Old 04-26-08, 06:39 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
WristPin's Avatar
Wristy's 1980 Meatmobile build up
I decided to bob the bed. started with the frame. cut off the tails. welded in a 2.25" square tube. I pounded down the spare tire hangar, then once it was all welded, i pounded it back up and made a few welds under it. I used some angle 3/16" thick around the corners of this tube. I wasnt to worried about the heat affecting the bushings. i loaded em up with grease inside and out the other day. since i didnt see any boiling out, they will be just fine.▼▼▼
This is for the bob, and also, im going to do more reinforcing on the side. im going to use the same square tube to make an additional cross member on the other side of the spare tire hangar, then take another piece and run it length wise. that way, once i make a winch plate with a receiver hitch, it'll have some strength behind it.
also upon my discovery of my frame problem. i noticed cracks on one side of the rear spring, front hangar.
i made some gussets out of 3/16" steel and welded them in. i turned up the welder as hot as i could to get deep penetration. and surprisingly, as rusty as the inside is, the frame did not burn through.▼▼▼
i am out of some of the steel, so i havent started on the frame patch. i have cut out many pieces, so once I do it, this part here will no longer be a weak link. even tho the other side has slight problems, im going to do the same thing to it. ▼▼▼
I still have the front spring hangars to work on. im going to beef the hell out of those too. once this is all done, the frame is gonna be so much beefier than it ever was. since i never had decent recovery points, this work is really gonna pay off. i have a few D ring shackles to weld on, and some hooks. Im gonna do the same type of hitch setup for a winch as i am doing for the rear.
Wristy
Jebus...
I like it when I can go out on the porch buck naked ...unroll it and take a wizz without somebody saying ......look john is alive and well
22RE Tech hotline- check the FAQ
Old 04-26-08, 10:27 PM   #2 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
That should hold 'er.....
2ndGenToyotaFan is online now   Reply With Quote
Old 04-26-08, 10:31 PM   #3 (permalink)
WristPin's Avatar
im hoping for the best.
I got a lot done on the front.
DAMN I wish i has a plasma cutter, or even a torch.
I am gonna do it all over kill.
(but not so much where I have 500 extra pounds)
Wristy
Jebus...
Old 04-28-08, 04:59 PM   #4 (permalink)
WristPin's Avatar
bed has been bobbed 13"
yeah. thats my hot wheels set in the backround
Wristy
Jebus...
Old 04-28-08, 05:01 PM   #5 (permalink)
WristPin's Avatar
at first i was going to put some bondo in there. but since there is none to be found in my shop, and i dont really feel like doing it, and since id rather not see it get water logged and chunk out or bash it on the trail and chunk out, I have decides to just paint over it.
Wristy
Jebus...
Old 04-28-08, 08:29 PM   #6 (permalink)
WristPin's Avatar
I finished the rear plow:
Wristy
Jebus...
Old 04-28-08, 08:30 PM   #7 (permalink)
WristPin's Avatar
by the way those weenie 31" tires are on it so its easier to move around till I get it all done. then the 35" tires go on.
Wristy
Jebus...
Old 04-28-08, 10:02 PM   #8 (permalink)
Valmorphanize!
valentine's Avatar
Nice progress.
Maybe one of these days I'll get off my ass and head on down there to give you a hand...
TLCA # 11402
97 FZJ80
94 FZJ80 Lifted & Locked
87 Land Cruiser FJ60
84 Toyota long bed P.U. {stolen} RIP
08 KLR 650
70 CT90
"The truth is NEVER hate" dieseldog 10-21-06, 11:00 PM
I am the Shadow Ninja
TUTotals
Originally Posted by Lupdog View Post
It's great to be a public nuisance!
Originally Posted by stinkyfj60 View Post
A tank full of napalm,
Suicide Girl
shotgun. Tercel smokes tires.
Originally Posted by yooper View Post
It's not all rainbows and butterflies in the Eastern Time Zone...
Originally Posted by Jman View Post
Why, yes, I would attempt to inject my DNA into that.
valentine is offline   Reply With Quote
Old 04-28-08, 10:16 PM   #9 (permalink)
WristPin's Avatar
you just need to get down here so we can scout some wheelin spots and find a place to kill clay pigeons.
Wristy
Jebus...
Old 04-28-08, 10:23 PM   #10 (permalink)
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Garage
Wristpin
Can you exlain your theory on your rear shackle angle? Shouldn't the rear perches be further forward?
Land Cruiser Garage Sale Items <- Link
Get Your Marlin ToyBoxes Now!
Beagle Chariot
1962 FJ40
1964 FJ 40
1968 FJ 40 <- For Sale
FJ 40.5 Build 4BT Cummins Conversion
1976 FJ 40
SPEN Trailer
D'Animal is online now   Reply With Quote
Old 04-28-08, 10:48 PM   #11 (permalink)
WristPin's Avatar
the perch location is stock. the spring length is stock. the stock shackles i removed set vertically, just like these longer ones I have now.
the trucks that use the longer 63" chevy springs, often I see with the shackles pointing at an angle, when just sitting on flat ground.
when my spring compresses, the shackle will extend out at a simalr angle to the ones with 63" springs.
does this answer your question?
Wristy
Jebus...
Old 04-29-08, 09:43 AM   #12 (permalink)
amgraham's Avatar
I think he's referring more to the fact that ideal shackle angle is around 45* to the rear. Here's mine when I still had stock shackles and AALs:
I don't know why yours sit upright like that.. I guess because of the arch of the springs. Once you get some weight on them and flex them out it should get better though.
1987 Toyota 4Runner
Specs Here: 4Runner Page
amgraham is offline   Reply With Quote
Old 04-29-08, 10:15 AM   #13 (permalink)
bigndn's Avatar
Location: where men are men and metrosexuals better be making me a CapMo.
TLCA# 18682
Garage
Where do I sign up? Sounds like fun! Nice work on the truck, Wristy! Need some flex shots ASAP.
Chad
1976 FJ40: TBI350/SM465/SOA/SR/37" MTRs/ARBs/30-Longs/Metal Tech/SROR/Oeyes
1985 Toy Hilux: 6" lift/4.3L/R150F/Marlin's DUC/ARBs/30-Longs/5.29s/37" KM2s/Oeyes
2005 Dodge Ram 2500 CTD bullydogged, airlift
My views on Animal Rights: Animals have the right to be tasty.
Originally Posted by PhilC64 View Post
Try the finger cots. They'll give you a bit more room and won't chip your sisters teeth.
bigndn is online now   Reply With Quote
Old 04-29-08, 12:50 PM   #14 (permalink)
WristPin's Avatar
all of the springs are brand new. I havent moved the truck more than back and forth outside my shop since i installed them. once i am completely done, i will get some flex shots, and maybe that shackle will start to stick out.
Wristy
Jebus...
Old 05-02-08, 09:44 PM   #15 (permalink)
WristPin's Avatar
got more werk done.
i used naval jelly to kill the rust on the inside of the frame. i got most of it. certain parts i couldnt access.
i used rustoleum brand rust primer/stop rust/sealer. it has some kind of goo in the bottom that had to be mixed really well. i got a can. the other paint cans weighed much less than the rust primer.
i figured i should paint the entire area, and just remove what i had to later to weld. the primer stuff smelled really good going on, but once i started welding- PPPEEEEWWWWW. that stank.
i used 2x3/16 angle to box in the frame. i boxed all the way around, this was a halfway boxed pic.
there are so many holes in this frame. why there are so many is beyond me. i understand a few, so it can be maneuvered in the factory, but c'mon this is ridiculous! so i am on another quest to seal off every one of em, so more mud wont get in ther and cause more damage.
i mean, i would really have to start washing my truck after every time i go kill some mud. i werk hard to get that mud on there, you know?!
over top of the ancle i cut and bent some 3/16" sheet to kind of match the contours.
inside the crossmember, was really hard to clean out, so i hope this will hold. i used a peice of 3/16" sheet that i bent to fit.
no, thats not a missing weld vertically, there is a 1/4" gap between the plates. later i will put another 3/16" plate across it.
after i was done for the day, i ate some
mmmmmmmmmmmmmmeat.
Wristy
Jebus...
Old 05-02-08, 10:55 PM   #16 (permalink)
Dain Bramaged Member
rusty_tlc's Avatar
TLCA# 15069
Originally Posted by D'Animal View Post
Wristpin
I saw that too. Keep in mind there will be more of a load once he gets the body back on, plus the suspension will settle out over time.
Dan Johnson
What the large print giveth, the fine print taketh away.
Battle Born Cruisers
1975 FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
1998 pair of Pink Panties, now with a doohicky in the front.
1984 FJ60, Detroits F&R and a gawd awful spring lift.
Rust never sleeps.
rusty_tlc is offline   Reply With Quote
Old 05-02-08, 11:12 PM   #17 (permalink)
while were on the subject, can anyone tell me why a vertical shackle is so popular?
I see them on EVERY Aussie rig I've ever looked at. Truly a W.T.F.
I cant figure out why this would be intentionally, seems as though its in the most prominent off road country's or areas. Do they know something I dont?......Like how and where to achieve useless flex?
The Man-a-Fre catalog is full of pics of them.
.another case in point
A visitor from the past
Hilux is offline   Reply With Quote
Old 05-02-08, 11:17 PM   #18 (permalink)
WristPin's Avatar
I always thot it was normal. I never paid much attention to it. I can totally understand why mine are like that now, new springs, never driven, never loaded down. they are stock length. I made sure they werent too short.
now that it seems abnormal, im gonna be checking them all out
Wristy
Jebus...
Old 05-02-08, 11:19 PM   #19 (permalink)
WristPin's Avatar
damn i want to finish this all up. there is never enuff time in the day, you know?! i want to go kill some mud!
Wristy
Jebus...
Old 05-03-08, 12:12 AM   #20 (permalink)
Jonathan_Ferguson's Avatar
TLCA# June 9th, 2002
Most are like that, mine is not one of them.
They are like that in Australia because most Australians make their junk into posers rather than wheel 'em.
1986 Nuclear Reactor
1985 Toyota LN65R
LIFE AIN'T WORTH LIVING WHEN YOU DIE BEFORE YOU'RE MEANT TO!
Jonathan_Ferguson is offline   Reply With Quote
Old 05-03-08, 12:14 AM   #21 (permalink)
User title
gladly's Avatar
TLCA# 16087
because an extended shackle is a really easy way to gain a couple of inches of lift
mine are near vertical, the ride might be better if they weren't, but now I can clear a larger tire and get better highway speed with lower RPM, and I think I spent under a hundred bucks
It's not The Adequate Thread.
_______________________________________
1975 fj40
2003 xr400
gladly is online now   Reply With Quote
Old 05-03-08, 12:21 AM   #22 (permalink)
User title
gladly's Avatar
TLCA# 16087
I wouldn't worry about it until you have it all back together, and get some miles on it, if they are new springs, they'll probably settle some, and if you compensate now, they could end up maxed out against the frame by the time they fully settle.
1975 fj40
2003 xr400
Old 05-03-08, 07:50 PM   #23 (permalink)
ToyotaNick's Avatar
since ya'll are on the subject of shackles. i have been thinking about putting inch and a half ball joint spacers on my truck and im wondering if i can use a longer shackle in the rear to level the truck out with the front. im am prety sure the shackle that i have right now is stock. O, also, how much longer will i have to make the shackle to get an inch and a half of height out of the truck?
1990 black toyota pickup body
1993 toyota 3vz-e 3.0 v6 engine
1994 3.0 v6 frame and suspension
4runner seats and center console
COMPLETELY different interior
9inches on 38x12.5x15 TSL SX's
IT IS CALLED THE PRETTY YOTA
ToyotaNick is offline   Reply With Quote
Old 05-03-08, 10:01 PM   #24 (permalink)
WristPin's Avatar
4Crawler's ball joints are what a lot of people are using.
Marlin Crawler :: USA Shackle Kits, Daystar Performance Bushings sells shackles.
1"-2.5" of lift
a 5" shackle will give you 1.5" over stock.
Wristy
Jebus...
Old 05-06-08, 07:03 PM   #25 (permalink)
ToyotaNick's Avatar
just to make sure, what is the length of the stock shackle on the rear of a 1994 ext pickup?
Old 05-06-08, 11:36 PM   #26 (permalink)
dizzidave's Avatar
As far as I know, a rear shackle lift should be fine, perhaps a bit stiffer of a ride. I'm pretty sure you will need approximately 3" longer shackles for an approximate 1.5" lift.
dizzidave is offline   Reply With Quote
Old 05-11-08, 08:18 PM   #27 (permalink)
WristPin's Avatar
rear half of frame is all done. i made a new wire harness, too.
then make a cool skull stencil, and made skull camo. what do you think??
Wristy
Jebus...
Old 05-11-08, 11:54 PM   #28 (permalink)
Oh nevermind......
TLCA# 13872
Anti Honda League? Is that a personal affront? The skull camo is badass!
Old 05-12-08, 12:50 PM   #29 (permalink)
Rookie
Skull camo is badass but what really got me was the big ass Misfits Fiend skull on the tailgate. I have been trying to figure out what to do with my bed and bumper and I think I found it! As long as you dont mind me mooching off your ideas. I have a bunch of rust above my wheel wells so I was thinking about tubbing them to accomidate bigger wheels but Im still trying to figure out the lift/ wheel size I wanna go with. Props again bro! Will be looking foreward to progess. Oh ya, I dont think I will cover the bed welds either...looks tough like a scar.
darichmon is offline   Reply With Quote
Old 05-12-08, 01:01 PM   #30 (permalink)
WristPin's Avatar
Anti Honda league goes way back.
I made those stickers. I distributed them all over town.
I was gonna have em say Anti Tuner Leauge. But 2 T's just didnt fit.
(you know anTi Tuner ) I really have a problem with tuners. punk kids drive it like they stole it. you know. hondas, themselves are good cars.
Its ironic, actually. my truck is surrounded by hondas. its all i work on.
And thanks, Jerod. I'm glad you like the skull camo.
Wristy
Jebus...
LinkBack to this Thread: http://forum.ih8mud.com/79-95-toyota-truck-tech/218301-wristys-1980-meatmobile-build-up.html
Posted By For Type Date
ToyotaResources.com - Frame Rust - Repair or Replace? This thread Refback 06-24-08 04:51 PM
