Auto crawler
Jumping boards here but my buddy asked me to post up. He just picked up a 90 v-6 4x4 runner auto with a bad tranny. He has another tranny but was thinking about inchworm's crawler box or one similar while the trans is out. Is anyone running a auto crawler? Got any words of wisdom for him? Thanks
__________________ SOLD!! CRUISERLESS AND HATING IT! EDIT: 97, J-fronts, med rears, factory locked, arb front bumper, 315 terra grapplers, 100K miles and counting, 4.88's, miss my 84 runner but luv my cruiser!
You may want to consider getting a torque converter with a higher than stock stall speed because its hard to stop an auto in double low unless you shift into neutral.
__________________ 1989 Toyota Pickup - 255,xxx miles, SAS, Bed Bobbed 14", 95 4Runner front clip, Hanemman Fiberglass front fenders, All Pro 5.5" lift, Hi Steer, 5.29 gear rear Detroit locker, front ARB locker. 1988 4Runner - Blown up 3.0 V6 1999 4Runner SR5 Sport Edition 1992 Lexus SC400 |
I've got a TH350 auto in my Toy p/u and manual in my Runner and wheel both. I prefer the auto.
__________________ 84 4Runner - ARBed 5.29s F&R, 2.28 & 4.7 t-cases, 30 spl Longs, 36" TSLs, etc. seen in FOUR WHEELER magazine July 2006, OFF-ROAD magazine Feb 2007 |
Yeah do it
Ive researched and talked to inchworm, gearslug, and even another guy. I went with the IW due to price and availability. Mine are half installed I havent used them yet but I bought them from a buddy of mine (Carl, the owner of Outback offroad) He ran them in his 90 runner and he loved them. I love autos so this was my best option. You could also intall a 340f and bolt a typical marlin crawler set to it, but that is much more involved due to making the 340f communicate with the 340h ECU. I expect to have a final drive ratio of about 400-450:1 (counting the TC as a doubler) which is really low for an auto. I suspect it will be fun
__________________ 1988 4runner 3.0 5spd soft top stock DD 1990 fj62 stock 1992 4runner 3.4, auto, dual inchworms (5:1, chromo output, twinstick, 10*) marlin sas, 5.29's, lockrite's, 30 spline longs, hydro assist, custom exo, 37" PBR's, DIY beadlocks, hs9500i/synthetic, AWshifting electronic shifters... |
chevy set up man. my th350 built is a dream.
I also have a TH350 with a 205. I like having it there when I need to hit it and not have to worry about a clutch. But its just a personal preference.
#7 | |
Here's the detailed write-up. Tech: Automatic Transmission swap & Marlin Crawler Install Tech: Automatic Transmission swap & Marlin Crawler Install Phil __________________ 1973 FJ40, beeropener 1966 FJ45, (the 12HT has arrived.... )1995 4Runner, AT with dual cases TLCA #9166 TLCA Delegate, Mountain Transit Authority, San Jose, CA Last edited by pjohnson; 02-19-08 at 12:12 PM. |
sorry to hijack but I have a newb kind of question...
Is the t-case the same between the auto and manual Toyota pickups? __________________ Sam '94 TLC, ARB w/ 8274 winch, custom side pipe, flareless & running-boardless, duraback, engine oil cooler and filter relocate, 2" Ironman lift, more to come later. ![]() '85 fj-60 parting out ![]() '98 Subaru Legacy (DD) CO/WY - Horsetooth 4 Wheelers Cruiser Club |
No longer pre-approved...
No, the Tcases are different, therein lies the problem....
__________________ Jerod Online Toyota Parts Catalog!!! 89 4Runner "The James Caird" 01 4Runner, for my Jefferson State Cruisers |
#10 | |
manual + 6cyl = chain drive auto + 4cyl = 1 piece trans/chain drive tcase A340H ![]() auto + 6cyl = same as 4cyl with auto This is pickup info (pre 95.5) __________________ 1988 4runner 3.0 5spd soft top stock DD 1990 fj62 stock 1992 4runner 3.4, auto, dual inchworms (5:1, chromo output, twinstick, 10*) marlin sas, 5.29's, lockrite's, 30 spline longs, hydro assist, custom exo, 37" PBR's, DIY beadlocks, hs9500i/synthetic, AWshifting electronic shifters... Last edited by 2ndGenToyotaFan; 02-22-08 at 03:43 PM. |
#11 | |
auto + 4cyl (pickup only) = A340F with chain drive t-case, same as auto+v6 I found standard cab pickups (2nd gen I believe) with an auto came with the A340F and chain drive t-case. I never saw it with any other model. I confirmed this at the dealer when I purchased a brand new shifter console cover from the above mentioned model. You can see the console piece in the article. Phil __________________ 1973 FJ40, beeropener 1966 FJ45, (the 12HT has arrived.... )1995 4Runner, AT with dual cases TLCA #9166 TLCA Delegate, Mountain Transit Authority, San Jose, CA |
#12 |
hijack mode on:
I do not want to post a thread, but I have an 85 RET AT. The TC is leaking and I do NOT want to tear it down. I have a 93 4runner V6 with THE SAME tranns code. any and all info on weather or not I can just simply swap them (I imagine sensor and BH swapping at the least) would be appreciated. links, yes or no will do thanks! ![]() hijack mode off: |
#13 |
Park them side by side and answer your question
![]() Buy the automatic transmission FSM.... There are some minor case differences and the 93 will have a cooler attached to the t-case, but it should be doable. Don't know about VSS & ECU compatability, probably different given different motors. Phil __________________ 1973 FJ40, beeropener 1966 FJ45, (the 12HT has arrived.... )1995 4Runner, AT with dual cases TLCA #9166 TLCA Delegate, Mountain Transit Authority, San Jose, CA |
Mortgage Calculator | Free Advertising | Web Advertising | Promotional Codes | Screw Machine |
