Old 04-28-08, 11:07 AM   #1
TLCA# 12411
Idle Speed Adjustment
My recently-acquired '93 pickup seems to be idling kinda high. I was gonna check the speed with my tachometer, but can't find a tach wire on the igniter. I assume I need to use one of the wires in the diagnostic box, but which one? It's a 22RE.
Thanks.
Trevor is offline   Reply With Quote
Old 04-28-08, 03:49 PM   #2
Jukelemon's Avatar
One of two ways.
You either connect your test probe to the - (neg) side of the ignition coil or to the IG terminal on the check connector. The other side of your tach goes to the - and + of the battery.
This is what the FSM states for a 92 which should be the same for a 93.
You MUST have a tach compatible with a Toyota ignition system.
Juke
"May you be in heaven a half an hour before the devil knows you're dead"
1992 4x4 PU
Jukelemon is offline   Reply With Quote
Old 04-28-08, 08:07 PM   #3
TLCA# 12411
Originally Posted by Jukelemon View Post
One of two ways.
Juke
Thanks, Juke. My tach directions show a diagram for '86 and '87 Toyotas only. I dunno what makes '86 and '87 so special. Maybe the tach directions were printed in '87.
Wristy: Thanks for nothing. I did a search. I find your avatar offensive, too.
Old 04-28-08, 08:23 PM   #4
No longer pre-approved...
2ndGenToyotaFan's Avatar
Easy Boys....
The idle adjust screw is on the intake right near the throttle valve, it's a big flathead screw and I think in is idle down...
Old 04-28-08, 08:32 PM   #5
WristPin's Avatar
i dont mean to be a jerk. sorry
can we still be friends?
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Originally Posted by Rezkid View Post
ridin quads and blastin' mofers...life don't get much better than that
Originally Posted by chesshircat View Post
Found my Haynes manual, shoved it under the leg of my bench to level it out.
Old 04-30-08, 10:47 AM   #6
Jukelemon's Avatar
I would call the company who makes your tach and ask them if there is compatibililty for the 93. I could not say what the difference, if any, would be between the years of the 22re.
1992 4x4 PU
Compare | Cash, Cars & Babes | Refinance | Gas Electricity | Online Dating
