Roof Rack Build
I have started fabbing up a roof rack. Here are a few pics of the start of the project:
I am building it out of 3/4" square tubing, .083 wall to be exact. I first wanted to come up with a design that did not require a tubing bender and did not look too boxy. I opted to fab up the corner brackets out of 16ga. sheet metal. They have a lip on them that supports the 3/4" tubing and they are dimpled to stiffen them up and save a little weight. Today was the first test fit after I tacked the frame together: ![]() Custom bent and dimpled corner pieces: ![]() Custom bent and dimpled side brackets: ![]() ![]() I still have to add several more features to it, weld it up, and get it off to the powder coat shop. Stay tuned. Cheers, tp |
Pretty cool.
You've got some damned fine photos on your website, BTW. Nice work. __________________ KB1OSF '87 Toyota xcab SR5 - SAS'd, stuff '98 Lexus ES300 '04 Toyota Highlander |
Are you planning on bolting through the fiberglass top? I'm thinking about mounting a Wilderness roof rack by bolting through the top. They make one that will fit which is designed for fiberglass pick-up truck bed tops.
I would be curious to see how much trouble you thought it was to drop the headliner in the fibergalss top to install (assuming you plan on bolting through). Looks good BTW. __________________ 1985 4Runner - ROTM WarDamnEagle's 85 4Runner 1997 FZJ80 - locked and stock 2007 HDJ100 - DD .....and these are just the Toyotas |
I am going to make gutter mount brackets for the front and middle brackets, but I have not decided exactly what route I am going to take on the rear mounts.
It doesn't look like it would be that big of a project to pull back the head liner and mount directly to the roof though. EDIT: I just nothiced the Roof Rack Build thread in the Expedition section...I should have posted this stuff there! Cheers, tp Last edited by fj40tom; 01-11-08 at 02:51 PM. |
I was able to get a few more pieces welded in today.
![]() ![]() ![]() With any luck I will get the entire frame welded up on Sunday. Cheers, tp |
I had concluded that gutter mount was going to be too difficult. Here is a link to the type of rack that I plan on installing. Again, though, it will have to be bolted through the roof. This might give you some ideas about mounting.
Garvin Industries __________________ 1985 4Runner - ROTM WarDamnEagle's 85 4Runner 1997 FZJ80 - locked and stock 2007 HDJ100 - DD .....and these are just the Toyotas |
[quote=WarDamnEagle;2933603]Here is a link to the type of rack that I plan on installing...QUOTE]
That looks like a great solution. I have used a similar product on my slide-in truck camper with great results. It would be a great alternative to the weak fiberglass rain gutter on the 4Runner shell: Yakima Cheers, tp |
I fabbed up some support brackets. These will help the rack support the weight and abuse of a solid Baja trip with no problem. I built the supports with a good bit of adjustment in them so the rack can easily be moved and mounted on several types of trucks (fj40, 60, 80, 4Runner, ect):
![]() After hours of welding and grinding, I was finally ready to cut the floor and weld it in: ![]() Welding the floor: ![]() The expanded metal floors are strong, but they require TONS of welding to keep them from rattling all the time. This floor is welded in over 200 spots. It will not rattle... ![]() The front and rear support brackets were designed with two adjustment slots in them too: ![]() Still more to come... Cheers, tp |
#10 |
No longer pre-approved...
Dang! just dang!
Keep up the good work!
__________________ Jerod Online Toyota Parts Catalog!!! 89 4Runner "The James Caird" 01 4Runner, for my Jefferson State Cruisers |
#11 |
How much does the completed rack weigh. Looks pretty heavy. Do you need heavier suspension. Does it take 4 strong tall guys to put it up there on top of the vehicle and is it made to be removable?
__________________ Odd man out with a 90 Jeep Cherokee. 3.5" lift and homemade bumpers and a 12,000lb winch. 31x10.50 BFG K/O ATs |
#12 |
Very nice. What do you estimate your final build cost was material wise?
#13 |
Tom, did you ever get this thing bolted onto your 4Runner? I would love to know how it went, see some pics, etc.
#14 | |
nice job. looks way better than my twin matress bed frame roof rack....
__________________ Wristy check the FAQ! 1980 RN37 ![]() ![]() 1989 RN101 1986 RN64 Quote:
LinkBack to this Thread: http://forum.ih8mud.com/79-95-toyota-truck-tech/198804-roof-rack-build.html
| Building Custom Roof Rack? - Jeep Cherokee Forum | This thread | Refback | 09-18-08 05:54 AM | |
| Roof racks for camper shells - race-dezert.com | This thread | Refback | 06-25-08 08:52 PM | |
| Roof racks for camper shells - race-dezert.com | This thread | Refback | 06-25-08 07:45 PM | |
Credit Card Consolidation | Mobile Phone | Mortgages | Problem Mortgage | Xecuter 3 Mod Chip |
