Ramblin Wreck
V6 Calipers on a '90 4Runner
I'm helping a friend do a brake job on his '90 22RE 4Runner, and realized that we should be able to use the larger v6 pickup/4runner calipers on his truck.
We're replacing the calipers anyway, so it would make sense to try and get the best brakes on there were can. Can anyone verify if v6 calipers would indeed work on his 4cyl 4runner? Thanks __________________ Bailey Quintrell '74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage '93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's '97 FZJ80 '98 UZJ100-OEM RR locker ΣΧ
I can't imagine that they wouldn't, but you may need to trip the backing plate/dust shield a little. Might also be a soft pedal until you upgrade the MC to a 1" bore.
__________________ KB1OSF '87 Toyota xcab SR5 - SAS'd, stuff '98 Lexus ES300 '04 Toyota Highlander |
Ante up to an 80 series!
The latter '93-'95 V6 callipers will not sit flush with the edge of the rotor. There will be about 1/8" of overhang. The '89-'92 callipers are the ones you want.
Ramblin Wreck
Okay, '89-'92 V6 4runner calipers. Thanks.
Going to put some Hawk LTS pads in them, had good experience with those pads on my FZJ80. Can anyone comment on the potential soft brake issue? I'd hate to go to the extra trouble and then have him need to get a different M/C. __________________ Bailey Quintrell '74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage '93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's '97 FZJ80 '98 UZJ100-OEM RR locker ΣΧ
You shouldn't have a problem.
I have V6 IFS calipers and the larger IFS drums on the rear. All works fine w/stock MC. You can always upgrade if you feel the need. Just make sure you bleed the system. __________________ 84 4Runner - ARBed 5.29s F&R, 2.28 & 4.7 t-cases, 30 spl Longs, 36" TSLs, etc. seen in FOUR WHEELER magazine July 2006, OFF-ROAD magazine Feb 2007 |
Ramblin Wreck
Bleed the system? Whats that do?
![]() Thanks for the info.
No longer pre-approved...
Good eye Poser.
![]() The V6 pads are around 3/4 inch/or so... longer than the 4 bangers, I know because the desk monkey at Schucks sold me the wrong set once..... Now I look up the part numbers at home and just hand them a note with the number on it.......
__________________ Jerod The 79-95 Truck/4Runner FAQ 89 4Runner "The James Caird" 01 4Runner, for my Jefferson State Cruisers |
If he has the factory chrome wheels like these...
![]() The wheel will rub the larger v6 calipers. __________________ 84 FJ60 85 4runner |
#10 |
Really? Hum, I got that same wheel as a spare and just sold the complete set that came with my truck. Good to know, guess if I get a front flat I'll have to rotate a rear up front before I put the spare on.
#11 |
Ramblin Wreck
He has some aftermarket alloy rims, hopefully they won't rub.
#12 |
You might be able to grind the caliper a little to allow them to fit. I have a set of 16" wheels so I just sold the chrome ones.
#13 |
Is this true for ALL years of I4 trucks? Should '93-'95 I4 trucks use the '93-'95 V6 calipers, or the '88-'92 V6 calipers?
#14 |
the reason you blead the brakes is because when you change the caliper or disconnect the lines, air is inhaled by your braking system. since air can be compressed you do not want that, so you bleed your breaks to get all of the air out so that your pedal will not be spongey and your breaks will be solid and stopp good. your break fluid cannot be compressed. a liquid cannot be compressed
#15 | |
__________________ 1985 4Runner - second round of upgrades done! 1997 FZJ80 - locked and stock 2007 HDJ100 - DD .....and these are just the Toyotas |
Mortgage Calculator | MPAA | News | Wills | Loan |
