Old 08-17-07, 01:05 PM   #1
LeftCoast's Avatar
Are 4 cyl 4x4 trannys interchangeable, between an 88 reg cab 4x4 and 89 runner?
Hi all,
I can pickup an 89 runner 4x4 with a whiny transmission for @ a geezel, but can I replace said transmission with a spare out of an 88 reg cab 4x4 PU? Both engines are the 22re, BTW. Should I switch out transfer case as well (altogether with my spare), and will I need to do anything with the driveshaft?
Also, how about a little rust hole over one of the doors? Not bad underneath, but the hole concerns me. Is this the beginning of bad rust everywhere, or do those 2 door runners have this weird flaw?
Thanks.
LeftCoast is offline   Reply With Quote
Old 08-17-07, 03:01 PM   #2
KLF
KLF's Avatar
Both trannies should be a W56, no problem swapping them. Yeah, swap the whole thing, t-case and all. Driveshaft shouldn't be a problem.
Where exactly is the rust hole? Yes, these trucks rust BAD.
And what the heck is a "geezel"?
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Old 08-17-07, 03:41 PM   #3
No longer pre-approved...
2ndGenToyotaFan's Avatar
A rust hole above the door? That's an odd one.... Could be a fluke, or it could be a rusty truck, I'd give it a good look over, as I would any truck.....
Old 08-17-07, 04:21 PM   #4
Ante up to an 80 series!
Bear80's Avatar
TLCA# 14779
22r and 22re motors have a w56 tranny with the gear driven t-case. Some mid-90's had a G58(?) with the 22re motor, not sure why but most still at the time used the w56.
The 3vze used the R150 with chain driven t-case. This is a better tranny than the w56, however you will need a new bell housing to use it on a 22re motor and the rear crossmember. Which for the bell housing, means finding a R151 that came on a 22re-t and then you'd be better off using the R151 since it has a LOW 1st and lower 2nd. Also the R151 has the gear driven t-case.
40th FZJ80 - Range Rover Recovery Vehicle
Alamo City Land Cruisers
-Benjamin-
Bear80 is offline   Reply With Quote
Old 08-17-07, 04:39 PM   #5
#1: shhhh!
#2: RET 2WD (R150) bellhousings will also work on (V6) R150 but 2WD has no low 1st and duh TC,
tntoyota is offline   Reply With Quote
Old 08-17-07, 05:37 PM   #6
Early 22R's maybe all of them came with G52 5 speeds... My 86 had one.
Old 08-17-07, 06:06 PM   #7
KY854RUN's Avatar
TLCA# 3200
The fuel injected trucks and 4Runners from 85 to 95 should have the W56. The carburated ones would have the G52.
You will need to check on where the T-case shifter is located. Trucks often came with the forward mounted shifter and 4Runners have the top mounted T-case shifter.
Kevin
`85 4Runner - work in progress
M416 Trailer - ukn year, rebuilt July 2007, build thread
`68 FJ40 - planning stages of a build
Green Country Cruisers - member
Wish List - to long to post
KY854RUN is offline   Reply With Quote
Old 08-17-07, 06:50 PM   #8
jasonmt's Avatar
Not all of the 22RE powered 89+ trucks and 90+ 4Runners came with a W56, those that had ADD came with a G58 transmission and a chain drive case.
A 89 22RE 4Runner and a 88 22RE pickup would have came with the same W56-B transmission and type 3 top mount gear drive T case.
jasonmt is offline   Reply With Quote
Old 08-17-07, 08:25 PM   #9
This thread turned out well, I think I'll FAQ it
Old 08-18-07, 12:39 AM   #10
Bear80's Avatar
TLCA# 14779
ah, that's right the 22r used the G52, while the 22re had the w56.
-Benjamin-
Old 08-19-07, 09:04 AM   #11
LeftCoast's Avatar
Great info to know, guys, thanks a lot.
The Runner, however, was a ginormous POS, not even worth the geezel (G, or grand, or $1000 KLF!). There was a hole over the windshield I could go three knuckles deep in...with three fingers.
Glad to have the thread in the FAQs, however, so all wasn't meaningless.
Old 08-19-07, 10:02 AM   #12
TLCA# Associate Member/Sponsor
The 1988 22RE transfer- case was the last year of the Top-Loader!! The 1989 carbureted, EFI, or V6 transfer-cases were all Front-Loaders. Whats this got to do with your transmission choice??? The tranny shifters come in various flavors, and the actual tranny/transfer shifter could prevent you from pulling the swap you desire??? Actually you might be able to pull this off with a shifter/ shift-rail swap???
Downey is online now   Reply With Quote
Old 08-19-07, 11:12 AM   #13
Here's some onfo from Marlin Crawler on T-cases and Trannys:
T-case Bible.
Pics of various trannys.
Old 09-01-07, 11:48 PM   #14
22RE and 2L
I am just woundering if a 22RE transmission will bolt up to my 84 diesel motor. I am having a hard timing finding a diesel tranny and a harder time getting help on how to solve my problem. Just want to know if the gas transmission will work and from what years I can get one from...
84toyodiesel is offline   Reply With Quote
Old 09-01-07, 11:53 PM   #15
retired maths geek huh
denis's Avatar
it will work, just keep you bellhousing. G and W series have the same front tranny pattern so either will work with your bellhousing.
'71MS75 threw a rod '74MS75 seized engine '75BJ40 farm tractor type R '79FJ55 rostig schwein '80BJ40 never ending resto '88LN65 frame-off '90HDJ80 the bear '92LN85 turbo ute
denis is offline   Reply With Quote
Mortgage Calculator | Personal Car Finance | Personal Loans | Mortgage Loans | Travel Shop
