03-29-08, 11:25 PM
Power window homebrew fix!
This is a drawing I made of 4 relays, desinged to work together so only 2 wires connect to a window motor. the poles + and - reverse, so the motor operates up and down.
I just wired this up in my truck for the driver window. it works good. it is important to wire it to switched power, cause two of the relays stay on while the switch is off.
You can use it for any power window.
you can substitute the 25A fuses for 15A or 20 A
while brewing this up, I could have used a switch, alone, but I get more satisfaction doing it my way.
Wristy
Originally Posted by cruiser88
Jebus...
 I like it when I can go out on the porch buck naked ...unroll it and take a wizz without somebody saying ......look john is alive and well
22RE Tech hotline- check the FAQ
03-29-08, 11:52 PM
its a lot cleaner looking once the circuit is built. you can see my test motor there, along with the momentary double throw double pole. you can use a momentary double throw single pole, if you want.
im no artist, i know the drawing is kind of sloppy. but the effectiveness of the circuit is 100%!
Wristy
Jebus...
04-01-08, 09:16 PM
I did it using 2 DPDT relays. Same thing I guess
YANKEETOYS.ORG
Member of the elite FJ25 club
Low range? We Don't Need No Stinkin' Low Range
Why would you want to put a round tire in a square wheel well?
09-18-09, 06:50 AM
Where do you mount the new switches?
Where do you mount the relays, how do I know what relays to purchase?
How do I get to the motor in the sun rooof?
09-18-09, 07:30 AM
I must have missed the "Why do this?" part of the thread. LOL
09-18-09, 08:32 AM
I believe this is to replace the relays that make the rear window work, they tend to fail eventually. Mike's solution is much more durable. I don't like Wristy's "2 relays stay energized" method, but eh... it's not that big of a deal.
For relays that matter, I go to McMaster-Carr. Stay away from the crap that Radio Shack sells.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
09-18-09, 10:54 AM
Well that I could see but Wristy said "driver's side window" which is why I asked.
09-18-09, 12:33 PM
why i did it cause the PO jacked up the window sw so bad i didnt have all the parts to fix it, and it the wires to it were so jacked up i didnt wanna deal wit it so i cut em out and ran the new ones.
i linked this thread for the newb so he could get an idea of how to fix his deal. DUH! L  L
Wristy
Jebus...
09-18-09, 12:38 PM
i designed the circuit to alternate polarity. it can be used on any motor
Wristy
Jebus...
09-18-09, 12:42 PM
#10 (permalink)
[QUOTE=victorbirdseye;4794648]Where do you mount the new switches? where ever you want
Where do you mount the relays, once they are taped up they take up some room. i mouned mine behind my stereo, kinda on the floor.
how do I know what relays to purchase? bosch style
How do I get to the motor in the sun rooof? pull the head liner, use some tools in the right spots
the relays use these numbered terminals. 30, 85, 87, 87a, 86
try frys electronics. or go to the junk yard and find some.
Wristy
Jebus...
09-18-09, 03:45 PM
#11 (permalink)
wouldn't it be simpler this way?
- 2 Bosch style relays, 1 switch
- motor has ground on both sides when relays aren't energized, switch provides ground to activate relay
- move the switch in one direction, 1 relay is energized and supplies power to one side of motor, other relay provides ground path - reverse scenario for the other direction
. . . is there any reason this wouldn't work?
You could have constant power to the relays with no battery drain
-Keith- kb3scj
'88 4runner SR5 - 3L 7MGE swap - Marlin HD W56 - 4.56 V6 Thirds, LSD up front - 33x10.5 BFG KM2's- home fab front and rear bumpers - NWMP 14 gal aux fuel tank
"Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
09-18-09, 05:08 PM
#12 (permalink)
the first relay for the up, is connected to 87 and when you switch to down, it remains in 87. you have to have the 87a in there cause these relays are normally closed in the 30 to 87 position.
looks yer design wont work. but i wouldnt mind building something similar
Wristy
Jebus...
09-18-09, 08:05 PM
#13 (permalink)
when you switch it to down the 1st relay is connected to 87 and ground, the second relay energizes and connects to 87a and voltage, so polarity reverses and the motor turns the opposite way - - this is actually a common dual relay power door lock circuit which reverses polarity to make the actuator move one way or the other based on switch input
-Keith- kb3scj
09-18-09, 08:17 PM
#14 (permalink)
hell you boys are making every thing so difficult. i have no drawings but all you gotta do is reach over with your left hand and turn that there cranky thing and the window goes up. unless you are a passenger then you have to use the right hand to turn the little cranky thing.
QUIT SUCKING MY OXYGEN
09-18-09, 08:18 PM
#15 (permalink)
but if you take the doors off your truck you do not have to worry about it at all.
09-18-09, 08:39 PM
#16 (permalink)
don't forget the latch and slide if you're in the back seat of a 1st gen 4runner
-Keith- kb3scj
09-18-09, 09:49 PM
#17 (permalink)
For relays that matter, I go to McMaster-Carr. Stay away from the **** that Radio Shack sells.
DigiKey Corp. also sells relays, switches and other electronic parts.
As the simple design just uses automotive relays I'd go that way and pick them up at the local auto parts store if they aren't priced insanely. If you don't want to bother with sockets, just get the blade type quick connect contact and use faston connectors. Automotive relays can be bought with a mounting tab in either metal or plastic.
This is a Tyco SPDT automotive relay, 30A @ 12VDC: Digi-Key - PB686-ND: If you go to the catalog page you will see sockets and terminals for them. Digikey is $2.93 each but orders under $25 are assessed $5 handling.
PS: don't forget to use dielectric grease on the contacts to keep em from corroding.
Sanity is for WIMPs.
09-18-09, 11:03 PM
#18 (permalink)
12 bolts and the latch and slides are on the saw horses.
09-19-09, 06:57 PM
#19 (permalink)
Intresting.....when I was using all my power windows I did things completly diffrent.
09-19-09, 10:07 PM
#20 (permalink)
F it! im breakin the glass out right now!
Wristy
Jebus...
09-20-09, 08:47 AM
#21 (permalink)
10-06-09, 08:58 AM
#22 (permalink)
this look like it would work just fine- are the stock switches ground-switched? if so, this is a fairly simple add-in. otherwise it is more difficult or you just have to add new switches.
either way- I'm getting sick of my 80's switches. they get wet (it rains here) and /or dusty and stop working. I clean them, they work for a while, but it always ends up failing in the end.
a couple relays would be a nice fix.
91 fj80 w/ 93 1HD-T. OME 850/860 w/ 1" front spacer, LEDs, HIRs, Geolander MT's 33x12.50r15, Tuffy center, ARB rear locker (in progress), in garage: lightforce lights, full rack, superwinch X9, maggiolina tent, hella horns.
ask me about Costa Rican Realty
10-07-09, 03:46 PM
#23 (permalink)
I just did this mod on my 80 passenger side window. It works much better now.
you can read about it here: http://forum.ih8mud.com/80-series-te...ml#post4856388
essentially: at the qd for the switch I cut the red wire and the black wire and the blue/black wire.
I put 2 relays w/ the following poles:
relay 1:
30: to black wire to motor
87: to +12v (from blue/black wire)
87a: to ground (new wire)
86: to ground (new wire)
85: to black from switch
relay2:
30: to red wire to motor
87: to +12v (blue/black wire)
85: to red wire @ switch
be sure you also reconnect the blue/black wire to itself. Ie: you're tapping into it for poles 87.
It would work even better if you ran +12v from a fuse from the battery. But I didn't do it that way 'cause I didn't feel like putting in the effort.
the window works better, both from the passenger switch and from the driver's seat.
the window lock no longer works (no loss to me).
enjoy
