steering rag joint.
out snow wheeling I noticed that my rag joint got really hot from the slow speeds, high rpm's and the header.
I removed it. I un bolted everything, beat the studs out, and turned it 90 degrees and it bolted right back up.. course the steering wheel needed adjusted. but no more rag joint to break. |
No longer pre-approved...
Got any pics Mark?
__________________ Jerod Online Toyota Parts Catalog!!! 89 4Runner "The James Caird" 01 4Runner, for my Jefferson State Cruisers |
no but I could take some of the parts and finished steering shaft.
Cool!
when snow wheeling I had a problem with my alternator.
while trying to fix it I was shocked at how hot the rag joint had gotten. I have a header and had been running 4000 to 5000 rpm now and then. it was WAY flexible and the steering felt a bit loose. I have been told before to remove it for rock crawling. when I took these pictures I notice the burned wire on my wifes truck. it crosses the rag joint. I am now wondering if that is the problem that Toyota's have with the starter not always working. the famous click click.. but nothing from the starter?? anyways. stock rag joint set up. ![]() there are two bolts and two studs. I removed the bolts and beat the studs out. turned the wheel 90 degrees and bolted it back up. the hole line right up. I would have left the studs, but they did not bolt down tight. so I just used the bolts. a little bit more vibration feed back though the wheel, but not bad. Now I don't notice it at all. ![]() ![]() the left over parts.
Debt Loans | Debt Consolidation | Mobile Phone | Loan | Loans |
