#31 | |
2nd gen it was definatly "somewhat" rebuilt by someone else, there were non toyota gaskets in it when I got it and it looks like the head and maybe the block have been milled... dono for any certenty tho. __________________ -Nate 88 PU long bed, pro comp 33's All Pro rear suspension Toyota factory e-locker 4/88's And a whole lot of dents contributed solely by new england's natural flora and fauna (mostly responsible is one species of flora... pine) (and the elusive new england delivery truck) |
#32 | |
.....still baffled __________________ -Nate 88 PU long bed, pro comp 33's All Pro rear suspension Toyota factory e-locker 4/88's And a whole lot of dents contributed solely by new england's natural flora and fauna (mostly responsible is one species of flora... pine) (and the elusive new england delivery truck) Last edited by "N8"; 05-09-07 at 08:49 AM. |
#33 | |
Hi ken. So I dont think I called the timing chain cover the head, and I went back and breifly looked at my posts and still dont think I did but if so I apoligise. the first two photos are of the debri I found on top of the piston and mashed into the head right next to the timing chain cover where they were broken from. The second two photos are of the head turned upside down. you can see the soark plug and the intake and exaust valves. oh and ya that nut didnt get up there it stayed in the oil pan im just asuming its what broke the aluminum I found up there, but I still dont know how that got there either. __________________ -Nate 88 PU long bed, pro comp 33's All Pro rear suspension Toyota factory e-locker 4/88's And a whole lot of dents contributed solely by new england's natural flora and fauna (mostly responsible is one species of flora... pine) (and the elusive new england delivery truck) |
#34 |
EURIKA!!!!
ok so I picked up the new intake valve today (exaust is on its way from new york) and started digging into the valves and guess what??? The valve guide is snaped about half way into the head and 1/4 of it is missing. or at least has been found loged in my piston. so the theory of the watterpump nut is over with I guess that hitchhiker didnt do any harm, and looks like my valve cover was just f-ed up to begin with. oh and I now have a good working knoledge of how the valves are installed. so now its on to figuring out how to get the old valve guide out of the head and the new one in. any sugestions from you guys we have a small 12 ton press in the shop but i dono how I would suport the head at the 30 degree angle the valve is set or whatever its really canted at??? The fsm says to heat the head to 200 degrees and tap out the old one and tap in the new one with a hammer but its not like we have a kilm or anything so i dono how ide pull that one off... any ideas? __________________ -Nate 88 PU long bed, pro comp 33's All Pro rear suspension Toyota factory e-locker 4/88's And a whole lot of dents contributed solely by new england's natural flora and fauna (mostly responsible is one species of flora... pine) (and the elusive new england delivery truck) Last edited by "N8"; 05-09-07 at 12:59 PM. |
#35 | |
Something else I did on my head before putting it back on, I drilled out all the threads for the exhaust studs and cam pillow blocks, and installed Helicoils. This was easy to do on my drill press in my basement, but I also had a stripped spark plug hole which I had the machine shop fix. __________________ KB1OSF '87 Toyota xcab SR5 - SAS'd, stuff '98 Lexus ES300 '04 Toyota Highlander |
#36 | |
The recipe should say... Bake at 200 degrees for 30 to 60 minutes or until nicely browned. Take it to a machine shop and have them replace the guide. Now we know where the piston/cylinder head damage came from, but you have not explained the other damage. I think I have an explanation that fits what we know and see in the photos. The photos in posts #17 & #18 are of the BACK side of the front cover. The oil pump goes on the front of that cover. So, that damage is the area where the timing chain goes and not the oil pump. That probably is a nut from the water pump pulley. The most likely explanation is, that it was accidentally left in the rocker area of the cylinder head during assembly of the engine or possibly dropped into the oil fill opening at some point. Then something wore it down until it fell to the lower timing gear and caused that damage. The noise was probably the nut going round and round doing its damage. __________________ Kevin `85 4Runner - work in progress M416 Trailer - ukn year, rebuilt July 2007, build thread `68 FJ40 - planning stages of a build Green Country Cruisers - member Wish List - to long to post |
#37 |
well here are my thoughts.
right now I have 3 heads in my posession the one with the broken valve guide, one disasembled and one other completly asembled. so I have the valve guide probobly coming in tomorrow or the next day. I figure if i try to do this myself and screw this up I have two other heads to fall back on. on top of this nat offerd to turn his grill into an oven for heating the head. I figure as long as I can use a thermometer to regulate the tempurature precisely it should be fine. I can spend an hour or two preheating the oven and stabalising the temperature and then a couple hours warming the head and then the fsm says just to use a punch to set the valve guide till the retainer clip is seated against the head. so if I do screw the pooch on this one I can send out the striped head with some good valves to be completly redone and in the mean time use the one that is assembled this will allow me a crack at fixing this myself and the experence is worth something to me. maybe this is a stupid idea but I feel that most of what I do is baced on such ideas o and the noise I was hearing was definatly the piston coming up and smashing the valve guide into the head it was a very distinct noise that was in time with the engine. I think that all that other stuff was just there not doing anything. I asume the PO screwed up the valve cover and put it back on anyway and at some point a watter pump pully nut fell into the engine somehow and I just found it when I tore the block down. so the only other question I have is should I be worried about other valve guides breaking and what could have caused this to happen other than normal wear and tear? I dono if I should be looking for something that caused this or if I should be onto the reasembly of the head at this point. any ideas? __________________ -Nate 88 PU long bed, pro comp 33's All Pro rear suspension Toyota factory e-locker 4/88's And a whole lot of dents contributed solely by new england's natural flora and fauna (mostly responsible is one species of flora... pine) (and the elusive new england delivery truck) |
#38 |
No longer pre-approved...
No need to heat it up, I've replaced a few just by breaking off the top part that sticks up inside where the valve spring goes (There is a snapring thing, so you have to break it) Then knock it out through the other side. The tricky part is getting the valve to valve guide clearance right.... I forget how you're suposed to do it...
__________________ Jerod Online Toyota Parts Catalog!!! 89 4Runner "The James Caird" 01 4Runner, for my Jefferson State Cruisers |
Debt Consolidation | Secured Loans | Online Loans | Loans | Secured Loans |
