Old 01-28-08, 10:54 AM   #1
Hottrod81's Avatar
TLCA# 18127
Carb Issue
I have a 1984 4Runner with a 22R and Carb. I am having an issue with the carb. When starting cold, it goes to a normal high idle. The problem is, after it is warm, I cannot get it to come off of the high idle. I was playing a bit with it this morning, and I moved the choke linkage on the back of the carb, and the engine idled down to normal, around 800 RPM. As soon as I touch the accelerator and then let off, it goes right back to high idle. Does anybody know what might be wrong? Thanks.
www.centralvalleycrawlers.org
My 4Runner Build
Originally Posted by Toyrunner87 View Post
I treated that hood like Ike treated Tina and it still won't budge.
Hottrod81 is offline   Reply With Quote
Old 02-03-08, 06:12 PM   #2
trojan_knight's Avatar
I would check the vacuum diagram and make sure it is all right.
Sam
'94 TLC, ARB w/ 9500# winch, custom side pipe, flareless & running-boardless, duraback, engine oil cooler and filter relocate, 2" Ironman lift, more to come later.
'82 toyota pick-up
'85 fj-60 parting out
CO/WY - Horsetooth 4 Wheelers Cruiser Club
trojan_knight is offline   Reply With Quote
Old 02-03-08, 06:13 PM   #3
forgot to mention I have just the opposite problem because I have a '87? carb on my '82. I have yet to fix the vacuum mess
Sam
'82 toyota pick-up
Old 05-08-08, 03:20 PM   #4
stupid carb
I had the same issue with my 82 22r and I noticed the the idle adjustment screw was kinda loose and would move every time i hit the throttle. I some how lost the screw when I was trying to shim it with washers and could not find one with the same thread pattern so I used a smaller bolt of similar length and positioned nuts on either side of the arm so it cannot move. What a pain in the ass! I researched and looked at the vaccuum system forever and replaced a bunch of crap before I realized the issue. Hope this helps...if not...good luck.
darichmon is offline   Reply With Quote
Old 05-08-08, 07:30 PM   #5
WristPin's Avatar
did you open the throttle in the truck, or right there on the carb?
i suggest you verify proper operation of the linkage, and springs. also clean off the linkage with wd40, and get er all lubed up.
you can use a vacuum gauge to check for leaks. this tool is very versitale, and can tell you a lot of important information
Wristy
check the FAQ!
1980 RN37
1989 RN101
1986 RN64
Originally Posted by Rezkid View Post
ridin quads and blastin' mofers...life don't get much better than that
Old 05-08-08, 07:35 PM   #6
Hilux's Avatar
TLCA# 9h9-69
reckon its the heat riser?
Not installed (tube from exhaust manni to diafram, is it a dashpot?) properly so it can tell when to cut the choke off?
I'm too old school, I still hold a phone to my ear...
We're just one krappy Diesel away from another 30 years of gas ...the "6.2 Redo"
As soon as I figure out how to make a still, I'm
going to start making "Bio Gasoline"
lets see, corn, sugar...copper pipe...
Hilux is offline   Reply With Quote
Mortgages | Credit Card Consolidation | Lingo Voip | Car Insurance | Bad Credit Loan
