Old 02-15-08, 12:59 AM   #1
Jonathan_Ferguson's Avatar
TLCA# June 9th, 2002
Bleeding the rear Load Sensing Proportioning Valve
As the Load Sensing Proportioning Valve doesn't have a screwable nipple, is the Bolt that sought of points downward do the deed?
1986 Nuclear Reactor
1985 Toyota LN65R
LIFE AIN'T WORTH LIVING WHEN YOU DIE BEFORE YOU'RE MEANT TO!
Jonathan_Ferguson is offline   Reply With Quote
Old 02-15-08, 02:50 AM   #2
inkpot's Avatar
TLCA# 10338
Howdy! My 85 pickup does have the normal bleeder nipple on there. I think it is aimed towards the front of the truck. Too dark to see right now, so I will check it in the morning. John
85 Toyota mini truck for chase/support!
CSC #41
inkpot is offline   Reply With Quote
Old 02-15-08, 05:52 AM   #3
H2o
TLCA# 15012
can someone post a picture of this setup? i bought my truck with a flatbed and was wondering what that looked like. right now, i just have a rod sticking out of the valve.
thanks.
1974 Black FJ40
1987 Green Mini Truck
H2o is offline   Reply With Quote
Old 02-15-08, 10:29 PM   #4
the truck doctor's Avatar
maybe this will help
The truck doctor
1989 excab 33" procomps E-locker
SAS'D 1987 excab 5:29's welded f/r,flatbed,35's 9.5xp wireless
the truck doctor is offline   Reply With Quote
Old 02-15-08, 11:41 PM   #5
1985 Toyota LN65R
Old 02-16-08, 04:48 AM   #6
Enlighten me fellas.
1985 Toyota LN65R
Old 02-16-08, 09:39 AM   #7
I'm freakin Irie damnit
ms018kmf's Avatar
Mine's slightly different for the year but I've got my bleeder by that part of the LSPV. Both year LSPV's seem to have the other lines running the same. It looks sort of like the red circled part used to be the nipple.
1994 Pickup 3.0, Total Chaos Caddy kit, Bilstein 9100's front/7100's rear, Centerforce Dual Friction, Red Optima, Flex-a-Lite Fan, TC Idler Arm, TC Diff Crossmember, Marlin rear bumper, fresh Toyota HG's with DOA Head Studs, Amsoil Synthetic Fluids everywhere and 33 BFG Muds.
If grandma had wheels she would have been a streetcar.
ms018kmf is offline   Reply With Quote
Old 02-16-08, 09:52 AM   #8
Yup, mines the same.
Looks like the red circle in the photo is the bleeder.
Maybe yours broke and someone simply replaced it with a bolt.
Hard to tell from the photo.
Fred
FredTJ is offline   Reply With Quote
Old 02-16-08, 12:27 PM   #9
ms018kmf's Avatar
The metal is pretty clean, like what you see when a bolt breaks. Tiny rocks pepper the hell out of parts down there.
Old 02-16-08, 03:55 PM   #10
inkpot's Avatar
TLCA# 10338
Howdy! Mine looks pretty close to that. The red circle should be the bleeder, and the other one is just a nut/plug fitting, maybe for a pressure bleeder, or a check valve? Mine's a long bed, if that might make a difference. John
CSC #41
Old 02-19-08, 04:39 AM   #11
Nice Photos It Is Explaining Me Each And Every Thing In The Photo. Good Photo Graphy.
muiradaker8 is offline   Reply With Quote
Old 02-19-08, 05:13 PM   #12
ok, here is a little brake bleeding thing.
go to the vet's office, get a 60cc syringe. a bit of vacuum tube.
put some grease around the bleeder valve, open and pull out the fluid. you can get a 120cc.. but I find the 60 is easier to pull.
keep the rez full.
missouriman is offline   Reply With Quote
Old 02-21-08, 10:09 AM   #13
forestdan7's Avatar
TLCA# 17532
Loosening the bolt lets you bleed out the nipple which should be right next to it, under a rubber cap. This is unlike other bleeders, where the nipple itself unscrews.
I just did mine after replacing the hard brake lines. Bleed LR, RR, RF, LF, master cylinder, LSPV. That should do it.
1985 FJ60
1987 4Runner
2007 Honda XR650L
forestdan7 is offline   Reply With Quote
Old 03-20-08, 06:09 PM   #14
Ina4Runner,downbytheriver
purerockfury's Avatar
Not to pirate a thread, but it's better to keep all of the information
together in one place, instead of starting a new thread.
I have a 93 4Runner. Just replaced the front calipers and rubber
brake lines leading to them. It has new brake lines all around
that are about 2 yrs. old. The passenger front brake keeps
hanging up. It did before and after the new parts.
My question is:
Has anyone experienced the Proportioning Valve sticking?
Way Cool Toyota Shirts & Hoodies:
www.northcoastin.com
-2001 Taco
-1993 4runner
purerockfury is offline   Reply With Quote
Old 03-20-08, 08:17 PM   #15
inkpot's Avatar
TLCA# 10338
My question is:
Howdy! Sounds like you might have a warpped rotor. If not, then maybe a bent spindle or backing plate. the Proportioning valve makes a difference from front to rear, not side to side. I don't think it would be your problem. John
CSC #41
Old 03-22-08, 12:53 PM   #16
I forgot to post up that with the new calipers, I put new rotors on too.
There are 3 lines on the Prop. valve. From what I can see, 1 input & 2 output.
Each leading to individual front brakes. That's why I was asking about it,
because of the 2 lines.
Any experience or thoughts?
-2001 Taco
-1993 4runner
Old 03-22-08, 01:12 PM   #17
inkpot's Avatar
TLCA# 10338
Howdy! Hmm, well so much for that idea. The block you are describing sounds like it could just be a "T" junction box. Does it have anything else on it like a set screw or adjuster in the middle? Does your rig have the valve under the rear end like the pics earlier in this thread? Check all the hard line to the right front, looking for crimps or bends that were not originally there. Like something that has been moved to make access easier for maintenance. Good chance it would be at a mounting bracket, and that would be hard to see without removing the rubber grommets that hold the lines. Braking pressure in the line is much greater that the return pressure after you release the pedal. Are your calipers "hard" mounted to the knuckle like earlier trucks, or are they "floaters" like Chevies where they can move lefty righty on two large pins. If floaters, then pull the pins and buff them up with some fine sandpaper in case they are dragging. John
CSC #41
Old 03-23-08, 12:50 AM   #18
rockrash's Avatar
Heres my set up.Oh silly me I forgot I took mine off.
rockrash is offline   Reply With Quote
Old 03-24-08, 01:41 PM   #19
ms018kmf's Avatar
Brakes can stick if the wheel bearing is a bit loose. If there's a shudder at the sticking brake as it releases then I'd jack up that wheel and see if it can shake.
Mortgage | US Business Directory | Cheap Car Insurance | Personal Loans | Electronics
