Old 06-19-04, 01:55 AM   #1
Jonathan_Ferguson's Avatar
TLCA# June 9th, 2002
Red face Best and Worst Modifications, You've done - Hilux/Mini Truck
All I've done to my Hilux is drive it home. - Which has been the only time I've driven it. Have had a broken right Ankle since the 8th of June, Crashed a Gokart on the Straight on the last Lap comming upto the Start/Finish line, When the Person in front of me spun.
First maintenance item will be the Clutch, Then the first modification will probable be Parabolic Leaf Springs.
1986 Nuclear Reactor
1985 Toyota LN65R
LIFE AIN'T WORTH LIVING WHEN YOU DIE BEFORE YOU'RE MEANT TO!
Jonathan_Ferguson is online now   Reply With Quote
Old 06-29-04, 09:39 AM   #2
John_Smith's Avatar
TLCA# 9074
Best mod=Lockrite in the front. I installed it six years ago and it still amazes me off road. You must install a idler arm brace though. I finally learned my lesson after bending three.
Worst mod= 31x10.5 tires on 8 inch rims. I always get dirt in the bead after wheeling and have to bread beads and clean it out or I leak air. Only put 12.5 wide tires or wider on 8 inch rims if you wheel the truck. Next tires will be 12.5 wide.
John Smith
79 FJ40
John_Smith is offline   Reply With Quote
Old 07-01-04, 01:08 AM   #3
cjtt350's Avatar
best mod marlin craler transfer case toy truck an lockrights worst= putting on 33,s on ford explorer sporttrac tor fender up?
86-toy -mini-marlin-lockrite33:3s& toy 82 in the works-v6 3.8 38,s-marlin -350 terbo&74 landcruiser-mostly stock-an avatar stolen- thanks! tyler
cjtt350 is offline   Reply With Quote
Old 10-27-04, 10:51 AM   #4
worst mod: skyjacker 5" softride. pain in the ass to install. infact is it not possible that they had actualy installed on of their system before they sold them . they expected the sway bar to fit with no mods? while the axle dropped 5"? Not a big deal bc my father owns a metal fab shop, also the drive angles were all messed up so there was drivablity problems. beyond that I had two sets of springs that went bad on me and were warranteed. also the skyjacker spring pack are too thick so when you put them on the arms for the emergency brake will NOT move. Pain in the ass!!!! so go with another manufacturer. I love my Old Man Emu springs on my cruiser, but I got them cheap and I'm not sure If I could cough up the dough for a new set.
Best Mods: detroit softlocker rear and detroit truetrack front and yukon 5.29 gears, 35" procomp xterrains. worked very well as a combination, my spedo was almoast accurate.
Custom flatbed, take a beating better than sheet metal, and you'll notice on mountain roads your rear always slips off the side first.
Warn 8274 a little heavy but I picked it up for $200
York onboard air. the compressor will fit on the lower pass side of the engine, but it's tight. I put a 12 gal air tank under the bed with a pressure switch and port out the side of my bed. I always had air ready to go and easy to get to.
jetboy,
75-40
Jetboy is offline   Reply With Quote
Old 10-27-04, 10:54 AM   #5
ALso don't buy a centerforce clutch!!!! they don't last long in high temp off road situations, TRD makes a new 10" clutch kit that is the sh** , for $500 it is the only way to go!!!
jetboy,
75-40
Old 10-28-04, 11:33 AM   #6
tonkota's Avatar
TLCA# 14154
Best mod: truetrac in the front.
Worst mod: NWOR Springs. Shitty design, shitty ride, shitty quality, and damn expensive. I thought I'd get what I paid for, but I didn't. I won't call them again.
A Ron
Using one cruiser to go mountain biking, and the other to collect dust.
2F-E Article
McNamara gear writeup
tonkota is offline   Reply With Quote
Old 10-28-04, 05:18 PM   #7
springfield user
brian's Avatar
TLCA# 6955
telephone phone pole modification to the right front that includes the sheetmetal, suspenion and frame.
this would fall under the worst catagory
just got word today about the frame(it was wrecked last dec). sadly i think that seals it's fate.
it's only metal, we can out think it.
77-fj40 20th anniversary edition
87-fj60 216K mile DDer
93-fzj80 mall crawler
toyota material distribution center. your source for Factory Service Manuals.
they're alot cheaper than you think.
1-800-622-2033
brian is offline   Reply With Quote
Old 10-29-04, 06:33 AM   #8
Put 680 thread lock on my wheel nuts and then coul d not get them off
4BGaz is offline   Reply With Quote
Old 10-29-04, 11:26 PM   #9
One word...
SLIDERS
1994 fzj80
1970 fj40
www.bellaadventures.net
Robb
blupaddler is offline   Reply With Quote
Old 10-30-04, 01:40 AM   #10
Jim_Chow's Avatar
best: OME springs, shocks, steering stabilizer, then e-code H4 headlights w/ heavy-duty harness, then arb bullbar (for piece of mind).
Jim_Chow is offline   Reply With Quote
Old 11-01-04, 06:53 PM   #11
tonkota's Avatar
TLCA# 14154
I have to disagree. I have had a DF in my mini for 4 years and 50k miles with no problems. It's smooth on engagement and has never slipped, even when soaking wet. Just my experience with them.
A Ron
2F-E Article
Old 11-07-04, 06:31 PM   #12
baby_troupe's Avatar
Best - The rear air locker
Worst - first set of driving lights (cheap & they rusted out)
baby_troupe is offline   Reply With Quote
Old 11-22-04, 11:48 AM   #13
I had the CF2 DF and it lasted about a year maybe less. It just got too hot too fast. after an hour or so of wheeling on tough trails it would get so hot that I would be stuck in the middle of the trail untill it would cool down and allow me to move again. I wasn't slipping the clutch to any large degree just lots of forward/backward action. also off road the centerforce does not get to the rpm range where it does any good unless your racing. I went to the toyota clutch and it was night and day. I never had problems with it and sold it about a year ago and the current owner has not replaced it yet.
jetboy,
75-40
Old 11-23-04, 07:45 AM   #14
toyrunner's Avatar
TLCA# 7031
I ran Santiago Canyon a few years ago and experienced the same with my DF2. Barely made it home. End result was the friction material went away, so I went to the TRD clutch
Danny
toyrunner is offline   Reply With Quote
Old 11-24-04, 12:36 AM   #15
78 One owner's Avatar
I'll remember the probs you guys had when i'm shopping for a clutch for my Gen III Formula project.
I've had a CF clutch in my FJ for 6yrs without a prob except learning how to use it at first. It's like an on/off switch and it sucked trying to crawl with 28:1 and no slip. No Probs now though.
Any brag I make comes with 4 kids in back, and one of them likely will be sleeping
'78FJ40:33s,SBC,PS,SR,Rrflip,4"lift,Warn,Lockrite, Rockbox, Topless.
Parts in, waiting for shoptime: 4.10fine-spline R&P F&Rr, ARB front, York, dual batteries under Rr floor.
78 One owner is offline   Reply With Quote
Loans | Credit Card Consolidation | Consolidate Student Loans | Online Loans | Credit Card
