LinkBack (115) Thread Tools Display Modes
Old 01-24-09, 01:44 PM   #31 (permalink)
Rookie
Originally Posted by Bear80 View Post
Thanks for the complement. My kit IS the Downey kit minus their shock tabs with bj spacers.
Any 7 to 8" travel shock will work up front. I would recommend the Doetsch 8000prerunner #8129 or their DT3000 #3129.
I made my shock tabs, but the Downey tabs are the best pre-fabbed solution. Their new style is also better then the older design which is why I had made my own at the time.
I'm not sure why Downey used HEAVY duty adjuster sleeves but I guess you can try to re-use the stock ones.
Take Porsche joints and make custom shafts. Otherwise I'll dig up the part numbers for the slip yokes and u-joints to make shafts like mine. Once you get the slip yokes you'll need to have them machined down to make clearance for the u-joint angle. Then the flange end will also need to be machined. Not to mention you have to have a whole new axle made which is NOT cheap. The Porsche joints aren't really that cheap either.
You will also need to get either at very minimum the Downey idler arm gusset with bronze idler arm bushings. Otherwise ante up for the Total Chaos idler arm.
I also would highly recommend the Downey poly replacement bushings for those Rancho arms if they still carry them. They are stiffer than the bushings from Rancho. You should also replace your lower arm bushings with the Downey poly bushings.
Plan on a rear lower arm truss too. I haven't needed one but I also only crawl with my truck.
Good luck!
THANKS BUDDY!!!
yeah I'm tossed between those style upper shock mouts, or the hoop style (some wide ones that will clear the UCAs; I've seen them before, so I know their out there)
and I just re-read the descriptions again, and I see where you did mention the fabbed shock mounts
the adjuster sleeves, I just figured I'd need longer ones to get the alignment right. I'd like to get new ones anyhow when I replace the tie-rods with the upgrade
and the joints I think are going to be the toughest part. I know of a machine shop accross town my job deals with, so I can maybe get a decent price through them on some custom work that I can't do myself.
definately getting the idler arm brace; I have a new idler are to bolt it to as well!
going to replace the LCA bushings too, while everythings apart. they are without a doubt the originals with 293k miles on them
I would do a rear truss, but I'm going to drop the diff an inch or so, therefor a truss wont fit, unless I custom fab one. But it's not going to be out pre-running, or catching major air, so I don't think it'll be necessary
Thanks so much for all the info; the pics are an enormous inspiration, and the thread is bookmarked for sure!!!
If you have any more pics, I'd greatly appriciate it! I'm still in the mix of gather hopefully everything I'll need, so it'll be a little while before I begin the install. I'll be posting a full pic-by-pic build process on YotaTech, and I'll have to throw the link in this thread when I do
IAmSuperBleeder is offline   Reply With Quote
Old 02-05-09, 12:37 AM   #32 (permalink)
Hey Ben. Haven't seen you around for a while. Didn't you sell this beast? How's the Cruiser coming along? /hijack
83 Pickup 22re, W56, 22 gal fuel cell, double shackle 63's, Marlin Highsteer, 36" TSLs, 5.29s
speedemon55 is offline   Reply With Quote
Old 02-05-09, 08:45 PM   #33 (permalink)
Bear80's Avatar
TLCA# 14779
I've been pretty busy lately and if I wasn't sick I would have made that wrench day. I did have my truck up for sale but couldn't pull the trigger even though I had a deal in the works.
40th FZJ80 - Range Rover Recovery Vehicle
Alamo City Land Cruisers
-Benjamin-
Bear80 is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/79-95-toyota-truck-tech/168936-rotbw.html
Posted By For Type Date
Toyota Long Travel - Page 5 - YotaTech Forums This thread Refback 09-21-09 06:57 PM
Lets see all the best 2nd gen 4Runners now - YotaTech Forums This thread Refback 09-13-09 10:01 AM
'86 Toyota Truck 4x4 This thread Refback 07-10-09 11:05 PM
Toyota Truck 4x4, 1986 This thread Refback 07-10-09 10:58 PM
Firestone Destination MT Review - YotaTech Forums This thread Refback 07-09-09 04:05 AM
1986 Toyota 4x4 Truck This thread Refback 07-02-09 09:29 AM
1986 Toyota Truck 4x4 This thread Refback 07-02-09 09:17 AM
1986 Toyota Truck 4x4 xtra cab This thread Refback 06-26-09 06:50 AM
2 wrecked 4runners in georgia, ARB bumper - YotaTech Forums This thread Refback 06-24-09 04:56 PM
1986 Pickup xtra cab 4x4 - TTORA Forum This thread Refback 06-18-09 08:15 AM
1986 Pickup xtra cab 4x4 - TTORA Forum This thread Refback 06-18-09 07:49 AM
1986 Pickup xtra cab 4x4 - YotaTech Forums This thread Refback 06-18-09 07:39 AM
1986 Toyota Truck 4x4 This thread Refback 06-17-09 11:25 PM
Looking to get rid of the rear end This thread Refback 05-27-09 11:08 AM
leveling out 95 runner - YotaTech Forums This thread Refback 05-01-09 10:44 PM
6 This thread Refback 04-18-09 07:13 PM
Transmission Whining in 3rd & 5th - YotaTech Forums This thread Refback 04-08-09 04:00 PM
Ramblings about air shocks - YotaTech Forums This thread Refback 03-25-09 10:06 AM
coil overs on stock a arms? - YotaTech Forums This thread Refback 03-19-09 04:16 PM
Rancho IFS Lift for '86-95 Pickup and 4runner - YotaTech Forums This thread Refback 03-12-09 06:16 PM
Downey Load Leaf replacement - YotaTech Forums This thread Refback 03-12-09 12:05 AM
idler arm difference? - YotaTech Forums This thread Refback 02-18-09 04:02 PM
Downey This thread Refback 02-05-09 10:21 PM
Beefy front CV's? - Page 3 - YotaTech Forums This thread Refback 02-05-09 08:45 PM
Downey shock mounts. 2x wheel travel?! - YotaTech Forums This thread Refback 02-04-09 02:52 AM
well well well, look what UPS done dropped off fer me - YotaTech Forums This thread Refback 01-20-09 05:17 PM
Rancho Upper Control Arms - YotaTech Forums This thread Refback 01-11-09 03:21 PM
Some pics with 4 This thread Refback 12-09-08 01:12 PM
POST YOUR PICS FOR 95 RUNNER / Comments - YotaTech Forums This thread Refback 12-04-08 05:54 AM
What size tires are you running? (IFS Only) - Page 6 - YotaTech Forums This thread Refback 11-25-08 12:44 PM
Total choas with BJ spacers? - YotaTech Forums This thread Refback 11-24-08 06:51 PM
Best IFS lift - YotaTech Forums This thread Refback 11-04-08 10:19 PM
lift kit - YotaTech Forums This thread Refback 10-31-08 08:42 PM
80 series LC wheels on 1st Gen Pickup - YotaTech Forums This thread Refback 10-29-08 08:08 AM
Xterrain 31x12.50-15 (4) - YotaTech Forums This thread Refback 10-08-08 01:13 PM
Are these stock rear leaf spring packs? - YotaTech Forums This thread Refback 10-08-08 07:54 AM
FJ80 Wheels on First gen 4runner? - YotaTech Forums This thread Refback 09-14-08 03:30 PM
Post Your Pics!!! - Page 26 - YotaTech Forums This thread Refback 09-08-08 10:41 PM
94 V6 callipers on my 86 pickup - YotaTech Forums This thread Refback 09-08-08 04:58 PM
Need Torsion bar Help! - YotaTech Forums This thread Refback 09-07-08 03:15 PM
Tail light options? - YotaTech Forums This thread Refback 08-26-08 01:25 AM
Whitey's Improvements by This thread Refback 08-06-08 12:51 PM
Whitey's Improvements by This thread Refback 08-03-08 08:35 PM
Whitey's Improvements by This thread Refback 08-03-08 06:13 PM
Softopper for 1st Gen 4Runners on Ebay - Page 2 - YotaTech Forums This thread Refback 07-20-08 12:57 PM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-30-08 03:12 PM
Ironman Suspension on ebay - YotaTech Forums This thread Refback 06-28-08 06:07 PM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-26-08 10:52 AM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-26-08 10:33 AM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-26-08 01:15 AM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-25-08 10:29 PM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-25-08 09:25 PM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-25-08 12:53 PM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-25-08 10:35 AM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-25-08 10:30 AM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-25-08 09:03 AM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-25-08 09:00 AM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-25-08 07:38 AM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-25-08 04:57 AM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-25-08 04:22 AM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-24-08 11:14 PM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-24-08 10:22 PM
1986 Xtra cab 4x4 - YotaTech Forums This thread Refback 06-24-08 10:18 PM
Sagging rear Downey Rear Leaf Springs - YotaTech Forums This thread Refback 06-17-08 02:39 PM
Control Arm Bushing replacement? - YotaTech Forums This thread Refback 06-09-08 03:16 AM
Need pics of IFS With RANCO LIFT - Page 2 - YotaTech Forums This thread Refback 06-07-08 12:13 PM
BAJA CLAW RADIAL or GOODYEAR MTR'S plz advice!! - YotaTech Forums This thread Refback 06-06-08 04:26 AM
WHY IS THE 3vze so bad to some - YotaTech Forums This thread Refback 05-27-08 07:00 AM
Post your GAS MILEAGE!! - Page 5 - YotaTech Forums This thread Refback 05-20-08 01:49 AM
Post you pics! Of your toyota pickups! Here is mine! - Page 3 - YotaTech Forums This thread Refback 05-19-08 05:25 PM
IFS rebuild - YotaTech Forums This thread Refback 05-17-08 06:38 PM
Rancho 26mm & SAW 25mm Torsion Bars - YotaTech Forums This thread Refback 05-08-08 09:26 PM
Annoying tapping! - YotaTech Forums This thread Refback 05-06-08 01:04 PM
IFS CV, to clearance or not????? - YotaTech Forums This thread Refback 04-07-08 11:08 AM
YotaTech Forums - View Single Post - IFS Flex Pics (DIAL UP, YE BE WARNED) This thread Refback 03-26-08 11:03 PM
IFS Flex Pics (DIAL UP, YE BE WARNED) - Page 13 - YotaTech Forums This thread Refback 03-26-08 09:08 PM
IFS Sway Bar Link Bushings - YotaTech Forums This thread Refback 03-12-08 05:01 PM
LOCKER Questions - Page 2 - YotaTech Forums This thread Refback 03-08-08 08:01 PM
LOCKER Questions - YotaTech Forums This thread Refback 03-06-08 06:36 PM
HD Tie Rods for IFS - YotaTech Forums This thread Refback 02-24-08 02:40 PM
Curious about strength of a stock Toyota IFS? - YotaTech Forums This thread Refback 02-07-08 09:42 PM
kumho Road Venture MT KL71. Anybody running these?? - YotaTech Forums This thread Refback 02-06-08 11:42 PM
Newbie / Downey 3 This thread Refback 02-06-08 10:23 PM
Lift ?'s - YotaTech Forums This thread Refback 01-31-08 04:25 PM
63 This thread Refback 01-29-08 08:34 PM
Hop..Hop...Hop....POP! -- Axle - YotaTech Forums This thread Refback 01-29-08 07:25 PM
Broken locker pins -- day old Lock Right!! - YotaTech Forums This thread Refback 01-27-08 10:41 PM
Are fancy clutches worth it? - YotaTech Forums This thread Refback 01-27-08 07:12 AM
Ball joint spacers? - YotaTech Forums This thread Refback 01-25-08 03:04 PM
Difference Aussie vs Lock Right? - YotaTech Forums This thread Refback 01-20-08 08:57 PM
IFS Flex Pics (DIAL UP, YE BE WARNED) - Page 7 - YotaTech Forums This thread Refback 01-20-08 07:44 PM
More pics of my truck! - YotaTech Forums This thread Refback 01-20-08 03:51 PM
Rear end sag '88 4 Runner helper springs - YotaTech Forums This thread Refback 01-19-08 09:29 PM
IFS Flex Pics (DIAL UP, YE BE WARNED) - Page 5 - YotaTech Forums This thread Refback 01-19-08 12:00 PM
IFS Flex Pics (DIAL UP, YE BE WARNED) - Page 4 - YotaTech Forums This thread Refback 01-18-08 11:38 AM
OME vs Downey vs Alcan rear leaf springs - YotaTech Forums This thread Refback 01-18-08 09:26 AM
old man emu, downey or sway a way torsion bars? - YotaTech Forums This thread Refback 01-17-08 01:39 PM
Toyota Trucks 3rd gen-89 to 95 - Favorite Links This thread Refback 01-17-08 09:29 AM
YotaTech Forums - View Profile: Bear80 This thread Refback 01-16-08 02:40 PM
Flipping Yer Tbars? Thoughts? - YotaTech Forums This thread Refback 01-16-08 09:42 AM
input shaft bearing or throwout bearing? - YotaTech Forums This thread Refback 01-15-08 08:16 PM
Pro Comp Xterrain - YotaTech Forums This thread Refback 01-13-08 04:35 PM
Post Your Pics!!! - Page 13 - YotaTech Forums This thread Refback 01-11-08 10:49 PM
Setting record straight on IFS - Page 3 - YotaTech Forums This thread Refback 01-11-08 10:49 AM
ball joint spacers need HELP!!!!! - YotaTech Forums This thread Refback 01-11-08 12:21 AM
Will 63 in chevies work w/BJ spacers - YotaTech Forums This thread Refback 01-09-08 03:31 PM
My Cruiser Coil/BJ Spacer Lift Thread. - Page 2 - YotaTech Forums This thread Refback 01-06-08 08:18 PM
Converting to Manual Hubs 1987 4Runner - YotaTech Forums This thread Refback 01-06-08 03:50 PM
IFS Flex Pics (DIAL UP, YE BE WARNED) - Page 3 - YotaTech Forums This thread Refback 01-05-08 12:16 AM
A-Arm broke in half, what are my options??? - YotaTech Forums This thread Refback 12-27-07 12:30 AM
Sway-a-way 25mm Torsion Bars - YotaTech Forums This thread Refback 12-26-07 08:58 PM
33 x 12.5 on stock rim? - Page 2 - YotaTech Forums This thread Refback 12-23-07 06:59 AM
Torsion Bar Crankery - YotaTech Forums This thread Refback 12-22-07 07:54 PM
Maximum CV travel - YotaTech Forums This thread Refback 12-20-07 03:25 AM
downey long travel - YotaTech Forums This thread Refback 12-16-07 04:16 PM
