Newbie new clutch install questions
Well im putting a new clutch in my 4runner and I just got my old pilot bearing out. When I install a new one should I pack it with grease? Should I grease the throwout bearing or input shaft? Do I drive the pilot bearing on the inner or outer race? Sorry for all the questions, if there is anything else I should know please fill me in...
Thanks, Andy __________________ -89 4Runner V6 5spd 4inch lift 33's 4.88's 260,000 miles and running strong -72 FJ40 F engine 3spd Rust |
No, the pilot and throwout bearings are sealed, lifetime lubed.
I don't quite understand the other pilot bearing question. You install it in the cavity at the end of the crankshaft, at the back of the engine. Use a soft faced hammer to get it started, then seat it with a large socket that is about the same size. Do you have a Factory Service Manual? __________________ KB1OSF '87 Toyota xcab SR5 - SAS'd, stuff '98 Lexus ES300 '04 Toyota Highlander |
I always put a little grease on the inner of pilot bearing. thats what my dad always says to do...so I do it.
grease the shaft so that the throwout can move freely. to drive the new one I always use a piece of wood this will not hurt the bearing and will drive it in evenly. peace! __________________ 3 pickups....1 is under going surgury ![]()
OK, I'll try to answer these all in order.
1. No, no need to pack it with grease. The bearing itself is sealed for life, and the two mating surfaces are not meant to move within the housing or on the pilot shaft. If you do grease the outside or the inside of the bearing, you allow the increased possibility for a bearing to spin within it's housing or allow the Tranny input shaft to spin within the bearing. You don't want metal on metal movement where it has not been allowed for. 2. Throwout bearing same thing, sealed for life. 3. You can grease the input shaft very very lightly on the splines where the clutch disc rides, just to ensure smooth even release of clutch pressure and hence friction. Probably won't affect a single thing you will actually notice, other than slightly longer clutch life. The shifting will still feel the same. 4. Always drive in/press in a bearing by the side that has the resistance. If a bearing, like the pilot bearing, is being pressed into a recessed hole, then you apply pressure to the outer half of the bearing. If a bearing is being pressed onto a shaft, you apply the pressure to the inner half. You never want the force being applied "through" the actual bearing or you can damage them, rollers, needles, balls, whatever type. 5. Nothing else I can think of really. Invest in a set of brass drifts if you feel you'll be doing a bit of this kind of work, but if not, soft faced hammer, wood, sockets, what have you. Just don't use anything that is hardened like chisels or anything that is likely to transmit all the force instead of absorbing and distributing it. Good luck! __________________ 81 BJ60 Completely Gutted, Bobbed 33" 85 Toyota 4Runner 5" Lift, 33 BFG's, Custom F/R Bumpers with Swing out Tire Carrier, Warn 8274. Misc other stuff |
Personal Military Loan | Home Loan | Credit Cards | Bad Credit Mortgages | PSD to XHTML |
