock it won't bind up.
missouriman is offline   Reply With Quote
Old 04-30-08, 08:42 PM   #7
oh here is a schedule 40 rear shaft thickness.
heck to balance,, will have to do a redo on this one some time.
vibes pretty bad at 50 to 65.
Old 04-30-08, 10:29 PM   #8
this is for my project 87 trail only truck. so a lil vibrating is ok not gunna be haulin ass on the trail. reason I ask about the two cardan joints is to gain a lil more angle if that makes sense?
the truck doctor
Old 05-01-08, 05:44 AM   #9
actually the angle in the one picture is about the limit of the dual joint.
Old 05-06-08, 06:12 AM   #10
Albin is on a distinguished road
How I did mine, no double carden unit. No vibration up to about 50 mph, although I rarely take it that high in 4wd.
http://www.rocketcityrockcrawlers.co...%20Project.pdf
Good luck.
Al
'85 4Runner
Albin is offline   Reply With Quote
Old 05-06-08, 10:52 AM   #11
cokidva is on a distinguished road
Nice write-up Albin. I'm doing mine tomorrow evening so I can wheel this weekend. I'll still vibrate with the rear for a while until I can get that CV done but in due time!
cheers
85 turbo mini locked and loaded with a tightened arse! SOLD
95 FJZ80 Lockers OME
cokidva is offline   Reply With Quote
Old 05-06-08, 04:12 PM   #12
rockrash's Avatar
rockrash is on a distinguished road
One of the guys that I work with built his out of a pto shaft.That might be another option also if some of you country boys have them laying around.
rockrash is offline   Reply With Quote
Old 05-06-08, 09:34 PM   #13
liljlandon is on a distinguished road
My dad brought that to my attention, as we were shopping in Tractor Supply for parts on our buggy when there was a 4wheelparts across the street, funny thing is, the cashier says he sees more people with 4wheeldrives in there than at the 4wheelparts store...
Im the lil landon (ironic name...)
hogansoffroad.com
^^^^^^^^^^Our Stomping ground^^^^^^^^^^
liljlandon is offline   Reply With Quote
Old 05-10-08, 12:45 PM   #14
fortysixandtwo's Avatar
fortysixandtwo is on a distinguished road
Nah. I have done about 55 MPH in the snow in 4 high with a square front and it wasnt loud nor did it vibrate at all. Mine makes a clank clank from time to time and thats it. If you make your shaft very precisely they wont make much noise at all. my friend made mine for me and it was probably his 9th or 10th that he made. very quiet, very little vibration.
1985 4Runner SR5 with the usual goodies.
fortysixandtwo is offline   Reply With Quote
Navidad | Loans | LCD TV | Mortgages | Bollywood India forum movie reviews
