Old 05-12-07, 02:22 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Ripper's Avatar
Idle Dips When Brake Pressed
'85 4R newly rebuilt top end. When engine is warmed up the idle will dip down every 4-5 seconds when I brake. I'm sure it is a vacuum issue but I don't know how to solve it. All my vacuum lines are new. Where do I start?
Ripper
Ripper is offline   Reply With Quote
Old 05-12-07, 04:43 PM   #2 (permalink)
jasonmt's Avatar
Idle speed is set too high.
jasonmt is offline   Reply With Quote
Old 05-12-07, 11:57 PM   #3 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
Ding ding ding!!! Common problem.
Old 05-13-07, 03:22 PM   #4 (permalink)
WristPin's Avatar
wouldnt say its a "problem" but more of a adjustment needed.
Wristy
Jebus...
I like it when I can go out on the porch buck naked ...unroll it and take a wizz without somebody saying ......look john is alive and well
22RE Tech hotline- check the FAQ
Old 05-13-07, 07:12 PM   #5 (permalink)
Ripper's Avatar
THANKS!!!!
You guys rock!!
Ripper
Old 05-13-07, 11:58 PM   #6 (permalink)
Oh nevermind......
TLCA# 13872
Common "adjustment needed" (You think you're soooo great...... boy if I met you in a dark alley......)
Old 05-14-07, 11:52 PM   #7 (permalink)
WristPin's Avatar
no dark alleys in the country
but i might poke you with my poking stick
Wristy
Jebus...
Old 05-14-07, 11:59 PM   #8 (permalink)
WristPin's Avatar
your posts are 1234!
05-13-07, 10:58 PM #6
2ndGenToyotaFan
I've been pre-approved!!!
Wristy
Jebus...
Old 05-15-07, 11:27 AM   #9 (permalink)
beatdown83fj60's Avatar
TLCA# Don't have one yet, but Rising Sun CO will be my domain
A dip at idle can also be a problem with the brake booster iirc while pressing on the brakes.
86 4Runner, stock, and clean......for now
beatdown83fj60 is offline   Reply With Quote
Old 05-15-07, 02:02 PM   #10 (permalink)
Ripper's Avatar
"brake booster iirc"
What is IIRC??
Ripper
Old 05-15-07, 02:32 PM   #11 (permalink)
Blues Dawg's Avatar
TLCA# 16271
What is IIRC??
if i recall correctly?
Yellow FJ Cruiser - a work in progress -
Copper State Cruisers #68
IBL8 & Procrastin8
Blues Dawg is offline   Reply With Quote
Old 05-16-07, 12:27 AM   #12 (permalink)
Sorry, Im becoming a nerd in my later internet days.
Old 05-18-07, 08:45 PM   #13 (permalink)
Ranski's Avatar
I will be chasing down the same issue this weekend. All my research is directing me towards vaccum leak or break booster.
To check break booster do the following:
On vehicle inspection: (before you rip the booster out and yell and scream
at it)
1 check air tightness
- - start engine
- - Stop engine after running for 1-2 minutes
2 pump brake pedal several times.
- -If pedal goes down deep the first time but gradually rises after the 2nd
and 3rd times, it is in good condition. :-)
3 If there is no change in the pedal height when depressed the 2nd and
succesive time it is defective. :-(
Check the operation:
1 With the engine stopped, pump the brake pedal several times with the same
pressure. Ensure that the pedal height does not change.
2 Start the engine while the brake pedal is depressed, place one tablet of
prozacs into the brake fluid reservoir and see if the brakes recover from
their depression. No really, If the pedal goes down slightly at this time,
it is in good condition. If there is no change in pedal height, it is
defective. :-(
Check air tightness under load:
1 With the engine running, depress the brake pedal.
Then stop the engine while keeping the brake pedal depressed.
2 Hold the pedal for 30 seconds. If the pedal height does not change, it is
If the pedal rises, it is defective. :-(
Randy
85' 4Runner
06' Sequoia
Shawnee, Kansas
Ranski is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/79-95-toyota-truck-tech/155085-idle-dips-when-brake-pressed.html
Posted By For Type Date
22er idle problem after engine swap. - Island4x4.com Message Board This thread Refback 11-02-09 01:33 PM
